loading LinuxCNC on old smithy 1240
4 years 5 days ago #255246
by LPMattei
Replied by LPMattei on topic loading LinuxCNC on old smithy 1240
I posted them again below in plain text rather than an uploaded file as above
4 years 5 days ago #255261
Replied by andypugh on topic loading LinuxCNC on old smithy 1240
Can you run the following in a terminal window to get a pin list? The point is to see if the 8i20 is being detected:
Paste the output here.
halrun
loadrt hostmot2 debug_idrom=1
loadrt hm2_pci config="firmware=hm2/5i20/sssvst2_2_4_v31.bit"
show pin
4 years 4 days ago - 4 years 4 days ago #255312
by LPMattei
smithy@debian:~$ halrun
halcmd: loadrt hostmot2 debug_idrom=1
Note: Using POSIX realtime
halcmd: loadrt hm2_pci config="firmware=hm2/5i20/sssvst2_2_4_v31.bit"
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i20 at 0000:04:01.0
hm2/hm2_5i20.0: Low Level init 0.15
hm2/hm2_5i20.0: IDRom:
hm2/hm2_5i20.0: IDRom Type: 0x00000003
hm2/hm2_5i20.0: Offset to Modules: 0x00000040
hm2/hm2_5i20.0: Offset to Pin Description: 0x000001C0
hm2/hm2_5i20.0: Board Name: MESA5I20
hm2/hm2_5i20.0: FPGA Size: 200
hm2/hm2_5i20.0: FPGA Pins: 208
hm2/hm2_5i20.0: Port Width: 24
hm2/hm2_5i20.0: IO Ports: 3
hm2/hm2_5i20.0: IO Width: 72
hm2/hm2_5i20.0: Clock Low: 33333333 Hz (33333 KHz, 33 MHz)
hm2/hm2_5i20.0: Clock High: 100000000 Hz (100000 KHz, 100 MHz)
hm2/hm2_5i20.0: Instance Stride 0: 0x00000004
hm2/hm2_5i20.0: Instance Stride 1: 0x00000040
hm2/hm2_5i20.0: Register Stride 0: 0x00000100
hm2/hm2_5i20.0: Register Stride 1: 0x00000100
hm2/hm2_5i20.0: Smart Serial Firmware Version 31
hm2/hm2_5i20.0: 72 I/O Pins used:
hm2/hm2_5i20.0: IO Pin 000 (P2-01): StepGen #0, pin Step (Output)
hm2/hm2_5i20.0: IO Pin 001 (P2-03): StepGen #0, pin Direction (Output)
hm2/hm2_5i20.0: IO Pin 002 (P2-05): StepGen #1, pin Step (Output)
hm2/hm2_5i20.0: IO Pin 003 (P2-07): StepGen #1, pin Direction (Output)
hm2/hm2_5i20.0: IO Pin 004 (P2-09): Encoder #0, pin A (Input)
hm2/hm2_5i20.0: IO Pin 005 (P2-11): Encoder #1, pin A (Input)
hm2/hm2_5i20.0: IO Pin 006 (P2-13): Encoder #0, pin B (Input)
hm2/hm2_5i20.0: IO Pin 007 (P2-15): Encoder #1, pin B (Input)
hm2/hm2_5i20.0: IO Pin 008 (P2-17): Encoder #0, pin Index (Input)
hm2/hm2_5i20.0: IO Pin 009 (P2-19): Encoder #1, pin Index (Input)
hm2/hm2_5i20.0: IO Pin 010 (P2-21): IOPort
hm2/hm2_5i20.0: IO Pin 011 (P2-23): IOPort
hm2/hm2_5i20.0: IO Pin 012 (P2-25): IOPort
hm2/hm2_5i20.0: IO Pin 013 (P2-27): IOPort
hm2/hm2_5i20.0: IO Pin 014 (P2-29): Smart Serial Interface #0, pin rx0 (Input)
hm2/hm2_5i20.0: IO Pin 015 (P2-31): IOPort
hm2/hm2_5i20.0: IO Pin 016 (P2-33): StepGen #2, pin Step (Output)
hm2/hm2_5i20.0: IO Pin 017 (P2-35): StepGen #2, pin Direction (Output)
hm2/hm2_5i20.0: IO Pin 018 (P2-37): StepGen #3, pin Step (Output)
hm2/hm2_5i20.0: IO Pin 019 (P2-39): StepGen #3, pin Direction (Output)
hm2/hm2_5i20.0: IO Pin 020 (P2-41): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_5i20.0: IO Pin 021 (P2-43): Smart Serial Interface #0, pin tx0 (Output)
