loading LinuxCNC on old smithy 1240
4 years 1 day ago - 4 years 1 day ago #255585
Replied by andypugh on topic loading LinuxCNC on old smithy 1240
Can you try
(The & gives you the command line back without waiting for linuxcnc to exit first)
linuxcnc &
dmesg
Last edit: 4 years 1 day ago by andypugh.
4 years 1 day ago #255587
by LPMattei
Replied by LPMattei on topic loading LinuxCNC on old smithy 1240
New info, F2 (toggle machine power) worked, it enabled home button and I was able to home system. Spindle does not work, but we are getting close,.
4 years 1 day ago #255588
Can you look at all the 8i20 fault pins?
halcmd show pin *8i20*
4 years 1 day ago #255589
The "Can't do ... PAUSE" is probably due to this bit of the HAL
which will isue a "PAUSE" command any time the spindle contactor is off (probably)
The TTT error is due to the NGCGUI add-ins which I assume are called up in a postgui file?
# Spindle Contactor - False when spindle contactor is energized
net SOFF hm2_5i20.0.gpio.033.in halui.program.pause motion.feed-hold
4 years 1 day ago #255597
by LPMattei
smithy@debian:~$ halcmd show pin *8i20*
Component Pins:
Owner Type Dir Value Name
9 float IN 0.1666667 hm2_5i20.0.8i20.0.0.angle <== rotor_angle
9 float OUT 0 hm2_5i20.0.8i20.0.0.bus-voltage ==> voltage
9 float OUT 28 hm2_5i20.0.8i20.0.0.card-temp ==> temp
9 float IN -0 hm2_5i20.0.8i20.0.0.current <== current
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.U-current
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.U-current-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.V-current
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.V-current-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.W-current
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.W-current-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-high
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.bus-high-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-overv
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.bus-overv-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-underv
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.bus-underv-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.framingr
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.framingr-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.module
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.module-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.no-enable
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.no-enable-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overcurrent
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.overcurrent-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overrun
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.overrun-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overtemp
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.overtemp-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.watchdog
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.fault.watchdog-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.brake-old
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.brake-old-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.brake-on
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.brake-on-not
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.bus-underv
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.bus-underv-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.current-lim
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.current-lim-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.ext-reset
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.ext-reset-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.no-enable
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.no-enable-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.pid-on
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.pid-on-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.sw-reset
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.sw-reset-not
9 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.wd-reset
9 bit OUT TRUE hm2_5i20.0.8i20.0.0.status.wd-reset-not
smithy@debian:~$
Component Pins:
smithy@debian:~$
4 years 1 day ago - 4 years 1 day ago #255598
by LPMattei
Output of dmesg
[ 4.646341] scsi host4: usb-storage 5-6.2:1.0
[ 4.646425] usbcore: registered new interface driver usb-storage
[ 4.660208] usbcore: registered new interface driver uas
[ 5.141292] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 5.141341] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[ 5.141386] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[ 5.147475] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[ 5.196188] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[ 5.212174] RTL8211E Gigabit Ethernet r8169-300:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
[ 5.411112] r8169 0000:03:00.0 enp3s0: Link is Down
[ 5.411198] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[ 5.669308] scsi 4:0:0:0: Direct-Access Kingston DataTraveler 112 1.00 PQ: 0 ANSI: 2
[ 5.669640] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 5.672780] sd 4:0:0:0: [sdb] 3913664 512-byte logical blocks: (2.00 GB/1.87 GiB)
[ 5.673398] sd 4:0:0:0: [sdb] Write Protect is off
[ 5.673399] sd 4:0:0:0: [sdb] Mode Sense: 03 00 00 00
[ 5.674662] sd 4:0:0:0: [sdb] No Caching mode page found
[ 5.674666] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 5.679918] sdb: sdb1
[ 5.682678] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 8.399942] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 8.399953] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 8.611223] random: crng init done
[ 8.611227] random: 7 urandom warning(s) missed due to ratelimiting
[ 83.151506] I-pipe: head domain RTAI registered.
[ 83.151508] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 83.151511] SYSINFO - # CPUs: 2, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 12499299, CLOCK NAME: 'tsc', CLOCK FREQ: 2999928000, CPU FREQ: 2999928000, LINUX TIMER IRQ: 4355.
[ 83.165302] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 83.165325] kstacks pool size = 524288 bytes
[ 83.165326] RTAI[sched]: hard timer type/freq = lapic/12499299(Hz)
[ 83.165326] linear timed lists.
[ 83.165327] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999928000 hz.
[ 83.165328] RTAI[sched]: timer setup = 80 ns, resched latency = 0 ns.
[ 83.183939] USERMODE CHECK: OK.
[ 83.183942] USERMODE CHECK PROVIDED (ns): KernelLatency 2577, UserLatency 2781.
[ 83.183943] FINAL CALIBRATION SUMMARY (ns): KernelLatency 2577, UserLatency 2781.
[ 83.192266] RTAI[math]: loaded, using musl libm.
[ 83.250096] hm2: loading Mesa HostMot2 driver version 0.15
[ 83.254494] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 83.254612] hm2_pci: discovered 5i20 at 0000:04:01.0
[ 83.393971] hm2/hm2_5i20.0: Low Level init 0.15
[ 83.393994] hm2/hm2_5i20.0: IDRom:
[ 83.393996] hm2/hm2_5i20.0: IDRom Type: 0x00000003
[ 83.393997] hm2/hm2_5i20.0: Offset to Modules: 0x00000040
[ 83.393998] hm2/hm2_5i20.0: Offset to Pin Description: 0x000001C0
[ 83.393999] hm2/hm2_5i20.0: Board Name: MESA5I20
[ 83.394000] hm2/hm2_5i20.0: FPGA Size: 200
[ 83.394000] hm2/hm2_5i20.0: FPGA Pins: 208
[ 83.394001] hm2/hm2_5i20.0: Port Width: 24
[ 83.394002] hm2/hm2_5i20.0: IO Ports: 3
[ 83.394003] hm2/hm2_5i20.0: IO Width: 72
[ 83.394004] hm2/hm2_5i20.0: Clock Low: 33333333 Hz (33333 KHz, 33 MHz)
[ 83.394005] hm2/hm2_5i20.0: Clock High: 100000000 Hz (100000 KHz, 100 MHz)
[ 83.394006] hm2/hm2_5i20.0: Instance Stride 0: 0x00000004
[ 83.394007] hm2/hm2_5i20.0: Instance Stride 1: 0x00000040
[ 83.394008] hm2/hm2_5i20.0: Register Stride 0: 0x00000100
[ 83.394009] hm2/hm2_5i20.0: Register Stride 1: 0x00000100
[ 83.394084] hm2/hm2_5i20.0: 72 HM2 Pin Descriptors:
[ 83.394085] hm2/hm2_5i20.0: pin 0:
[ 83.394086] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394087] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 83.394088] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 83.394090] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 83.394091] hm2/hm2_5i20.0: pin 1:
[ 83.394091] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394092] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 83.394093] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 83.394094] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 83.394095] hm2/hm2_5i20.0: pin 2:
[ 83.394096] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394097] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 83.394098] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 83.394099] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 83.394099] hm2/hm2_5i20.0: pin 3:
[ 83.394100] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394101] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 83.394102] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 83.394103] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 83.394104] hm2/hm2_5i20.0: pin 4:
[ 83.394105] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394106] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 83.394107] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 83.394108] hm2/hm2_5i20.0: Secondary Pin: 0x01 (A, Input)
[ 83.394108] hm2/hm2_5i20.0: pin 5:
[ 83.394109] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394110] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 83.394111] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 83.394112] hm2/hm2_5i20.0: Secondary Pin: 0x01 (A, Input)
[ 83.394113] hm2/hm2_5i20.0: pin 6:
[ 83.394114] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394115] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 83.394116] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 83.394117] hm2/hm2_5i20.0: Secondary Pin: 0x02 (B, Input)
[ 83.394117] hm2/hm2_5i20.0: pin 7:
[ 83.394118] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394119] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 83.394120] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 83.394121] hm2/hm2_5i20.0: Secondary Pin: 0x02 (B, Input)
[ 83.394122] hm2/hm2_5i20.0: pin 8:
[ 83.394123] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394124] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 83.394124] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 83.394125] hm2/hm2_5i20.0: Secondary Pin: 0x03 (Index, Input)
[ 83.394126] hm2/hm2_5i20.0: pin 9:
[ 83.394127] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394128] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 83.394129] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 83.394130] hm2/hm2_5i20.0: Secondary Pin: 0x03 (Index, Input)
[ 83.394131] hm2/hm2_5i20.0: pin 10:
[ 83.394131] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394132] hm2/hm2_5i20.0: pin 11:
[ 83.394133] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394134] hm2/hm2_5i20.0: pin 12:
[ 83.394135] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394136] hm2/hm2_5i20.0: pin 13:
[ 83.394137] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394137] hm2/hm2_5i20.0: pin 14:
[ 83.394138] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394139] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 83.394140] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 83.394142] hm2/hm2_5i20.0: Secondary Pin: 0x01 (rx0, Input)
[ 83.394142] hm2/hm2_5i20.0: pin 15:
[ 83.394143] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394144] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 83.394145] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 83.394146] hm2/hm2_5i20.0: Secondary Pin: 0x02 (rx1, Input)
[ 83.394147] hm2/hm2_5i20.0: pin 16:
[ 83.394148] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394149] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 83.394150] hm2/hm2_5i20.0: Secondary Unit: 0x02
[ 83.394151] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 83.394151] hm2/hm2_5i20.0: pin 17:
[ 83.394152] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394153] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 83.394154] hm2/hm2_5i20.0: Secondary Unit: 0x02
[ 83.394155] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 83.394156] hm2/hm2_5i20.0: pin 18:
[ 83.394157] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394158] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 83.394159] hm2/hm2_5i20.0: Secondary Unit: 0x03
[ 83.394160] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 83.394160] hm2/hm2_5i20.0: pin 19:
[ 83.394161] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394162] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 83.394163] hm2/hm2_5i20.0: Secondary Unit: 0x03
[ 83.394164] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 83.394165] hm2/hm2_5i20.0: pin 20:
[ 83.394166] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394167] hm2/hm2_5i20.0: Secondary Tag: 0x06 (PWMGen)
[ 83.394168] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 83.394169] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Out0 (PWM or Up), Output)
[ 83.394170] hm2/hm2_5i20.0: pin 21:
[ 83.394171] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394172] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 83.394172] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 83.394174] hm2/hm2_5i20.0: Secondary Pin: 0x81 (tx0, Output)
[ 83.394174] hm2/hm2_5i20.0: pin 22:
[ 83.394175] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394176] hm2/hm2_5i20.0: Secondary Tag: 0x06 (PWMGen)
[ 83.394177] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 83.394178] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Out0 (PWM or Up), Output)
[ 83.394179] hm2/hm2_5i20.0: pin 23:
[ 83.394180] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394181] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 83.394182] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 83.394183] hm2/hm2_5i20.0: Secondary Pin: 0x82 (tx1, Output)
[ 83.394184] hm2/hm2_5i20.0: pin 24:
[ 83.394184] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394185] hm2/hm2_5i20.0: pin 25:
[ 83.394186] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394187] hm2/hm2_5i20.0: pin 26:
[ 83.394188] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394189] hm2/hm2_5i20.0: pin 27:
[ 83.394190] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394190] hm2/hm2_5i20.0: pin 28:
[ 83.394191] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394192] hm2/hm2_5i20.0: pin 29:
[ 83.394193] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394194] hm2/hm2_5i20.0: pin 30:
[ 83.394195] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394195] hm2/hm2_5i20.0: pin 31:
[ 83.394196] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394197] hm2/hm2_5i20.0: pin 32:
[ 83.394198] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394199] hm2/hm2_5i20.0: pin 33:
[ 83.394200] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394200] hm2/hm2_5i20.0: pin 34:
[ 83.394201] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394202] hm2/hm2_5i20.0: pin 35:
[ 83.394203] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394204] hm2/hm2_5i20.0: pin 36:
[ 83.394205] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394205] hm2/hm2_5i20.0: pin 37:
