loading LinuxCNC on old smithy 1240
4 years 4 days ago #255326
by LPMattei
Replied by LPMattei on topic loading LinuxCNC on old smithy 1240
That is the way I tried when the initial attempt failed. I am still in the same boat.
4 years 4 days ago #255328
by LPMattei
I can't seem to get that to work, I tried a different setup "smithy 1240 Mill" instead of Smithy 1240 Combined Mill" which is what old SW used. That gets further, actually opens the gui up, but I get a watchdog bit error. I don't know what is different between the 2, but I'm thinking that is the config to use, as i am further along. Any thoughts on this idea?
4 years 4 days ago #255330
Replied by andypugh on topic loading LinuxCNC on old smithy 1240
I think that you should go with the config that used to work.
I am pretty sure that the problem you had last time "1240combined.hal:86: parameter or pin 'hm2_5i20.0.8i20.0.0.max_current' not found" is not the error now.
We need to work through the errors one by one.
I am on the IRC channel if you want something a bit more live,
4 years 4 days ago - 4 years 4 days ago #255334
by LPMattei
Thank you, but at the risk of sounding like a fool, what is IRC channel.
NM, I may be there
NM, I may be there
Last edit: 4 years 4 days ago by LPMattei.
4 years 4 days ago #255343
What does
uname -a
in a terminal say?
Also, in PC's BIOS settings, disable everything regarding power saving, turbo, speed step, C states, hyperthreading, etc.
Replied by tommylight on topic loading LinuxCNC on old smithy 1240
That is a timing issue with the PC, or using the wrong kernel.That gets further, actually opens the gui up, but I get a watchdog bit error.
What does
uname -a
in a terminal say?
4 years 3 days ago - 4 years 3 days ago #255385
by LPMattei
uname -a Linux debian 4.19.195-rtai-amd64 #5 SMP PREEMPT Sun Jul 11 19:13:27 BST 2021 x86_64 GNU/Linux
I also just turned of virtualization in bios. I was working with AndyPugh last night, and we were making some progress, I believe we loaded a new kernel and latency test looks better, but it got late. I'm hoping to hear back from him today, but I'm open to any other ideas in the meantime.
Last edit: 4 years 3 days ago by LPMattei.
Time to create page: 0.064 seconds