hm2/hm2_5i20.0: IO Pin 022 (P2-45): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_5i20.0: IO Pin 023 (P2-47): IOPort
hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
hm2/hm2_5i20.0: IO Pin 034 (P3-21): IOPort
hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
hm2/hm2_5i20.0: IO Pin 048 (P4-01): IOPort
hm2/hm2_5i20.0: IO Pin 049 (P4-03): IOPort
hm2/hm2_5i20.0: IO Pin 050 (P4-05): IOPort
hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
hm2/hm2_5i20.0: registered
hm2_5i20.0: initialized AnyIO board at 0000:04:01.0
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
7 s32 OUT 0 hm2_5i20.0.0.debug
7 float IN 0 hm2_5i20.0.8i20.0.0.angle
7 float OUT 0 hm2_5i20.0.8i20.0.0.bus-voltage
7 float OUT 0 hm2_5i20.0.8i20.0.0.card-temp
7 float IN 0 hm2_5i20.0.8i20.0.0.current
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.U-current
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.U-current-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.V-current
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.V-current-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.W-current
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.W-current-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-high
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-high-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-overv
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-overv-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-underv
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.bus-underv-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.framingr
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.framingr-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.module
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.module-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.no-enable
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.no-enable-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overcurrent
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overcurrent-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overrun
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overrun-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overtemp
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.overtemp-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.watchdog
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.fault.watchdog-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.brake-old
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.brake-old-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.brake-on
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.brake-on-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.bus-underv
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.bus-underv-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.current-lim
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.current-lim-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.ext-reset