[ 83.394206] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394207] hm2/hm2_5i20.0: pin 38:
[ 83.394208] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394209] hm2/hm2_5i20.0: pin 39:
[ 83.394210] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394210] hm2/hm2_5i20.0: pin 40:
[ 83.394211] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394212] hm2/hm2_5i20.0: pin 41:
[ 83.394213] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394214] hm2/hm2_5i20.0: pin 42:
[ 83.394215] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394215] hm2/hm2_5i20.0: pin 43:
[ 83.394216] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394217] hm2/hm2_5i20.0: pin 44:
[ 83.394218] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394219] hm2/hm2_5i20.0: pin 45:
[ 83.394220] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394220] hm2/hm2_5i20.0: pin 46:
[ 83.394221] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394222] hm2/hm2_5i20.0: pin 47:
[ 83.394223] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394224] hm2/hm2_5i20.0: pin 48:
[ 83.394225] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394225] hm2/hm2_5i20.0: pin 49:
[ 83.394226] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394227] hm2/hm2_5i20.0: pin 50:
[ 83.394228] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394229] hm2/hm2_5i20.0: pin 51:
[ 83.394230] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394230] hm2/hm2_5i20.0: pin 52:
[ 83.394231] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394232] hm2/hm2_5i20.0: pin 53:
[ 83.394233] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394234] hm2/hm2_5i20.0: pin 54:
[ 83.394235] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394235] hm2/hm2_5i20.0: pin 55:
[ 83.394236] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394237] hm2/hm2_5i20.0: pin 56:
[ 83.394238] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394239] hm2/hm2_5i20.0: pin 57:
[ 83.394240] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394240] hm2/hm2_5i20.0: pin 58:
[ 83.394241] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394242] hm2/hm2_5i20.0: pin 59:
[ 83.394243] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394244] hm2/hm2_5i20.0: pin 60:
[ 83.394245] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394245] hm2/hm2_5i20.0: pin 61:
[ 83.394246] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394247] hm2/hm2_5i20.0: pin 62:
[ 83.394248] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394249] hm2/hm2_5i20.0: pin 63:
[ 83.394250] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394250] hm2/hm2_5i20.0: pin 64:
[ 83.394251] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394252] hm2/hm2_5i20.0: pin 65:
[ 83.394253] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394254] hm2/hm2_5i20.0: pin 66:
[ 83.394255] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394255] hm2/hm2_5i20.0: pin 67:
[ 83.394256] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394257] hm2/hm2_5i20.0: pin 68:
[ 83.394258] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394259] hm2/hm2_5i20.0: pin 69:
[ 83.394260] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394261] hm2/hm2_5i20.0: pin 70:
[ 83.394261] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394262] hm2/hm2_5i20.0: pin 71:
[ 83.394263] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 83.394267] hm2/hm2_5i20.0: Module Descriptor 0 at 0x0440:
[ 83.394268] hm2/hm2_5i20.0: General Function Tag: 2 (Watchdog)
[ 83.394269] hm2/hm2_5i20.0: Version: 0
[ 83.394271] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 83.394272] hm2/hm2_5i20.0: Instances: 1
[ 83.394273] hm2/hm2_5i20.0: Base Address: 0x0C00
[ 83.394273] hm2/hm2_5i20.0: -- Num Registers: 3
[ 83.394274] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 83.394275] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 83.394276] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000000
[ 83.394280] hm2/hm2_5i20.0: Module Descriptor 1 at 0x044C:
[ 83.394281] hm2/hm2_5i20.0: General Function Tag: 3 (IOPort)
[ 83.394282] hm2/hm2_5i20.0: Version: 0
[ 83.394283] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 83.394284] hm2/hm2_5i20.0: Instances: 3
[ 83.394285] hm2/hm2_5i20.0: Base Address: 0x1000
[ 83.394286] hm2/hm2_5i20.0: -- Num Registers: 5
[ 83.394287] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 83.394287] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 83.394288] hm2/hm2_5i20.0: -- Multiple Registers: 0x0000001F
[ 83.394292] hm2/hm2_5i20.0: Module Descriptor 2 at 0x0458:
[ 83.394293] hm2/hm2_5i20.0: General Function Tag: 4 (Encoder)
[ 83.394294] hm2/hm2_5i20.0: Version: 2
[ 83.394295] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 83.394296] hm2/hm2_5i20.0: Instances: 2
[ 83.394297] hm2/hm2_5i20.0: Base Address: 0x3000
[ 83.394298] hm2/hm2_5i20.0: -- Num Registers: 5
[ 83.394299] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 83.394300] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 83.394300] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000003
[ 83.394304] hm2/hm2_5i20.0: Module Descriptor 3 at 0x0464:
[ 83.394305] hm2/hm2_5i20.0: General Function Tag: 6 (PWMGen)
[ 83.394306] hm2/hm2_5i20.0: Version: 0
[ 83.394307] hm2/hm2_5i20.0: Clock Tag: 2 (100.000 MHz)
[ 83.394308] hm2/hm2_5i20.0: Instances: 2
[ 83.394309] hm2/hm2_5i20.0: Base Address: 0x4000
[ 83.394310] hm2/hm2_5i20.0: -- Num Registers: 5
[ 83.394311] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 83.394312] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 83.394313] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000003
[ 83.394317] hm2/hm2_5i20.0: Module Descriptor 4 at 0x0470:
[ 83.394318] hm2/hm2_5i20.0: General Function Tag: 5 (StepGen)
[ 83.394318] hm2/hm2_5i20.0: Version: 2
[ 83.394320] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 83.394320] hm2/hm2_5i20.0: Instances: 4
[ 83.394321] hm2/hm2_5i20.0: Base Address: 0x2000
[ 83.394322] hm2/hm2_5i20.0: -- Num Registers: 10
[ 83.394323] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 83.394324] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 83.394325] hm2/hm2_5i20.0: -- Multiple Registers: 0x000001FF
[ 83.394329] hm2/hm2_5i20.0: Module Descriptor 5 at 0x047C:
[ 83.394330] hm2/hm2_5i20.0: General Function Tag: 193 (Smart Serial Interface)
[ 83.394331] hm2/hm2_5i20.0: Version: 0
[ 83.394332] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 83.394333] hm2/hm2_5i20.0: Instances: 1
[ 83.394333] hm2/hm2_5i20.0: Base Address: 0x5A00
[ 83.394334] hm2/hm2_5i20.0: -- Num Registers: 6
[ 83.394335] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 83.394336] hm2/hm2_5i20.0: -- Instance Stride: 0x00000040
[ 83.394337] hm2/hm2_5i20.0: -- Multiple Registers: 0x0000003C
[ 83.394341] hm2/hm2_5i20.0: Module Descriptor 6 at 0x0488:
[ 83.394342] hm2/hm2_5i20.0: General Function Tag: 128 (LED)
[ 83.394343] hm2/hm2_5i20.0: Version: 0
[ 83.394344] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 83.394345] hm2/hm2_5i20.0: Instances: 1
[ 83.394346] hm2/hm2_5i20.0: Base Address: 0x0200
[ 83.394347] hm2/hm2_5i20.0: -- Num Registers: 1
[ 83.394348] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 83.394348] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 83.394349] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000000
[ 83.394741] hm2/hm2_5i20.0: Smart Serial Firmware Version 31
[ 83.404104] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 83.404108] hm2/hm2_5i20.0: IO Pin 000 (P2-01): StepGen #0, pin Step (Output)
[ 83.404109] hm2/hm2_5i20.0: IO Pin 001 (P2-03): StepGen #0, pin Direction (Output)
[ 83.404111] hm2/hm2_5i20.0: IO Pin 002 (P2-05): StepGen #1, pin Step (Output)
[ 83.404112] hm2/hm2_5i20.0: IO Pin 003 (P2-07): StepGen #1, pin Direction (Output)
[ 83.404113] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Encoder #0, pin A (Input)
[ 83.404114] hm2/hm2_5i20.0: IO Pin 005 (P2-11): IOPort
[ 83.404115] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Encoder #0, pin B (Input)
[ 83.404116] hm2/hm2_5i20.0: IO Pin 007 (P2-15): IOPort
[ 83.404118] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Encoder #0, pin Index (Input)
[ 83.404119] hm2/hm2_5i20.0: IO Pin 009 (P2-19): IOPort
[ 83.404120] hm2/hm2_5i20.0: IO Pin 010 (P2-21): IOPort
[ 83.404121] hm2/hm2_5i20.0: IO Pin 011 (P2-23): IOPort
[ 83.404122] hm2/hm2_5i20.0: IO Pin 012 (P2-25): IOPort
[ 83.404123] hm2/hm2_5i20.0: IO Pin 013 (P2-27): IOPort
[ 83.404125] hm2/hm2_5i20.0: IO Pin 014 (P2-29): Smart Serial Interface #0, pin rx0 (Input)
[ 83.404126] hm2/hm2_5i20.0: IO Pin 015 (P2-31): IOPort
[ 83.404127] hm2/hm2_5i20.0: IO Pin 016 (P2-33): StepGen #2, pin Step (Output)
[ 83.404129] hm2/hm2_5i20.0: IO Pin 017 (P2-35): StepGen #2, pin Direction (Output)
[ 83.404130] hm2/hm2_5i20.0: IO Pin 018 (P2-37): StepGen #3, pin Step (Output)
[ 83.404131] hm2/hm2_5i20.0: IO Pin 019 (P2-39): StepGen #3, pin Direction (Output)
[ 83.404132] hm2/hm2_5i20.0: IO Pin 020 (P2-41): IOPort
[ 83.404134] hm2/hm2_5i20.0: IO Pin 021 (P2-43): Smart Serial Interface #0, pin tx0 (Output)
[ 83.404135] hm2/hm2_5i20.0: IO Pin 022 (P2-45): IOPort
[ 83.404136] hm2/hm2_5i20.0: IO Pin 023 (P2-47): IOPort
[ 83.404137] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 83.404138] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 83.404139] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 83.404140] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 83.404141] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 83.404142] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 83.404143] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 83.404145] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 83.404146] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 83.404147] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 83.404148] hm2/hm2_5i20.0: IO Pin 034 (P3-21): IOPort
[ 83.404149] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 83.404150] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 83.404151] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 83.404152] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 83.404153] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 83.404154] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 83.404155] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 83.404156] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 83.404158] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 83.404159] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 83.404160] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 83.404161] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 83.404162] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 83.404163] hm2/hm2_5i20.0: IO Pin 048 (P4-01): IOPort
[ 83.404164] hm2/hm2_5i20.0: IO Pin 049 (P4-03): IOPort
[ 83.404165] hm2/hm2_5i20.0: IO Pin 050 (P4-05): IOPort
[ 83.404166] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 83.404167] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 83.404169] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 83.404170] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 83.404171] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 83.404172] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 83.404173] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 83.404174] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 83.404175] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 83.404176] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 83.404177] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 83.404178] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 83.404179] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 83.404180] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 83.404182] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 83.404183] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 83.404184] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 83.404185] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 83.404186] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 83.404187] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 83.404188] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 83.404189] hm2/hm2_5i20.0: HM2 Modules used:
[ 83.404190] hm2/hm2_5i20.0: Encoders: 1
[ 83.404192] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 83.404193] hm2/hm2_5i20.0: version: 2
[ 83.404193] hm2/hm2_5i20.0: counter_addr: 0x3000
[ 83.404194] hm2/hm2_5i20.0: latch_control_addr: 0x3100
[ 83.404195] hm2/hm2_5i20.0: timestamp_div_addr: 0x3200
[ 83.404196] hm2/hm2_5i20.0: timestamp_count_addr: 0x3300
[ 83.404197] hm2/hm2_5i20.0: filter_rate_addr: 0x3400
[ 83.404198] hm2/hm2_5i20.0: timestamp_div: 0x0000
[ 83.404199] hm2/hm2_5i20.0: instance 0:
[ 83.404200] hm2/hm2_5i20.0: hw:
[ 83.404201] hm2/hm2_5i20.0: counter = 0003.ffff
[ 83.404202] hm2/hm2_5i20.0: latch/control = 0000.0800
[ 83.404203] hm2/hm2_5i20.0: prev_control = 0000.0800
[ 83.404205] hm2/hm2_5i20.0: SSerial: 1
[ 83.404206] hm2/hm2_5i20.0: version 31
[ 83.404207] hm2/hm2_5i20.0: instance 0:
[ 83.404208] hm2/hm2_5i20.0: Command Addr 0x5a00
[ 83.404209] hm2/hm2_5i20.0: Data Addr 0x5b00
[ 83.404210] hm2/hm2_5i20.0: port 0 device hm2_5i20.0.8i20.0.0
[ 83.404211] hm2/hm2_5i20.0: Parameters:
[ 83.404212] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404213] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404214] hm2/hm2_5i20.0: DataType = 0x02
[ 83.404214] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404215] hm2/hm2_5i20.0: ParmMax 1.00
[ 83.404216] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404217] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404218] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404219] hm2/hm2_5i20.0: UnitString = degrees
[ 83.404220] hm2/hm2_5i20.0: NameString = angle
[ 83.404221] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404222] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404223] hm2/hm2_5i20.0: DataType = 0x03
[ 83.404224] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404225] hm2/hm2_5i20.0: ParmMax 30.00
[ 83.404225] hm2/hm2_5i20.0: ParmMin -30.00
[ 83.404226] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404227] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404228] hm2/hm2_5i20.0: UnitString = amps
[ 83.404229] hm2/hm2_5i20.0: NameString = current
[ 83.404230] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404231] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404232] hm2/hm2_5i20.0: DataType = 0x02
[ 83.404233] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404234] hm2/hm2_5i20.0: ParmMax 65535.00
[ 83.404235] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404235] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404236] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404237] hm2/hm2_5i20.0: UnitString = Deg C
[ 83.404238] hm2/hm2_5i20.0: NameString = card-temp
[ 83.404239] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404240] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404241] hm2/hm2_5i20.0: DataType = 0x02
[ 83.404242] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404243] hm2/hm2_5i20.0: ParmMax 655.34
[ 83.404244] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404245] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404245] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404246] hm2/hm2_5i20.0: UnitString = volts
[ 83.404247] hm2/hm2_5i20.0: NameString = bus-voltage
[ 83.404248] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404249] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404250] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404251] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404252] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404253] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404254] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404254] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404255] hm2/hm2_5i20.0: UnitString = none
[ 83.404256] hm2/hm2_5i20.0: NameString = status.current-lim
[ 83.404257] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404258] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404259] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404260] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404261] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404262] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404262] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404263] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404264] hm2/hm2_5i20.0: UnitString = none
[ 83.404265] hm2/hm2_5i20.0: NameString = status.brake-on
[ 83.404266] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404267] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404268] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404269] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404269] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404270] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404271] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404272] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404273] hm2/hm2_5i20.0: UnitString = none
[ 83.404274] hm2/hm2_5i20.0: NameString = status.brake-old
[ 83.404275] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404276] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404277] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404277] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404278] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404279] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404280] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404281] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404282] hm2/hm2_5i20.0: UnitString = none
[ 83.404283] hm2/hm2_5i20.0: NameString = status.bus-underv
[ 83.404284] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404285] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404286] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404287] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404287] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404288] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404289] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404290] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404291] hm2/hm2_5i20.0: UnitString = none
[ 83.404292] hm2/hm2_5i20.0: NameString = status.wd-reset
[ 83.404293] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404294] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404295] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404295] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404296] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404297] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404298] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404299] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404300] hm2/hm2_5i20.0: UnitString = none
[ 83.404301] hm2/hm2_5i20.0: NameString = status.sw-reset
[ 83.404302] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404303] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404303] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404304] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404305] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404306] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404307] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404308] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404309] hm2/hm2_5i20.0: UnitString = none
[ 83.404310] hm2/hm2_5i20.0: NameString = status.ext-reset
[ 83.404311] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404311] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404312] hm2/hm2_5i20.0: DataType = 0x00
[ 83.404313] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404314] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404315] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404316] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404317] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404318] hm2/hm2_5i20.0: UnitString = pad
[ 83.404319] hm2/hm2_5i20.0: NameString = pad
[ 83.404319] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404320] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404321] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404322] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404323] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404324] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404325] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404326] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404326] hm2/hm2_5i20.0: UnitString = none
[ 83.404327] hm2/hm2_5i20.0: NameString = status.no-enable
[ 83.404328] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404329] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404330] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404331] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404332] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404333] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404334] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404334] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404335] hm2/hm2_5i20.0: UnitString = none
[ 83.404336] hm2/hm2_5i20.0: NameString = status.pid-on
[ 83.404337] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404338] hm2/hm2_5i20.0: DataLength = 0x06
[ 83.404339] hm2/hm2_5i20.0: DataType = 0x00
[ 83.404340] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404341] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404342] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404343] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404343] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404344] hm2/hm2_5i20.0: UnitString = pad
[ 83.404345] hm2/hm2_5i20.0: NameString = pad
[ 83.404346] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404347] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404348] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404349] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404350] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404351] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404351] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404352] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404353] hm2/hm2_5i20.0: UnitString = none
[ 83.404354] hm2/hm2_5i20.0: NameString = fault.watchdog
[ 83.404355] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404356] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404357] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404358] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404359] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404359] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404360] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404361] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404362] hm2/hm2_5i20.0: UnitString = none
[ 83.404363] hm2/hm2_5i20.0: NameString = fault.no-enable
[ 83.404364] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404365] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404366] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404367] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404367] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404368] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404369] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404370] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404371] hm2/hm2_5i20.0: UnitString = none
[ 83.404372] hm2/hm2_5i20.0: NameString = fault.overtemp
[ 83.404373] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404374] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404375] hm2/hm2_5i20.0: DataType = 0x00
[ 83.404375] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404376] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404377] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404378] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404379] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404380] hm2/hm2_5i20.0: UnitString = pad
[ 83.404381] hm2/hm2_5i20.0: NameString = pad
[ 83.404382] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404383] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404384] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404384] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404385] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404386] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404387] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404388] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404389] hm2/hm2_5i20.0: UnitString = none
[ 83.404390] hm2/hm2_5i20.0: NameString = fault.overcurrent
[ 83.404391] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404392] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404393] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404393] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404394] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404395] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404396] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404397] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404398] hm2/hm2_5i20.0: UnitString = none
[ 83.404399] hm2/hm2_5i20.0: NameString = fault.U-current
[ 83.404400] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404400] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404401] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404402] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404403] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404404] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404405] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404406] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404407] hm2/hm2_5i20.0: UnitString = none
[ 83.404408] hm2/hm2_5i20.0: NameString = fault.V-current
[ 83.404408] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404409] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404410] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404411] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404412] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404413] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404414] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404415] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404415] hm2/hm2_5i20.0: UnitString = none
[ 83.404416] hm2/hm2_5i20.0: NameString = fault.W-current
[ 83.404417] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404418] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404419] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404420] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404421] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404422] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404422] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404423] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404424] hm2/hm2_5i20.0: UnitString = none
[ 83.404425] hm2/hm2_5i20.0: NameString = fault.bus-underv
[ 83.404426] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404427] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404428] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404429] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404430] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404430] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404431] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404432] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404433] hm2/hm2_5i20.0: UnitString = none
[ 83.404434] hm2/hm2_5i20.0: NameString = fault.bus-high
[ 83.404435] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404436] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404437] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404438] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404439] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404439] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404440] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404441] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404442] hm2/hm2_5i20.0: UnitString = none
[ 83.404443] hm2/hm2_5i20.0: NameString = fault.bus-overv
[ 83.404444] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404445] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404446] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404447] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404448] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404448] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404449] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404450] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404451] hm2/hm2_5i20.0: UnitString = none
[ 83.404452] hm2/hm2_5i20.0: NameString = fault.module
[ 83.404453] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404454] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404455] hm2/hm2_5i20.0: DataType = 0x00
[ 83.404456] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404457] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404457] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404458] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404459] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404460] hm2/hm2_5i20.0: UnitString = pad
[ 83.404461] hm2/hm2_5i20.0: NameString = pad
[ 83.404462] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404463] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404464] hm2/hm2_5i20.0: DataType = 0x00
[ 83.404465] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404465] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404466] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404467] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404468] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404469] hm2/hm2_5i20.0: UnitString = pad
[ 83.404470] hm2/hm2_5i20.0: NameString = pad
[ 83.404471] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404472] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404473] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404473] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404474] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404475] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404476] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404477] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404478] hm2/hm2_5i20.0: UnitString = none
[ 83.404479] hm2/hm2_5i20.0: NameString = fault.overrun