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.ext-reset-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.no-enable
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.no-enable-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.pid-on
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.pid-on-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.sw-reset
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.sw-reset-not
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.wd-reset
7 bit OUT FALSE hm2_5i20.0.8i20.0.0.status.wd-reset-not
7 s32 OUT 0 hm2_5i20.0.encoder.00.count
7 s32 OUT 0 hm2_5i20.0.encoder.00.count-latched
7 bit I/O FALSE hm2_5i20.0.encoder.00.index-enable
7 bit OUT FALSE hm2_5i20.0.encoder.00.input-a
7 bit OUT TRUE hm2_5i20.0.encoder.00.input-b
7 bit OUT FALSE hm2_5i20.0.encoder.00.input-index
7 bit IN FALSE hm2_5i20.0.encoder.00.latch-enable
7 bit IN FALSE hm2_5i20.0.encoder.00.latch-polarity
7 float OUT 0 hm2_5i20.0.encoder.00.position
7 float OUT 0 hm2_5i20.0.encoder.00.position-latched
7 bit OUT FALSE hm2_5i20.0.encoder.00.quad-error
7 bit IN FALSE hm2_5i20.0.encoder.00.quad-error-enable
7 s32 OUT 65535 hm2_5i20.0.encoder.00.rawcounts
7 s32 OUT 65535 hm2_5i20.0.encoder.00.rawlatch
7 bit IN FALSE hm2_5i20.0.encoder.00.reset
7 float OUT 0 hm2_5i20.0.encoder.00.velocity
7 float OUT 0 hm2_5i20.0.encoder.00.velocity-rpm
7 s32 OUT 0 hm2_5i20.0.encoder.01.count
7 s32 OUT 0 hm2_5i20.0.encoder.01.count-latched
7 bit I/O FALSE hm2_5i20.0.encoder.01.index-enable
7 bit OUT FALSE hm2_5i20.0.encoder.01.input-a
7 bit OUT FALSE hm2_5i20.0.encoder.01.input-b
7 bit OUT FALSE hm2_5i20.0.encoder.01.input-index
7 bit IN FALSE hm2_5i20.0.encoder.01.latch-enable
7 bit IN FALSE hm2_5i20.0.encoder.01.latch-polarity
7 float OUT 0 hm2_5i20.0.encoder.01.position
7 float OUT 0 hm2_5i20.0.encoder.01.position-latched
7 bit OUT FALSE hm2_5i20.0.encoder.01.quad-error
7 bit IN FALSE hm2_5i20.0.encoder.01.quad-error-enable
7 s32 OUT 0 hm2_5i20.0.encoder.01.rawcounts
7 s32 OUT 0 hm2_5i20.0.encoder.01.rawlatch
7 bit IN FALSE hm2_5i20.0.encoder.01.reset
7 float OUT 0 hm2_5i20.0.encoder.01.velocity
7 float OUT 0 hm2_5i20.0.encoder.01.velocity-rpm
7 bit IN FALSE hm2_5i20.0.encoder.hires-timestamp
7 u32 IN 0x00001FC8 hm2_5i20.0.encoder.sample-frequency
7 bit OUT TRUE hm2_5i20.0.gpio.000.in
7 bit OUT FALSE hm2_5i20.0.gpio.000.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.001.in
7 bit OUT FALSE hm2_5i20.0.gpio.001.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.002.in
7 bit OUT FALSE hm2_5i20.0.gpio.002.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.003.in
7 bit OUT FALSE hm2_5i20.0.gpio.003.in_not
7 bit OUT FALSE hm2_5i20.0.gpio.004.in
7 bit OUT TRUE hm2_5i20.0.gpio.004.in_not
7 bit OUT FALSE hm2_5i20.0.gpio.005.in
7 bit OUT TRUE hm2_5i20.0.gpio.005.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.006.in
7 bit OUT FALSE hm2_5i20.0.gpio.006.in_not