[ 83.404480] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404481] hm2/hm2_5i20.0: DataLength = 0x01
[ 83.404482] hm2/hm2_5i20.0: DataType = 0x07
[ 83.404482] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404483] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404484] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404485] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 83.404486] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 83.404487] hm2/hm2_5i20.0: UnitString = none
[ 83.404488] hm2/hm2_5i20.0: NameString = fault.framingr
[ 83.404489] hm2/hm2_5i20.0: Globals:
[ 83.404490] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404491] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404491] hm2/hm2_5i20.0: DataType = 0x02
[ 83.404492] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404493] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404494] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404495] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404496] hm2/hm2_5i20.0: ParmAddr = 0x0874
[ 83.404497] hm2/hm2_5i20.0: UnitString = none
[ 83.404498] hm2/hm2_5i20.0: NameString = swrevision
[ 83.404499] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404500] hm2/hm2_5i20.0: DataLength = 0x20
[ 83.404500] hm2/hm2_5i20.0: DataType = 0x02
[ 83.404501] hm2/hm2_5i20.0: DataDir = 0x00
[ 83.404502] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404503] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404504] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404505] hm2/hm2_5i20.0: ParmAddr = 0x0928
[ 83.404506] hm2/hm2_5i20.0: UnitString = none
[ 83.404507] hm2/hm2_5i20.0: NameString = unitnumber
[ 83.404507] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404508] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404509] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404510] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404511] hm2/hm2_5i20.0: ParmMax 32.76
[ 83.404512] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404513] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404513] hm2/hm2_5i20.0: ParmAddr = 0x0002
[ 83.404514] hm2/hm2_5i20.0: UnitString = amps
[ 83.404515] hm2/hm2_5i20.0: NameString = nvmaxcurrent
[ 83.404516] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404517] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404518] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404519] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404520] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404521] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404522] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404522] hm2/hm2_5i20.0: ParmAddr = 0x0024
[ 83.404523] hm2/hm2_5i20.0: UnitString = volts
[ 83.404524] hm2/hm2_5i20.0: NameString = nvbusundervmax
[ 83.404525] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404526] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404527] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404528] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404529] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404530] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404530] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404531] hm2/hm2_5i20.0: ParmAddr = 0x0022
[ 83.404532] hm2/hm2_5i20.0: UnitString = volts
[ 83.404533] hm2/hm2_5i20.0: NameString = nvbusundervmin
[ 83.404534] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404535] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404536] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404537] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404538] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404538] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404539] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404540] hm2/hm2_5i20.0: ParmAddr = 0x0026
[ 83.404541] hm2/hm2_5i20.0: UnitString = volts
[ 83.404542] hm2/hm2_5i20.0: NameString = nvbusoverv
[ 83.404543] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404544] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404545] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404546] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404546] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404547] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404548] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404549] hm2/hm2_5i20.0: ParmAddr = 0x0028
[ 83.404550] hm2/hm2_5i20.0: UnitString = volts
[ 83.404551] hm2/hm2_5i20.0: NameString = nvbrakeonv
[ 83.404552] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404553] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404554] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404554] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404555] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404556] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404557] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404558] hm2/hm2_5i20.0: ParmAddr = 0x002a
[ 83.404559] hm2/hm2_5i20.0: UnitString = volts
[ 83.404560] hm2/hm2_5i20.0: NameString = nvbrakeoffv
[ 83.404561] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404562] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404563] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404563] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404564] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404565] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404566] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404567] hm2/hm2_5i20.0: ParmAddr = 0x0006
[ 83.404568] hm2/hm2_5i20.0: UnitString = bps
[ 83.404569] hm2/hm2_5i20.0: NameString = nvrembaudrate
[ 83.404570] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404571] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404571] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404572] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404573] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404574] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404575] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404576] hm2/hm2_5i20.0: ParmAddr = 0x000a
[ 83.404577] hm2/hm2_5i20.0: UnitString = none
[ 83.404578] hm2/hm2_5i20.0: NameString = nvkqp
[ 83.404579] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404580] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404580] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404581] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404582] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404583] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404584] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404585] hm2/hm2_5i20.0: ParmAddr = 0x000e
[ 83.404586] hm2/hm2_5i20.0: UnitString = none
[ 83.404587] hm2/hm2_5i20.0: NameString = nvkqihi
[ 83.404587] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404588] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404589] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404590] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404591] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404592] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404593] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404593] hm2/hm2_5i20.0: ParmAddr = 0x000c
[ 83.404594] hm2/hm2_5i20.0: UnitString = none
[ 83.404595] hm2/hm2_5i20.0: NameString = nvkqilo
[ 83.404596] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404597] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404598] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404599] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404600] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404600] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404601] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404602] hm2/hm2_5i20.0: ParmAddr = 0x0010
[ 83.404603] hm2/hm2_5i20.0: UnitString = none
[ 83.404604] hm2/hm2_5i20.0: NameString = nvkqil
[ 83.404605] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404606] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404607] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404608] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404608] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404609] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404610] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404611] hm2/hm2_5i20.0: ParmAddr = 0x0012
[ 83.404612] hm2/hm2_5i20.0: UnitString = none
[ 83.404613] hm2/hm2_5i20.0: NameString = nvkdp
[ 83.404614] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404615] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404616] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404617] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404617] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404618] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404619] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404620] hm2/hm2_5i20.0: ParmAddr = 0x0016
[ 83.404621] hm2/hm2_5i20.0: UnitString = none
[ 83.404622] hm2/hm2_5i20.0: NameString = nvkdihi
[ 83.404623] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404624] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404625] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404625] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404626] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404627] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404628] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404629] hm2/hm2_5i20.0: ParmAddr = 0x0014
[ 83.404630] hm2/hm2_5i20.0: UnitString = none
[ 83.404631] hm2/hm2_5i20.0: NameString = nvkdilo
[ 83.404632] hm2/hm2_5i20.0: RecordType = 0xa0
[ 83.404632] hm2/hm2_5i20.0: DataLength = 0x10
[ 83.404633] hm2/hm2_5i20.0: DataType = 0x04
[ 83.404634] hm2/hm2_5i20.0: DataDir = 0x80
[ 83.404635] hm2/hm2_5i20.0: ParmMax 0.00
[ 83.404636] hm2/hm2_5i20.0: ParmMin 0.00
[ 83.404637] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 83.404638] hm2/hm2_5i20.0: ParmAddr = 0x0018
[ 83.404639] hm2/hm2_5i20.0: UnitString = none
[ 83.404639] hm2/hm2_5i20.0: NameString = nvkdil
[ 83.404640] hm2/hm2_5i20.0: Modes:
[ 83.404641] hm2/hm2_5i20.0:
[ 83.404642] hm2/hm2_5i20.0: StepGen: 4
[ 83.404643] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 83.404644] hm2/hm2_5i20.0: version: 2
[ 83.404645] hm2/hm2_5i20.0: step_rate_addr: 0x2000
[ 83.404646] hm2/hm2_5i20.0: accumulator_addr: 0x2100
[ 83.404647] hm2/hm2_5i20.0: mode_addr: 0x2200
[ 83.404648] hm2/hm2_5i20.0: dir_setup_time_addr: 0x2300
[ 83.404649] hm2/hm2_5i20.0: dir_hold_time_addr: 0x2400
[ 83.404649] hm2/hm2_5i20.0: pulse_width_addr: 0x2500
[ 83.404650] hm2/hm2_5i20.0: pulse_idle_width_addr: 0x2600
[ 83.404651] hm2/hm2_5i20.0: table_sequence_data_setup_addr: 0x2700
[ 83.404652] hm2/hm2_5i20.0: table_sequence_length_addr: 0x2800
[ 83.404653] hm2/hm2_5i20.0: master_dds_addr: 0x2900
[ 83.404654] hm2/hm2_5i20.0: instance 0:
[ 83.404655] hm2/hm2_5i20.0: enable = 0
[ 83.404655] hm2/hm2_5i20.0: hw:
[ 83.404656] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 83.404657] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 83.404658] hm2/hm2_5i20.0: mode = 0x00000000
[ 83.404659] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 83.404660] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 83.404661] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 83.404662] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 83.404663] hm2/hm2_5i20.0: instance 1:
[ 83.404664] hm2/hm2_5i20.0: enable = 0
[ 83.404664] hm2/hm2_5i20.0: hw:
[ 83.404665] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 83.404666] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 83.404667] hm2/hm2_5i20.0: mode = 0x00000000
[ 83.404668] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 83.404669] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 83.404670] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 83.404671] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 83.404672] hm2/hm2_5i20.0: instance 2:
[ 83.404673] hm2/hm2_5i20.0: enable = 0
[ 83.404673] hm2/hm2_5i20.0: hw:
[ 83.404674] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 83.404675] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 83.404676] hm2/hm2_5i20.0: mode = 0x00000000
[ 83.404677] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 83.404678] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 83.404679] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 83.404680] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 83.404681] hm2/hm2_5i20.0: instance 3:
[ 83.404682] hm2/hm2_5i20.0: enable = 0
[ 83.404683] hm2/hm2_5i20.0: hw:
[ 83.404683] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 83.404684] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 83.404685] hm2/hm2_5i20.0: mode = 0x00000000
[ 83.404686] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 83.404687] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 83.404688] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 83.404689] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 83.404690] hm2/hm2_5i20.0: IO Ports: 3
[ 83.404692] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 83.404693] hm2/hm2_5i20.0: version: 0
[ 83.404694] hm2/hm2_5i20.0: data_addr: 0x1000
[ 83.404695] hm2/hm2_5i20.0: ddr_addr: 0x1100
[ 83.404695] hm2/hm2_5i20.0: alt_source_addr: 0x1200
[ 83.404696] hm2/hm2_5i20.0: open_drain_addr: 0x1300
[ 83.404697] hm2/hm2_5i20.0: output_invert_addr: 0x1400
[ 83.404698] hm2/hm2_5i20.0: instance 0:
[ 83.404699] hm2/hm2_5i20.0: data_read = 0xFF434F
[ 83.404700] hm2/hm2_5i20.0: data_write = 0x000000
[ 83.404701] hm2/hm2_5i20.0: ddr = 0x200000
[ 83.404702] hm2/hm2_5i20.0: alt_source = 0x2F415F
[ 83.404703] hm2/hm2_5i20.0: open_drain = 0x000000
[ 83.404704] hm2/hm2_5i20.0: output_invert = 0x000000
[ 83.404704] hm2/hm2_5i20.0: instance 1:
[ 83.404705] hm2/hm2_5i20.0: data_read = 0xFFDF7F
[ 83.404706] hm2/hm2_5i20.0: data_write = 0x000000
[ 83.404707] hm2/hm2_5i20.0: ddr = 0x000000
[ 83.404708] hm2/hm2_5i20.0: alt_source = 0x000000
[ 83.404709] hm2/hm2_5i20.0: open_drain = 0x000000
[ 83.404710] hm2/hm2_5i20.0: output_invert = 0x000000
[ 83.404710] hm2/hm2_5i20.0: instance 2:
[ 83.404711] hm2/hm2_5i20.0: data_read = 0xFFFFFF
[ 83.404712] hm2/hm2_5i20.0: data_write = 0x000000
[ 83.404713] hm2/hm2_5i20.0: ddr = 0x000000
[ 83.404714] hm2/hm2_5i20.0: alt_source = 0x000000
[ 83.404715] hm2/hm2_5i20.0: open_drain = 0x000000
[ 83.404716] hm2/hm2_5i20.0: output_invert = 0x000000
[ 83.404717] hm2/hm2_5i20.0: Watchdog: 1
[ 83.404719] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 83.404720] hm2/hm2_5i20.0: version: 0
[ 83.404721] hm2/hm2_5i20.0: timer_addr: 0x0C00
[ 83.404722] hm2/hm2_5i20.0: status_addr: 0x0D00
[ 83.404722] hm2/hm2_5i20.0: reset_addr: 0x0E00
[ 83.404723] hm2/hm2_5i20.0: instance 0:
[ 83.404724] hm2/hm2_5i20.0: param timeout_ns = 5000000
[ 83.404725] hm2/hm2_5i20.0: pin has_bit = 0
[ 83.404726] hm2/hm2_5i20.0: reg timer = 0x80000000
[ 83.404796] hm2/hm2_5i20.0: registered
[ 83.404798] hm2_5i20.0: initialized AnyIO board at 0000:04:01.0
[ 228.051498] hm2_5i20.0: dropping AnyIO board at 0000:04:01.0
[ 228.051503] hm2/hm2_5i20.0: unregistered
[ 228.052198] hm2_pci: driver unloaded
[ 228.067510] hm2: unloading
[ 230.219540] RTAI[math]: unloaded.
[ 230.272957] SCHED releases registered named ALIEN PEDV$D
[ 230.287350] RTAI[malloc]: unloaded.
[ 230.392940] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 230.411607] I-pipe: head domain RTAI unregistered.
[ 230.411615] RTAI[hal]: unmounted.
[ 255.380560] I-pipe: head domain RTAI registered.
[ 255.380563] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[ 255.380566] SYSINFO - # CPUs: 2, TIMER NAME: 'lapic', TIMER IRQ: 4355, TIMER FREQ: 12499299, CLOCK NAME: 'tsc', CLOCK FREQ: 2999928000, CPU FREQ: 2999928000, LINUX TIMER IRQ: 4355.
[ 255.385846] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 255.385868] kstacks pool size = 524288 bytes
[ 255.385869] RTAI[sched]: hard timer type/freq = lapic/12499299(Hz)
[ 255.385870] linear timed lists.
[ 255.385871] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2999928000 hz.
[ 255.385872] RTAI[sched]: timer setup = 80 ns, resched latency = 0 ns.
[ 255.401458] USERMODE CHECK: OK.
[ 255.401461] USERMODE CHECK PROVIDED (ns): KernelLatency 2577, UserLatency 2781.
[ 255.401462] FINAL CALIBRATION SUMMARY (ns): KernelLatency 2577, UserLatency 2781.
[ 255.411857] RTAI[math]: loaded, using musl libm.
[ 255.455459] hm2: loading Mesa HostMot2 driver version 0.15
[ 255.458394] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 255.458509] hm2_pci: discovered 5i20 at 0000:04:01.0
[ 255.589953] hm2/hm2_5i20.0: Low Level init 0.15
[ 255.589977] hm2/hm2_5i20.0: IDRom:
[ 255.589979] hm2/hm2_5i20.0: IDRom Type: 0x00000003
[ 255.589980] hm2/hm2_5i20.0: Offset to Modules: 0x00000040
[ 255.589981] hm2/hm2_5i20.0: Offset to Pin Description: 0x000001C0
[ 255.589982] hm2/hm2_5i20.0: Board Name: MESA5I20
[ 255.589983] hm2/hm2_5i20.0: FPGA Size: 200
[ 255.589983] hm2/hm2_5i20.0: FPGA Pins: 208
[ 255.589984] hm2/hm2_5i20.0: Port Width: 24
[ 255.589985] hm2/hm2_5i20.0: IO Ports: 3
[ 255.589986] hm2/hm2_5i20.0: IO Width: 72
[ 255.589987] hm2/hm2_5i20.0: Clock Low: 33333333 Hz (33333 KHz, 33 MHz)
[ 255.589988] hm2/hm2_5i20.0: Clock High: 100000000 Hz (100000 KHz, 100 MHz)
[ 255.589989] hm2/hm2_5i20.0: Instance Stride 0: 0x00000004
[ 255.589990] hm2/hm2_5i20.0: Instance Stride 1: 0x00000040
[ 255.589991] hm2/hm2_5i20.0: Register Stride 0: 0x00000100
[ 255.589992] hm2/hm2_5i20.0: Register Stride 1: 0x00000100
[ 255.590069] hm2/hm2_5i20.0: 72 HM2 Pin Descriptors:
[ 255.590070] hm2/hm2_5i20.0: pin 0:
[ 255.590072] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590073] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 255.590074] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 255.590075] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 255.590076] hm2/hm2_5i20.0: pin 1:
[ 255.590077] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590078] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 255.590079] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 255.590080] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 255.590080] hm2/hm2_5i20.0: pin 2:
[ 255.590081] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590082] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 255.590083] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 255.590084] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 255.590085] hm2/hm2_5i20.0: pin 3:
[ 255.590086] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590087] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 255.590088] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 255.590089] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 255.590089] hm2/hm2_5i20.0: pin 4:
[ 255.590090] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590091] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 255.590092] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 255.590093] hm2/hm2_5i20.0: Secondary Pin: 0x01 (A, Input)
[ 255.590094] hm2/hm2_5i20.0: pin 5:
[ 255.590095] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590096] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 255.590097] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 255.590098] hm2/hm2_5i20.0: Secondary Pin: 0x01 (A, Input)
[ 255.590098] hm2/hm2_5i20.0: pin 6:
[ 255.590099] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590100] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 255.590101] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 255.590102] hm2/hm2_5i20.0: Secondary Pin: 0x02 (B, Input)
[ 255.590103] hm2/hm2_5i20.0: pin 7:
[ 255.590104] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590105] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 255.590106] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 255.590107] hm2/hm2_5i20.0: Secondary Pin: 0x02 (B, Input)
[ 255.590107] hm2/hm2_5i20.0: pin 8:
[ 255.590108] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590109] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 255.590110] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 255.590111] hm2/hm2_5i20.0: Secondary Pin: 0x03 (Index, Input)
[ 255.590112] hm2/hm2_5i20.0: pin 9:
[ 255.590113] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590113] hm2/hm2_5i20.0: Secondary Tag: 0x04 (Encoder)
[ 255.590114] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 255.590115] hm2/hm2_5i20.0: Secondary Pin: 0x03 (Index, Input)
[ 255.590116] hm2/hm2_5i20.0: pin 10:
[ 255.590117] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590118] hm2/hm2_5i20.0: pin 11:
[ 255.590119] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590120] hm2/hm2_5i20.0: pin 12:
[ 255.590120] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590121] hm2/hm2_5i20.0: pin 13:
[ 255.590122] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590123] hm2/hm2_5i20.0: pin 14:
[ 255.590124] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590125] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 255.590126] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 255.590127] hm2/hm2_5i20.0: Secondary Pin: 0x01 (rx0, Input)
[ 255.590128] hm2/hm2_5i20.0: pin 15:
[ 255.590129] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590130] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 255.590131] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 255.590132] hm2/hm2_5i20.0: Secondary Pin: 0x02 (rx1, Input)
[ 255.590132] hm2/hm2_5i20.0: pin 16:
[ 255.590133] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590134] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 255.590135] hm2/hm2_5i20.0: Secondary Unit: 0x02
[ 255.590136] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 255.590137] hm2/hm2_5i20.0: pin 17:
[ 255.590138] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590139] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 255.590140] hm2/hm2_5i20.0: Secondary Unit: 0x02
[ 255.590141] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 255.590141] hm2/hm2_5i20.0: pin 18:
[ 255.590142] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590143] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 255.590144] hm2/hm2_5i20.0: Secondary Unit: 0x03
[ 255.590145] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Step, Output)
[ 255.590146] hm2/hm2_5i20.0: pin 19:
[ 255.590147] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590148] hm2/hm2_5i20.0: Secondary Tag: 0x05 (StepGen)
[ 255.590149] hm2/hm2_5i20.0: Secondary Unit: 0x03
[ 255.590150] hm2/hm2_5i20.0: Secondary Pin: 0x82 (Direction, Output)
[ 255.590151] hm2/hm2_5i20.0: pin 20:
[ 255.590151] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590152] hm2/hm2_5i20.0: Secondary Tag: 0x06 (PWMGen)
[ 255.590153] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 255.590154] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Out0 (PWM or Up), Output)
[ 255.590155] hm2/hm2_5i20.0: pin 21:
[ 255.590156] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590157] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 255.590158] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 255.590159] hm2/hm2_5i20.0: Secondary Pin: 0x81 (tx0, Output)
[ 255.590160] hm2/hm2_5i20.0: pin 22:
[ 255.590161] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590162] hm2/hm2_5i20.0: Secondary Tag: 0x06 (PWMGen)
[ 255.590163] hm2/hm2_5i20.0: Secondary Unit: 0x01
[ 255.590164] hm2/hm2_5i20.0: Secondary Pin: 0x81 (Out0 (PWM or Up), Output)
[ 255.590165] hm2/hm2_5i20.0: pin 23:
[ 255.590166] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590167] hm2/hm2_5i20.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 255.590168] hm2/hm2_5i20.0: Secondary Unit: 0x00
[ 255.590169] hm2/hm2_5i20.0: Secondary Pin: 0x82 (tx1, Output)
[ 255.590169] hm2/hm2_5i20.0: pin 24:
[ 255.590170] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590171] hm2/hm2_5i20.0: pin 25:
[ 255.590172] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590173] hm2/hm2_5i20.0: pin 26:
[ 255.590174] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590174] hm2/hm2_5i20.0: pin 27:
[ 255.590175] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590176] hm2/hm2_5i20.0: pin 28:
[ 255.590177] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590178] hm2/hm2_5i20.0: pin 29:
[ 255.590179] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590179] hm2/hm2_5i20.0: pin 30:
[ 255.590180] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590181] hm2/hm2_5i20.0: pin 31:
[ 255.590182] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590183] hm2/hm2_5i20.0: pin 32:
[ 255.590184] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590185] hm2/hm2_5i20.0: pin 33:
[ 255.590185] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590186] hm2/hm2_5i20.0: pin 34:
[ 255.590187] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590188] hm2/hm2_5i20.0: pin 35:
[ 255.590189] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590190] hm2/hm2_5i20.0: pin 36:
[ 255.590190] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590191] hm2/hm2_5i20.0: pin 37:
[ 255.590192] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590193] hm2/hm2_5i20.0: pin 38:
[ 255.590194] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590195] hm2/hm2_5i20.0: pin 39:
[ 255.590195] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590196] hm2/hm2_5i20.0: pin 40:
[ 255.590197] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590198] hm2/hm2_5i20.0: pin 41:
[ 255.590199] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590200] hm2/hm2_5i20.0: pin 42:
[ 255.590201] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590201] hm2/hm2_5i20.0: pin 43:
[ 255.590202] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590203] hm2/hm2_5i20.0: pin 44:
[ 255.590204] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590205] hm2/hm2_5i20.0: pin 45:
[ 255.590206] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590206] hm2/hm2_5i20.0: pin 46:
[ 255.590207] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590208] hm2/hm2_5i20.0: pin 47:
[ 255.590209] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590210] hm2/hm2_5i20.0: pin 48:
[ 255.590211] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590211] hm2/hm2_5i20.0: pin 49:
[ 255.590212] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590213] hm2/hm2_5i20.0: pin 50:
[ 255.590214] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590215] hm2/hm2_5i20.0: pin 51:
[ 255.590216] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590216] hm2/hm2_5i20.0: pin 52:
[ 255.590217] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590218] hm2/hm2_5i20.0: pin 53:
[ 255.590219] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590220] hm2/hm2_5i20.0: pin 54:
[ 255.590221] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590221] hm2/hm2_5i20.0: pin 55:
[ 255.590222] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590223] hm2/hm2_5i20.0: pin 56:
[ 255.590224] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590225] hm2/hm2_5i20.0: pin 57:
[ 255.590226] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590226] hm2/hm2_5i20.0: pin 58:
[ 255.590227] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590228] hm2/hm2_5i20.0: pin 59:
[ 255.590229] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590230] hm2/hm2_5i20.0: pin 60:
[ 255.590231] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590232] hm2/hm2_5i20.0: pin 61:
[ 255.590232] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590233] hm2/hm2_5i20.0: pin 62:
[ 255.590234] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590235] hm2/hm2_5i20.0: pin 63:
[ 255.590236] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590237] hm2/hm2_5i20.0: pin 64:
[ 255.590237] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590238] hm2/hm2_5i20.0: pin 65:
[ 255.590239] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590240] hm2/hm2_5i20.0: pin 66:
[ 255.590241] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590242] hm2/hm2_5i20.0: pin 67:
[ 255.590242] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590243] hm2/hm2_5i20.0: pin 68:
[ 255.590244] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590245] hm2/hm2_5i20.0: pin 69:
[ 255.590246] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590247] hm2/hm2_5i20.0: pin 70:
[ 255.590247] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590248] hm2/hm2_5i20.0: pin 71:
[ 255.590249] hm2/hm2_5i20.0: Primary Tag: 0x03 (IOPort)
[ 255.590253] hm2/hm2_5i20.0: Module Descriptor 0 at 0x0440:
[ 255.590254] hm2/hm2_5i20.0: General Function Tag: 2 (Watchdog)
[ 255.590255] hm2/hm2_5i20.0: Version: 0
[ 255.590257] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 255.590258] hm2/hm2_5i20.0: Instances: 1
[ 255.590259] hm2/hm2_5i20.0: Base Address: 0x0C00
[ 255.590260] hm2/hm2_5i20.0: -- Num Registers: 3
[ 255.590261] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 255.590262] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 255.590263] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000000
[ 255.590267] hm2/hm2_5i20.0: Module Descriptor 1 at 0x044C:
[ 255.590268] hm2/hm2_5i20.0: General Function Tag: 3 (IOPort)
[ 255.590269] hm2/hm2_5i20.0: Version: 0