7 bit OUT FALSE hm2_5i20.0.gpio.007.in
7 bit OUT TRUE hm2_5i20.0.gpio.007.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.008.in
7 bit OUT FALSE hm2_5i20.0.gpio.008.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.009.in
7 bit OUT FALSE hm2_5i20.0.gpio.009.in_not
7 bit OUT FALSE hm2_5i20.0.gpio.010.in
7 bit OUT TRUE hm2_5i20.0.gpio.010.in_not
7 bit IN FALSE hm2_5i20.0.gpio.010.out
7 bit OUT FALSE hm2_5i20.0.gpio.011.in
7 bit OUT TRUE hm2_5i20.0.gpio.011.in_not
7 bit IN FALSE hm2_5i20.0.gpio.011.out
7 bit OUT FALSE hm2_5i20.0.gpio.012.in
7 bit OUT TRUE hm2_5i20.0.gpio.012.in_not
7 bit IN FALSE hm2_5i20.0.gpio.012.out
7 bit OUT FALSE hm2_5i20.0.gpio.013.in
7 bit OUT TRUE hm2_5i20.0.gpio.013.in_not
7 bit IN FALSE hm2_5i20.0.gpio.013.out
7 bit OUT TRUE hm2_5i20.0.gpio.014.in
7 bit OUT FALSE hm2_5i20.0.gpio.014.in_not
7 bit OUT FALSE hm2_5i20.0.gpio.015.in
7 bit OUT TRUE hm2_5i20.0.gpio.015.in_not
7 bit IN FALSE hm2_5i20.0.gpio.015.out
7 bit OUT TRUE hm2_5i20.0.gpio.016.in
7 bit OUT FALSE hm2_5i20.0.gpio.016.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.017.in
7 bit OUT FALSE hm2_5i20.0.gpio.017.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.018.in
7 bit OUT FALSE hm2_5i20.0.gpio.018.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.019.in
7 bit OUT FALSE hm2_5i20.0.gpio.019.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.020.in
7 bit OUT FALSE hm2_5i20.0.gpio.020.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.021.in
7 bit OUT FALSE hm2_5i20.0.gpio.021.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.022.in
7 bit OUT FALSE hm2_5i20.0.gpio.022.in_not
7 bit OUT TRUE hm2_5i20.0.gpio.023.in
7 bit OUT FALSE hm2_5i20.0.gpio.023.in_not
7 bit IN FALSE hm2_5i20.0.gpio.023.out
7 bit OUT TRUE hm2_5i20.0.gpio.024.in
7 bit OUT FALSE hm2_5i20.0.gpio.024.in_not
7 bit IN FALSE hm2_5i20.0.gpio.024.out
7 bit OUT TRUE hm2_5i20.0.gpio.025.in
7 bit OUT FALSE hm2_5i20.0.gpio.025.in_not
7 bit IN FALSE hm2_5i20.0.gpio.025.out
7 bit OUT TRUE hm2_5i20.0.gpio.026.in
7 bit OUT FALSE hm2_5i20.0.gpio.026.in_not
7 bit IN FALSE hm2_5i20.0.gpio.026.out
7 bit OUT TRUE hm2_5i20.0.gpio.027.in
7 bit OUT FALSE hm2_5i20.0.gpio.027.in_not
7 bit IN FALSE hm2_5i20.0.gpio.027.out
7 bit OUT TRUE hm2_5i20.0.gpio.028.in
7 bit OUT FALSE hm2_5i20.0.gpio.028.in_not
7 bit IN FALSE hm2_5i20.0.gpio.028.out
7 bit OUT TRUE hm2_5i20.0.gpio.029.in
7 bit OUT FALSE hm2_5i20.0.gpio.029.in_not
7 bit IN FALSE hm2_5i20.0.gpio.029.out
7 bit OUT TRUE hm2_5i20.0.gpio.030.in
7 bit OUT FALSE hm2_5i20.0.gpio.030.in_not
7 bit IN FALSE hm2_5i20.0.gpio.030.out
7 bit OUT FALSE hm2_5i20.0.gpio.031.in
7 bit OUT TRUE hm2_5i20.0.gpio.031.in_not
7 bit IN FALSE hm2_5i20.0.gpio.031.out
7 bit OUT TRUE hm2_5i20.0.gpio.032.in
7 bit OUT FALSE hm2_5i20.0.gpio.032.in_not
7 bit IN FALSE hm2_5i20.0.gpio.032.out
7 bit OUT TRUE hm2_5i20.0.gpio.033.in
7 bit OUT FALSE hm2_5i20.0.gpio.033.in_not
7 bit IN FALSE hm2_5i20.0.gpio.033.out
7 bit OUT TRUE hm2_5i20.0.gpio.034.in