[ 255.590270] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 255.590271] hm2/hm2_5i20.0: Instances: 3
[ 255.590272] hm2/hm2_5i20.0: Base Address: 0x1000
[ 255.590272] hm2/hm2_5i20.0: -- Num Registers: 5
[ 255.590273] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 255.590274] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 255.590275] hm2/hm2_5i20.0: -- Multiple Registers: 0x0000001F
[ 255.590279] hm2/hm2_5i20.0: Module Descriptor 2 at 0x0458:
[ 255.590280] hm2/hm2_5i20.0: General Function Tag: 4 (Encoder)
[ 255.590281] hm2/hm2_5i20.0: Version: 2
[ 255.590282] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 255.590283] hm2/hm2_5i20.0: Instances: 2
[ 255.590284] hm2/hm2_5i20.0: Base Address: 0x3000
[ 255.590285] hm2/hm2_5i20.0: -- Num Registers: 5
[ 255.590286] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 255.590286] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 255.590287] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000003
[ 255.590291] hm2/hm2_5i20.0: Module Descriptor 3 at 0x0464:
[ 255.590292] hm2/hm2_5i20.0: General Function Tag: 6 (PWMGen)
[ 255.590293] hm2/hm2_5i20.0: Version: 0
[ 255.590295] hm2/hm2_5i20.0: Clock Tag: 2 (100.000 MHz)
[ 255.590295] hm2/hm2_5i20.0: Instances: 2
[ 255.590296] hm2/hm2_5i20.0: Base Address: 0x4000
[ 255.590297] hm2/hm2_5i20.0: -- Num Registers: 5
[ 255.590298] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 255.590299] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 255.590300] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000003
[ 255.590304] hm2/hm2_5i20.0: Module Descriptor 4 at 0x0470:
[ 255.590305] hm2/hm2_5i20.0: General Function Tag: 5 (StepGen)
[ 255.590306] hm2/hm2_5i20.0: Version: 2
[ 255.590307] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 255.590308] hm2/hm2_5i20.0: Instances: 4
[ 255.590308] hm2/hm2_5i20.0: Base Address: 0x2000
[ 255.590309] hm2/hm2_5i20.0: -- Num Registers: 10
[ 255.590310] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 255.590311] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 255.590312] hm2/hm2_5i20.0: -- Multiple Registers: 0x000001FF
[ 255.590316] hm2/hm2_5i20.0: Module Descriptor 5 at 0x047C:
[ 255.590317] hm2/hm2_5i20.0: General Function Tag: 193 (Smart Serial Interface)
[ 255.590318] hm2/hm2_5i20.0: Version: 0
[ 255.590319] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 255.590320] hm2/hm2_5i20.0: Instances: 1
[ 255.590321] hm2/hm2_5i20.0: Base Address: 0x5A00
[ 255.590322] hm2/hm2_5i20.0: -- Num Registers: 6
[ 255.590322] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 255.590323] hm2/hm2_5i20.0: -- Instance Stride: 0x00000040
[ 255.590324] hm2/hm2_5i20.0: -- Multiple Registers: 0x0000003C
[ 255.590328] hm2/hm2_5i20.0: Module Descriptor 6 at 0x0488:
[ 255.590329] hm2/hm2_5i20.0: General Function Tag: 128 (LED)
[ 255.590330] hm2/hm2_5i20.0: Version: 0
[ 255.590331] hm2/hm2_5i20.0: Clock Tag: 1 (33.333 MHz)
[ 255.590332] hm2/hm2_5i20.0: Instances: 1
[ 255.590333] hm2/hm2_5i20.0: Base Address: 0x0200
[ 255.590334] hm2/hm2_5i20.0: -- Num Registers: 1
[ 255.590335] hm2/hm2_5i20.0: Register Stride: 0x00000100
[ 255.590336] hm2/hm2_5i20.0: -- Instance Stride: 0x00000004
[ 255.590337] hm2/hm2_5i20.0: -- Multiple Registers: 0x00000000
[ 255.590719] hm2/hm2_5i20.0: Smart Serial Firmware Version 31
[ 255.600041] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 255.600044] hm2/hm2_5i20.0: IO Pin 000 (P2-01): StepGen #0, pin Step (Output)
[ 255.600046] hm2/hm2_5i20.0: IO Pin 001 (P2-03): StepGen #0, pin Direction (Output)
[ 255.600047] hm2/hm2_5i20.0: IO Pin 002 (P2-05): StepGen #1, pin Step (Output)
[ 255.600048] hm2/hm2_5i20.0: IO Pin 003 (P2-07): StepGen #1, pin Direction (Output)
[ 255.600050] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Encoder #0, pin A (Input)
[ 255.600051] hm2/hm2_5i20.0: IO Pin 005 (P2-11): IOPort
[ 255.600052] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Encoder #0, pin B (Input)
[ 255.600053] hm2/hm2_5i20.0: IO Pin 007 (P2-15): IOPort
[ 255.600055] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Encoder #0, pin Index (Input)
[ 255.600056] hm2/hm2_5i20.0: IO Pin 009 (P2-19): IOPort
[ 255.600057] hm2/hm2_5i20.0: IO Pin 010 (P2-21): IOPort
[ 255.600058] hm2/hm2_5i20.0: IO Pin 011 (P2-23): IOPort
[ 255.600059] hm2/hm2_5i20.0: IO Pin 012 (P2-25): IOPort
[ 255.600060] hm2/hm2_5i20.0: IO Pin 013 (P2-27): IOPort
[ 255.600062] hm2/hm2_5i20.0: IO Pin 014 (P2-29): Smart Serial Interface #0, pin rx0 (Input)
[ 255.600063] hm2/hm2_5i20.0: IO Pin 015 (P2-31): IOPort
[ 255.600064] hm2/hm2_5i20.0: IO Pin 016 (P2-33): StepGen #2, pin Step (Output)
[ 255.600066] hm2/hm2_5i20.0: IO Pin 017 (P2-35): StepGen #2, pin Direction (Output)
[ 255.600067] hm2/hm2_5i20.0: IO Pin 018 (P2-37): StepGen #3, pin Step (Output)
[ 255.600068] hm2/hm2_5i20.0: IO Pin 019 (P2-39): StepGen #3, pin Direction (Output)
[ 255.600069] hm2/hm2_5i20.0: IO Pin 020 (P2-41): IOPort
[ 255.600071] hm2/hm2_5i20.0: IO Pin 021 (P2-43): Smart Serial Interface #0, pin tx0 (Output)
[ 255.600072] hm2/hm2_5i20.0: IO Pin 022 (P2-45): IOPort
[ 255.600073] hm2/hm2_5i20.0: IO Pin 023 (P2-47): IOPort
[ 255.600074] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 255.600076] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 255.600077] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 255.600078] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 255.600079] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 255.600080] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 255.600081] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 255.600082] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 255.600083] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 255.600084] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 255.600085] hm2/hm2_5i20.0: IO Pin 034 (P3-21): IOPort
[ 255.600086] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 255.600087] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 255.600089] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 255.600090] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 255.600091] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 255.600092] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 255.600093] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 255.600094] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 255.600095] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 255.600096] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 255.600098] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 255.600099] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 255.600100] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 255.600101] hm2/hm2_5i20.0: IO Pin 048 (P4-01): IOPort
[ 255.600102] hm2/hm2_5i20.0: IO Pin 049 (P4-03): IOPort
[ 255.600103] hm2/hm2_5i20.0: IO Pin 050 (P4-05): IOPort
[ 255.600104] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 255.600105] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 255.600106] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 255.600108] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 255.600109] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 255.600110] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 255.600111] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 255.600112] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 255.600113] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 255.600114] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 255.600115] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 255.600116] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 255.600117] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 255.600118] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 255.600120] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 255.600121] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 255.600122] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 255.600123] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 255.600124] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 255.600125] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 255.600127] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 255.600127] hm2/hm2_5i20.0: HM2 Modules used:
[ 255.600128] hm2/hm2_5i20.0: Encoders: 1
[ 255.600130] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 255.600131] hm2/hm2_5i20.0: version: 2
[ 255.600132] hm2/hm2_5i20.0: counter_addr: 0x3000
[ 255.600133] hm2/hm2_5i20.0: latch_control_addr: 0x3100
[ 255.600134] hm2/hm2_5i20.0: timestamp_div_addr: 0x3200
[ 255.600135] hm2/hm2_5i20.0: timestamp_count_addr: 0x3300
[ 255.600135] hm2/hm2_5i20.0: filter_rate_addr: 0x3400
[ 255.600136] hm2/hm2_5i20.0: timestamp_div: 0x0000
[ 255.600137] hm2/hm2_5i20.0: instance 0:
[ 255.600138] hm2/hm2_5i20.0: hw:
[ 255.600139] hm2/hm2_5i20.0: counter = 0003.ffff
[ 255.600140] hm2/hm2_5i20.0: latch/control = 0000.0800
[ 255.600141] hm2/hm2_5i20.0: prev_control = 0000.0800
[ 255.600143] hm2/hm2_5i20.0: SSerial: 1
[ 255.600144] hm2/hm2_5i20.0: version 31
[ 255.600144] hm2/hm2_5i20.0: instance 0:
[ 255.600146] hm2/hm2_5i20.0: Command Addr 0x5a00
[ 255.600146] hm2/hm2_5i20.0: Data Addr 0x5b00
[ 255.600147] hm2/hm2_5i20.0: port 0 device hm2_5i20.0.8i20.0.0
[ 255.600148] hm2/hm2_5i20.0: Parameters:
[ 255.600149] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600150] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600151] hm2/hm2_5i20.0: DataType = 0x02
[ 255.600152] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600153] hm2/hm2_5i20.0: ParmMax 1.00
[ 255.600154] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600155] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600156] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600157] hm2/hm2_5i20.0: UnitString = degrees
[ 255.600158] hm2/hm2_5i20.0: NameString = angle
[ 255.600159] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600160] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600161] hm2/hm2_5i20.0: DataType = 0x03
[ 255.600162] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600163] hm2/hm2_5i20.0: ParmMax 30.00
[ 255.600164] hm2/hm2_5i20.0: ParmMin -30.00
[ 255.600164] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600165] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600166] hm2/hm2_5i20.0: UnitString = amps
[ 255.600167] hm2/hm2_5i20.0: NameString = current
[ 255.600168] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600169] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600170] hm2/hm2_5i20.0: DataType = 0x02
[ 255.600171] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600172] hm2/hm2_5i20.0: ParmMax 65535.00
[ 255.600173] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600174] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600174] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600175] hm2/hm2_5i20.0: UnitString = Deg C
[ 255.600176] hm2/hm2_5i20.0: NameString = card-temp
[ 255.600177] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600178] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600179] hm2/hm2_5i20.0: DataType = 0x02
[ 255.600180] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600181] hm2/hm2_5i20.0: ParmMax 655.34
[ 255.600182] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600183] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600184] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600185] hm2/hm2_5i20.0: UnitString = volts
[ 255.600186] hm2/hm2_5i20.0: NameString = bus-voltage
[ 255.600187] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600188] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600189] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600190] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600191] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600192] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600193] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600194] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600195] hm2/hm2_5i20.0: UnitString = none
[ 255.600196] hm2/hm2_5i20.0: NameString = status.current-lim
[ 255.600197] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600198] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600198] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600199] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600200] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600201] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600202] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600203] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600204] hm2/hm2_5i20.0: UnitString = none
[ 255.600205] hm2/hm2_5i20.0: NameString = status.brake-on
[ 255.600206] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600207] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600207] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600208] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600209] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600210] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600212] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600212] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600213] hm2/hm2_5i20.0: UnitString = none
[ 255.600214] hm2/hm2_5i20.0: NameString = status.brake-old
[ 255.600215] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600216] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600217] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600218] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600219] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600220] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600221] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600222] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600223] hm2/hm2_5i20.0: UnitString = none
[ 255.600224] hm2/hm2_5i20.0: NameString = status.bus-underv