7 bit OUT FALSE hm2_5i20.0.gpio.034.in_not
7 bit IN FALSE hm2_5i20.0.gpio.034.out
7 bit OUT TRUE hm2_5i20.0.gpio.035.in
7 bit OUT FALSE hm2_5i20.0.gpio.035.in_not
7 bit IN FALSE hm2_5i20.0.gpio.035.out
7 bit OUT TRUE hm2_5i20.0.gpio.036.in
7 bit OUT FALSE hm2_5i20.0.gpio.036.in_not
7 bit IN FALSE hm2_5i20.0.gpio.036.out
7 bit OUT FALSE hm2_5i20.0.gpio.037.in
7 bit OUT TRUE hm2_5i20.0.gpio.037.in_not
7 bit IN FALSE hm2_5i20.0.gpio.037.out
7 bit OUT TRUE hm2_5i20.0.gpio.038.in
7 bit OUT FALSE hm2_5i20.0.gpio.038.in_not
7 bit IN FALSE hm2_5i20.0.gpio.038.out
7 bit OUT TRUE hm2_5i20.0.gpio.039.in
7 bit OUT FALSE hm2_5i20.0.gpio.039.in_not
7 bit IN FALSE hm2_5i20.0.gpio.039.out
7 bit OUT TRUE hm2_5i20.0.gpio.040.in
7 bit OUT FALSE hm2_5i20.0.gpio.040.in_not
7 bit IN FALSE hm2_5i20.0.gpio.040.out
7 bit OUT TRUE hm2_5i20.0.gpio.041.in
7 bit OUT FALSE hm2_5i20.0.gpio.041.in_not
7 bit IN FALSE hm2_5i20.0.gpio.041.out
7 bit OUT TRUE hm2_5i20.0.gpio.042.in
7 bit OUT FALSE hm2_5i20.0.gpio.042.in_not
7 bit IN FALSE hm2_5i20.0.gpio.042.out
7 bit OUT TRUE hm2_5i20.0.gpio.043.in
7 bit OUT FALSE hm2_5i20.0.gpio.043.in_not
7 bit IN FALSE hm2_5i20.0.gpio.043.out
7 bit OUT TRUE hm2_5i20.0.gpio.044.in
7 bit OUT FALSE hm2_5i20.0.gpio.044.in_not
7 bit IN FALSE hm2_5i20.0.gpio.044.out
7 bit OUT TRUE hm2_5i20.0.gpio.045.in
7 bit OUT FALSE hm2_5i20.0.gpio.045.in_not
7 bit IN FALSE hm2_5i20.0.gpio.045.out
7 bit OUT TRUE hm2_5i20.0.gpio.046.in
7 bit OUT FALSE hm2_5i20.0.gpio.046.in_not
7 bit IN FALSE hm2_5i20.0.gpio.046.out
7 bit OUT TRUE hm2_5i20.0.gpio.047.in
7 bit OUT FALSE hm2_5i20.0.gpio.047.in_not
7 bit IN FALSE hm2_5i20.0.gpio.047.out
7 bit OUT TRUE hm2_5i20.0.gpio.048.in
7 bit OUT FALSE hm2_5i20.0.gpio.048.in_not
7 bit IN FALSE hm2_5i20.0.gpio.048.out
7 bit OUT TRUE hm2_5i20.0.gpio.049.in
7 bit OUT FALSE hm2_5i20.0.gpio.049.in_not
7 bit IN FALSE hm2_5i20.0.gpio.049.out
7 bit OUT TRUE hm2_5i20.0.gpio.050.in
7 bit OUT FALSE hm2_5i20.0.gpio.050.in_not
7 bit IN FALSE hm2_5i20.0.gpio.050.out
7 bit OUT TRUE hm2_5i20.0.gpio.051.in
7 bit OUT FALSE hm2_5i20.0.gpio.051.in_not
7 bit IN FALSE hm2_5i20.0.gpio.051.out
7 bit OUT TRUE hm2_5i20.0.gpio.052.in
7 bit OUT FALSE hm2_5i20.0.gpio.052.in_not
7 bit IN FALSE hm2_5i20.0.gpio.052.out
7 bit OUT TRUE hm2_5i20.0.gpio.053.in
7 bit OUT FALSE hm2_5i20.0.gpio.053.in_not
7 bit IN FALSE hm2_5i20.0.gpio.053.out
7 bit OUT TRUE hm2_5i20.0.gpio.054.in
7 bit OUT FALSE hm2_5i20.0.gpio.054.in_not
7 bit IN FALSE hm2_5i20.0.gpio.054.out
7 bit OUT TRUE hm2_5i20.0.gpio.055.in
7 bit OUT FALSE hm2_5i20.0.gpio.055.in_not
7 bit IN FALSE hm2_5i20.0.gpio.055.out
7 bit OUT TRUE hm2_5i20.0.gpio.056.in
7 bit OUT FALSE hm2_5i20.0.gpio.056.in_not
7 bit IN FALSE hm2_5i20.0.gpio.056.out
7 bit OUT TRUE hm2_5i20.0.gpio.057.in
7 bit OUT FALSE hm2_5i20.0.gpio.057.in_not
7 bit IN FALSE hm2_5i20.0.gpio.057.out
7 bit OUT TRUE hm2_5i20.0.gpio.058.in
7 bit OUT FALSE hm2_5i20.0.gpio.058.in_not
7 bit IN FALSE hm2_5i20.0.gpio.058.out
7 bit OUT TRUE hm2_5i20.0.gpio.059.in
7 bit OUT FALSE hm2_5i20.0.gpio.059.in_not
7 bit IN FALSE hm2_5i20.0.gpio.059.out
7 bit OUT TRUE hm2_5i20.0.gpio.060.in
7 bit OUT FALSE hm2_5i20.0.gpio.060.in_not
7 bit IN FALSE hm2_5i20.0.gpio.060.out
7 bit OUT TRUE hm2_5i20.0.gpio.061.in
7 bit OUT FALSE hm2_5i20.0.gpio.061.in_not
7 bit IN FALSE hm2_5i20.0.gpio.061.out
7 bit OUT TRUE hm2_5i20.0.gpio.062.in
7 bit OUT FALSE hm2_5i20.0.gpio.062.in_not
7 bit IN FALSE hm2_5i20.0.gpio.062.out
7 bit OUT TRUE hm2_5i20.0.gpio.063.in
7 bit OUT FALSE hm2_5i20.0.gpio.063.in_not
7 bit IN FALSE hm2_5i20.0.gpio.063.out
7 bit OUT TRUE hm2_5i20.0.gpio.064.in
7 bit OUT FALSE hm2_5i20.0.gpio.064.in_not
7 bit IN FALSE hm2_5i20.0.gpio.064.out
7 bit OUT TRUE hm2_5i20.0.gpio.065.in
7 bit OUT FALSE hm2_5i20.0.gpio.065.in_not
7 bit IN FALSE hm2_5i20.0.gpio.065.out
7 bit OUT TRUE hm2_5i20.0.gpio.066.in
7 bit OUT FALSE hm2_5i20.0.gpio.066.in_not
7 bit IN FALSE hm2_5i20.0.gpio.066.out
7 bit OUT TRUE hm2_5i20.0.gpio.067.in
7 bit OUT FALSE hm2_5i20.0.gpio.067.in_not
7 bit IN FALSE hm2_5i20.0.gpio.067.out
7 bit OUT TRUE hm2_5i20.0.gpio.068.in
7 bit OUT FALSE hm2_5i20.0.gpio.068.in_not
7 bit IN FALSE hm2_5i20.0.gpio.068.out
7 bit OUT TRUE hm2_5i20.0.gpio.069.in
7 bit OUT FALSE hm2_5i20.0.gpio.069.in_not
7 bit IN FALSE hm2_5i20.0.gpio.069.out
7 bit OUT TRUE hm2_5i20.0.gpio.070.in
7 bit OUT FALSE hm2_5i20.0.gpio.070.in_not
7 bit IN FALSE hm2_5i20.0.gpio.070.out
7 bit OUT TRUE hm2_5i20.0.gpio.071.in
7 bit OUT FALSE hm2_5i20.0.gpio.071.in_not
7 bit IN FALSE hm2_5i20.0.gpio.071.out
7 bit IN FALSE hm2_5i20.0.led.CR01
7 bit IN FALSE hm2_5i20.0.led.CR02
7 bit IN FALSE hm2_5i20.0.led.CR03
7 bit IN FALSE hm2_5i20.0.led.CR04
7 bit IN FALSE hm2_5i20.0.led.CR05
7 bit IN FALSE hm2_5i20.0.led.CR06
7 bit IN FALSE hm2_5i20.0.led.CR07
7 bit IN FALSE hm2_5i20.0.led.CR08
7 bit IN FALSE hm2_5i20.0.pwmgen.00.enable
7 float IN 0 hm2_5i20.0.pwmgen.00.value
7 bit IN FALSE hm2_5i20.0.pwmgen.01.enable
7 float IN 0 hm2_5i20.0.pwmgen.01.value
7 s32 OUT 0 hm2_5i20.0.read.time
7 s32 OUT 0 hm2_5i20.0.read_gpio.time
7 u32 OUT 0x00000000 hm2_5i20.0.sserial.port-0.fault-count
7 u32 OUT 0x00000000 hm2_5i20.0.sserial.port-0.port_state
7 u32 OUT 0x00000000 hm2_5i20.0.sserial.port-0.port_state2
7 u32 OUT 0x00000000 hm2_5i20.0.sserial.port-0.port_state3
7 bit IN TRUE hm2_5i20.0.sserial.port-0.run
7 bit IN FALSE hm2_5i20.0.stepgen.00.control-type
7 s32 OUT 0 hm2_5i20.0.stepgen.00.counts
7 float OUT 0 hm2_5i20.0.stepgen.00.dbg_err_at_match
7 float OUT 0 hm2_5i20.0.stepgen.00.dbg_ff_vel
7 float OUT 0 hm2_5i20.0.stepgen.00.dbg_pos_minus_prev_cmd
7 float OUT 0 hm2_5i20.0.stepgen.00.dbg_s_to_match
7 s32 OUT 0 hm2_5i20.0.stepgen.00.dbg_step_rate
7 float OUT 0 hm2_5i20.0.stepgen.00.dbg_vel_error
7 bit IN FALSE hm2_5i20.0.stepgen.00.enable
7 float IN 0 hm2_5i20.0.stepgen.00.position-cmd
7 float OUT 0 hm2_5i20.0.stepgen.00.position-fb
7 float IN 0 hm2_5i20.0.stepgen.00.velocity-cmd
7 float OUT 0 hm2_5i20.0.stepgen.00.velocity-fb