[ 255.600225] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600225] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600226] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600227] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600228] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600229] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600230] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600231] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600232] hm2/hm2_5i20.0: UnitString = none
[ 255.600233] hm2/hm2_5i20.0: NameString = status.wd-reset
[ 255.600234] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600234] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600235] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600236] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600237] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600238] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600239] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600240] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600241] hm2/hm2_5i20.0: UnitString = none
[ 255.600242] hm2/hm2_5i20.0: NameString = status.sw-reset
[ 255.600243] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600244] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600245] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600246] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600247] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600248] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600249] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600249] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600250] hm2/hm2_5i20.0: UnitString = none
[ 255.600251] hm2/hm2_5i20.0: NameString = status.ext-reset
[ 255.600252] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600253] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600254] hm2/hm2_5i20.0: DataType = 0x00
[ 255.600255] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600256] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600257] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600258] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600259] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600259] hm2/hm2_5i20.0: UnitString = pad
[ 255.600260] hm2/hm2_5i20.0: NameString = pad
[ 255.600261] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600262] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600263] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600264] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600265] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600266] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600267] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600268] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600269] hm2/hm2_5i20.0: UnitString = none
[ 255.600270] hm2/hm2_5i20.0: NameString = status.no-enable
[ 255.600271] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600272] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600273] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600274] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600275] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600276] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600277] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600277] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600278] hm2/hm2_5i20.0: UnitString = none
[ 255.600279] hm2/hm2_5i20.0: NameString = status.pid-on
[ 255.600280] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600281] hm2/hm2_5i20.0: DataLength = 0x06
[ 255.600282] hm2/hm2_5i20.0: DataType = 0x00
[ 255.600283] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600284] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600285] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600286] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600287] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600288] hm2/hm2_5i20.0: UnitString = pad
[ 255.600288] hm2/hm2_5i20.0: NameString = pad
[ 255.600289] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600290] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600291] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600292] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600293] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600294] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600295] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600296] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600297] hm2/hm2_5i20.0: UnitString = none
[ 255.600298] hm2/hm2_5i20.0: NameString = fault.watchdog
[ 255.600299] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600300] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600301] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600302] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600303] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600304] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600305] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600306] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600306] hm2/hm2_5i20.0: UnitString = none
[ 255.600307] hm2/hm2_5i20.0: NameString = fault.no-enable
[ 255.600308] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600309] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600310] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600311] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600312] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600313] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600314] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600315] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600315] hm2/hm2_5i20.0: UnitString = none
[ 255.600316] hm2/hm2_5i20.0: NameString = fault.overtemp
[ 255.600317] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600318] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600319] hm2/hm2_5i20.0: DataType = 0x00
[ 255.600320] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600321] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600322] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600323] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600324] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600325] hm2/hm2_5i20.0: UnitString = pad
[ 255.600326] hm2/hm2_5i20.0: NameString = pad
[ 255.600327] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600328] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600329] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600329] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600330] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600331] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600332] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600333] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600334] hm2/hm2_5i20.0: UnitString = none
[ 255.600335] hm2/hm2_5i20.0: NameString = fault.overcurrent
[ 255.600336] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600337] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600338] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600339] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600340] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600340] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600341] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600342] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600343] hm2/hm2_5i20.0: UnitString = none
[ 255.600344] hm2/hm2_5i20.0: NameString = fault.U-current
[ 255.600345] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600346] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600347] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600348] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600349] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600349] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600350] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600351] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600352] hm2/hm2_5i20.0: UnitString = none
[ 255.600353] hm2/hm2_5i20.0: NameString = fault.V-current
[ 255.600355] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600356] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600356] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600357] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600358] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600359] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600360] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600361] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600362] hm2/hm2_5i20.0: UnitString = none
[ 255.600363] hm2/hm2_5i20.0: NameString = fault.W-current
[ 255.600364] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600365] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600365] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600366] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600367] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600368] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600369] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600370] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600371] hm2/hm2_5i20.0: UnitString = none
[ 255.600372] hm2/hm2_5i20.0: NameString = fault.bus-underv
[ 255.600373] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600374] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600374] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600375] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600376] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600377] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600378] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600379] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600380] hm2/hm2_5i20.0: UnitString = none
[ 255.600381] hm2/hm2_5i20.0: NameString = fault.bus-high
[ 255.600382] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600383] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600384] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600385] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600386] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600387] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600388] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600389] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600390] hm2/hm2_5i20.0: UnitString = none
[ 255.600390] hm2/hm2_5i20.0: NameString = fault.bus-overv
[ 255.600391] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600392] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600393] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600394] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600395] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600396] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600397] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600398] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600399] hm2/hm2_5i20.0: UnitString = none
[ 255.600400] hm2/hm2_5i20.0: NameString = fault.module
[ 255.600401] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600402] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600403] hm2/hm2_5i20.0: DataType = 0x00
[ 255.600403] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600404] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600405] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600406] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600407] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600408] hm2/hm2_5i20.0: UnitString = pad
[ 255.600409] hm2/hm2_5i20.0: NameString = pad
[ 255.600410] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600411] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600412] hm2/hm2_5i20.0: DataType = 0x00
[ 255.600413] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600414] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600415] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600416] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600417] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600418] hm2/hm2_5i20.0: UnitString = pad
[ 255.600419] hm2/hm2_5i20.0: NameString = pad
[ 255.600420] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600421] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600421] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600422] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600423] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600424] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600425] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600426] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600427] hm2/hm2_5i20.0: UnitString = none
[ 255.600428] hm2/hm2_5i20.0: NameString = fault.overrun
[ 255.600429] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600430] hm2/hm2_5i20.0: DataLength = 0x01
[ 255.600431] hm2/hm2_5i20.0: DataType = 0x07
[ 255.600431] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600432] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600433] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600434] hm2/hm2_5i20.0: SizeOf ParmMin 0x04
[ 255.600435] hm2/hm2_5i20.0: ParmAddr = 0x0000
[ 255.600436] hm2/hm2_5i20.0: UnitString = none
[ 255.600437] hm2/hm2_5i20.0: NameString = fault.framingr
[ 255.600438] hm2/hm2_5i20.0: Globals:
[ 255.600439] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600440] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600441] hm2/hm2_5i20.0: DataType = 0x02
[ 255.600442] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600443] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600444] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600445] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600446] hm2/hm2_5i20.0: ParmAddr = 0x0874
[ 255.600447] hm2/hm2_5i20.0: UnitString = none
[ 255.600447] hm2/hm2_5i20.0: NameString = swrevision
[ 255.600448] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600449] hm2/hm2_5i20.0: DataLength = 0x20
[ 255.600450] hm2/hm2_5i20.0: DataType = 0x02
[ 255.600451] hm2/hm2_5i20.0: DataDir = 0x00
[ 255.600452] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600453] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600454] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600455] hm2/hm2_5i20.0: ParmAddr = 0x0928
[ 255.600456] hm2/hm2_5i20.0: UnitString = none
[ 255.600457] hm2/hm2_5i20.0: NameString = unitnumber
[ 255.600458] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600459] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600459] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600460] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600461] hm2/hm2_5i20.0: ParmMax 32.76
[ 255.600462] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600463] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600464] hm2/hm2_5i20.0: ParmAddr = 0x0002
[ 255.600465] hm2/hm2_5i20.0: UnitString = amps
[ 255.600466] hm2/hm2_5i20.0: NameString = nvmaxcurrent
[ 255.600467] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600468] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600468] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600469] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600471] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600472] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600473] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600474] hm2/hm2_5i20.0: ParmAddr = 0x0024
[ 255.600474] hm2/hm2_5i20.0: UnitString = volts
[ 255.600475] hm2/hm2_5i20.0: NameString = nvbusundervmax
[ 255.600476] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600477] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600478] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600479] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600480] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600481] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600482] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600483] hm2/hm2_5i20.0: ParmAddr = 0x0022
[ 255.600484] hm2/hm2_5i20.0: UnitString = volts
[ 255.600485] hm2/hm2_5i20.0: NameString = nvbusundervmin
[ 255.600485] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600486] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600487] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600488] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600489] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600490] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600491] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600492] hm2/hm2_5i20.0: ParmAddr = 0x0026
[ 255.600493] hm2/hm2_5i20.0: UnitString = volts
[ 255.600494] hm2/hm2_5i20.0: NameString = nvbusoverv
[ 255.600494] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600495] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600496] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600497] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600498] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600499] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600500] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600501] hm2/hm2_5i20.0: ParmAddr = 0x0028
[ 255.600502] hm2/hm2_5i20.0: UnitString = volts
[ 255.600503] hm2/hm2_5i20.0: NameString = nvbrakeonv
[ 255.600504] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600505] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600506] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600507] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600508] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600509] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600509] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600510] hm2/hm2_5i20.0: ParmAddr = 0x002a
[ 255.600511] hm2/hm2_5i20.0: UnitString = volts
[ 255.600512] hm2/hm2_5i20.0: NameString = nvbrakeoffv
[ 255.600513] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600514] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600515] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600516] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600517] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600518] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600519] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600520] hm2/hm2_5i20.0: ParmAddr = 0x0006
[ 255.600521] hm2/hm2_5i20.0: UnitString = bps
[ 255.600521] hm2/hm2_5i20.0: NameString = nvrembaudrate
[ 255.600522] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600523] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600524] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600525] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600526] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600527] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600528] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600529] hm2/hm2_5i20.0: ParmAddr = 0x000a
[ 255.600530] hm2/hm2_5i20.0: UnitString = none
[ 255.600531] hm2/hm2_5i20.0: NameString = nvkqp
[ 255.600532] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600533] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600534] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600535] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600536] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600537] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600538] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600538] hm2/hm2_5i20.0: ParmAddr = 0x000e
[ 255.600539] hm2/hm2_5i20.0: UnitString = none
[ 255.600540] hm2/hm2_5i20.0: NameString = nvkqihi
[ 255.600541] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600542] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600543] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600544] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600545] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600546] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600546] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600547] hm2/hm2_5i20.0: ParmAddr = 0x000c
[ 255.600548] hm2/hm2_5i20.0: UnitString = none
[ 255.600549] hm2/hm2_5i20.0: NameString = nvkqilo
[ 255.600550] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600551] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600552] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600553] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600554] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600554] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600555] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600556] hm2/hm2_5i20.0: ParmAddr = 0x0010
[ 255.600558] hm2/hm2_5i20.0: UnitString = none
[ 255.600559] hm2/hm2_5i20.0: NameString = nvkqil
[ 255.600560] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600561] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600561] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600562] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600563] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600564] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600565] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600566] hm2/hm2_5i20.0: ParmAddr = 0x0012
[ 255.600567] hm2/hm2_5i20.0: UnitString = none
[ 255.600568] hm2/hm2_5i20.0: NameString = nvkdp
[ 255.600569] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600570] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600571] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600572] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600573] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600573] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600574] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600575] hm2/hm2_5i20.0: ParmAddr = 0x0016
[ 255.600576] hm2/hm2_5i20.0: UnitString = none
[ 255.600577] hm2/hm2_5i20.0: NameString = nvkdihi
[ 255.600578] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600579] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600580] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600581] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600581] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600582] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600583] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600584] hm2/hm2_5i20.0: ParmAddr = 0x0014
[ 255.600585] hm2/hm2_5i20.0: UnitString = none
[ 255.600587] hm2/hm2_5i20.0: NameString = nvkdilo
[ 255.600588] hm2/hm2_5i20.0: RecordType = 0xa0
[ 255.600588] hm2/hm2_5i20.0: DataLength = 0x10
[ 255.600589] hm2/hm2_5i20.0: DataType = 0x04
[ 255.600590] hm2/hm2_5i20.0: DataDir = 0x80
[ 255.600591] hm2/hm2_5i20.0: ParmMax 0.00
[ 255.600592] hm2/hm2_5i20.0: ParmMin 0.00
[ 255.600593] hm2/hm2_5i20.0: SizeOf ParmMin 4
[ 255.600594] hm2/hm2_5i20.0: ParmAddr = 0x0018
[ 255.600595] hm2/hm2_5i20.0: UnitString = none
[ 255.600596] hm2/hm2_5i20.0: NameString = nvkdil
[ 255.600597] hm2/hm2_5i20.0: Modes:
[ 255.600598] hm2/hm2_5i20.0: StepGen: 4
[ 255.600600] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 255.600601] hm2/hm2_5i20.0: version: 2
[ 255.600601] hm2/hm2_5i20.0: step_rate_addr: 0x2000
[ 255.600602] hm2/hm2_5i20.0: accumulator_addr: 0x2100
[ 255.600603] hm2/hm2_5i20.0: mode_addr: 0x2200
[ 255.600604] hm2/hm2_5i20.0: dir_setup_time_addr: 0x2300
[ 255.600605] hm2/hm2_5i20.0: dir_hold_time_addr: 0x2400
[ 255.600606] hm2/hm2_5i20.0: pulse_width_addr: 0x2500
[ 255.600607] hm2/hm2_5i20.0: pulse_idle_width_addr: 0x2600
[ 255.600608] hm2/hm2_5i20.0: table_sequence_data_setup_addr: 0x2700
[ 255.600609] hm2/hm2_5i20.0: table_sequence_length_addr: 0x2800
[ 255.600609] hm2/hm2_5i20.0: master_dds_addr: 0x2900
[ 255.600610] hm2/hm2_5i20.0: instance 0:
[ 255.600611] hm2/hm2_5i20.0: enable = 0
[ 255.600612] hm2/hm2_5i20.0: hw:
[ 255.600613] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 255.600614] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 255.600615] hm2/hm2_5i20.0: mode = 0x00000000
[ 255.600616] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 255.600617] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 255.600618] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 255.600619] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 255.600620] hm2/hm2_5i20.0: instance 1:
[ 255.600621] hm2/hm2_5i20.0: enable = 0
[ 255.600622] hm2/hm2_5i20.0: hw:
[ 255.600623] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 255.600623] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 255.600624] hm2/hm2_5i20.0: mode = 0x00000000
[ 255.600625] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 255.600626] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 255.600627] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 255.600629] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 255.600629] hm2/hm2_5i20.0: instance 2:
[ 255.600630] hm2/hm2_5i20.0: enable = 0
[ 255.600631] hm2/hm2_5i20.0: hw:
[ 255.600632] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 255.600633] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 255.600634] hm2/hm2_5i20.0: mode = 0x00000000
[ 255.600635] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 255.600636] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 255.600637] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 255.600638] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 255.600639] hm2/hm2_5i20.0: instance 3:
[ 255.600640] hm2/hm2_5i20.0: enable = 0
[ 255.600640] hm2/hm2_5i20.0: hw:
[ 255.600641] hm2/hm2_5i20.0: step_rate = 0x00000000
[ 255.600642] hm2/hm2_5i20.0: accumulator = 0x00000000
[ 255.600644] hm2/hm2_5i20.0: mode = 0x00000000
[ 255.600645] hm2/hm2_5i20.0: dir_setup_time = 0x00003FFE (491490 ns)
[ 255.600646] hm2/hm2_5i20.0: dir_hold_time = 0x00003FFE (491490 ns)
[ 255.600647] hm2/hm2_5i20.0: pulse_width = 0x00003FFE (491490 ns)
[ 255.600648] hm2/hm2_5i20.0: pulse_idle_width = 0x00003FFE (491490 ns)
[ 255.600649] hm2/hm2_5i20.0: IO Ports: 3
[ 255.600650] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 255.600651] hm2/hm2_5i20.0: version: 0
[ 255.600652] hm2/hm2_5i20.0: data_addr: 0x1000
[ 255.600653] hm2/hm2_5i20.0: ddr_addr: 0x1100
[ 255.600654] hm2/hm2_5i20.0: alt_source_addr: 0x1200
[ 255.600655] hm2/hm2_5i20.0: open_drain_addr: 0x1300
[ 255.600656] hm2/hm2_5i20.0: output_invert_addr: 0x1400
[ 255.600656] hm2/hm2_5i20.0: instance 0:
[ 255.600657] hm2/hm2_5i20.0: data_read = 0xFF434F
[ 255.600658] hm2/hm2_5i20.0: data_write = 0x000000
[ 255.600659] hm2/hm2_5i20.0: ddr = 0x200000
[ 255.600660] hm2/hm2_5i20.0: alt_source = 0x2F415F
[ 255.600661] hm2/hm2_5i20.0: open_drain = 0x000000
[ 255.600662] hm2/hm2_5i20.0: output_invert = 0x000000
[ 255.600663] hm2/hm2_5i20.0: instance 1:
[ 255.600664] hm2/hm2_5i20.0: data_read = 0xFFDF7F
[ 255.600665] hm2/hm2_5i20.0: data_write = 0x000000
[ 255.600666] hm2/hm2_5i20.0: ddr = 0x000000
[ 255.600666] hm2/hm2_5i20.0: alt_source = 0x000000
[ 255.600667] hm2/hm2_5i20.0: open_drain = 0x000000
[ 255.600668] hm2/hm2_5i20.0: output_invert = 0x000000
[ 255.600669] hm2/hm2_5i20.0: instance 2:
[ 255.600670] hm2/hm2_5i20.0: data_read = 0xFFFFFF
[ 255.600671] hm2/hm2_5i20.0: data_write = 0x000000
[ 255.600672] hm2/hm2_5i20.0: ddr = 0x000000
[ 255.600673] hm2/hm2_5i20.0: alt_source = 0x000000
[ 255.600674] hm2/hm2_5i20.0: open_drain = 0x000000
[ 255.600675] hm2/hm2_5i20.0: output_invert = 0x000000
[ 255.600676] hm2/hm2_5i20.0: Watchdog: 1
[ 255.600677] hm2/hm2_5i20.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 255.600678] hm2/hm2_5i20.0: version: 0
[ 255.600679] hm2/hm2_5i20.0: timer_addr: 0x0C00
[ 255.600680] hm2/hm2_5i20.0: status_addr: 0x0D00
[ 255.600681] hm2/hm2_5i20.0: reset_addr: 0x0E00
[ 255.600682] hm2/hm2_5i20.0: instance 0:
[ 255.600683] hm2/hm2_5i20.0: param timeout_ns = 5000000
[ 255.600684] hm2/hm2_5i20.0: pin has_bit = 0
[ 255.600685] hm2/hm2_5i20.0: reg timer = 0x80000000
[ 255.600746] hm2/hm2_5i20.0: registered
[ 255.600748] hm2_5i20.0: initialized AnyIO board at 0000:04:01.0
Last edit: 4 years 1 day ago by andypugh.
Time to create page: 0.164 seconds