7 bit IN FALSE hm2_5i20.0.stepgen.01.control-type
7 s32 OUT 0 hm2_5i20.0.stepgen.01.counts
7 float OUT 0 hm2_5i20.0.stepgen.01.dbg_err_at_match
7 float OUT 0 hm2_5i20.0.stepgen.01.dbg_ff_vel
7 float OUT 0 hm2_5i20.0.stepgen.01.dbg_pos_minus_prev_cmd
7 float OUT 0 hm2_5i20.0.stepgen.01.dbg_s_to_match
7 s32 OUT 0 hm2_5i20.0.stepgen.01.dbg_step_rate
7 float OUT 0 hm2_5i20.0.stepgen.01.dbg_vel_error
7 bit IN FALSE hm2_5i20.0.stepgen.01.enable
7 float IN 0 hm2_5i20.0.stepgen.01.position-cmd
7 float OUT 0 hm2_5i20.0.stepgen.01.position-fb
7 float IN 0 hm2_5i20.0.stepgen.01.velocity-cmd
7 float OUT 0 hm2_5i20.0.stepgen.01.velocity-fb
7 bit IN FALSE hm2_5i20.0.stepgen.02.control-type
7 s32 OUT 0 hm2_5i20.0.stepgen.02.counts
7 float OUT 0 hm2_5i20.0.stepgen.02.dbg_err_at_match
7 float OUT 0 hm2_5i20.0.stepgen.02.dbg_ff_vel
7 float OUT 0 hm2_5i20.0.stepgen.02.dbg_pos_minus_prev_cmd
7 float OUT 0 hm2_5i20.0.stepgen.02.dbg_s_to_match
7 s32 OUT 0 hm2_5i20.0.stepgen.02.dbg_step_rate
7 float OUT 0 hm2_5i20.0.stepgen.02.dbg_vel_error
7 bit IN FALSE hm2_5i20.0.stepgen.02.enable
7 float IN 0 hm2_5i20.0.stepgen.02.position-cmd
7 float OUT 0 hm2_5i20.0.stepgen.02.position-fb
7 float IN 0 hm2_5i20.0.stepgen.02.velocity-cmd
7 float OUT 0 hm2_5i20.0.stepgen.02.velocity-fb
7 bit IN FALSE hm2_5i20.0.stepgen.03.control-type
7 s32 OUT 0 hm2_5i20.0.stepgen.03.counts
7 float OUT 0 hm2_5i20.0.stepgen.03.dbg_err_at_match
7 float OUT 0 hm2_5i20.0.stepgen.03.dbg_ff_vel
7 float OUT 0 hm2_5i20.0.stepgen.03.dbg_pos_minus_prev_cmd
7 float OUT 0 hm2_5i20.0.stepgen.03.dbg_s_to_match
7 s32 OUT 0 hm2_5i20.0.stepgen.03.dbg_step_rate
7 float OUT 0 hm2_5i20.0.stepgen.03.dbg_vel_error
7 bit IN FALSE hm2_5i20.0.stepgen.03.enable
7 float IN 0 hm2_5i20.0.stepgen.03.position-cmd
7 float OUT 0 hm2_5i20.0.stepgen.03.position-fb
7 float IN 0 hm2_5i20.0.stepgen.03.velocity-cmd
7 float OUT 0 hm2_5i20.0.stepgen.03.velocity-fb
7 bit I/O FALSE hm2_5i20.0.watchdog.has_bit
7 s32 OUT 0 hm2_5i20.0.write.time
7 s32 OUT 0 hm2_5i20.0.write_gpio.time
halcmd:
Last edit: 4 years 4 days ago by andypugh.
4 years 4 days ago - 4 years 4 days ago #255319
OK, so it looks like there used to be a parameter called 8i20.max_current but there isn't any more.
Logging in to my own machine (I use 8i20 too) I see:
So replace your
with
18 float RW 6.99 hm2_8i20.0003.current-maxlim
18 float RW -6.99 hm2_8i20.0003.current-minlim
18 float RW -8.5 hm2_8i20.0003.current-scalemax
So replace your
setp hm2_5i20.0.8i20.0.0.max_current 30.0
with
setp hm2_8i20.0003.current-maxlim 30
setp hm2_8i20.0003.current-minlim -30
setp hm2_8i20.0003.current-scalemax 30
4 years 4 days ago #255321
by LPMattei
That did not work, fwiw I have a 5i20, I tried changing to line to be more similar to what I had in the file. Mine read
setp hm2_5i20.0.8i20.0.0.max_current 30.0, but that didn't work either. Is there another way we can communicate? It may be a simpler problem than i am making of it, but with the delays with forum responses, I tend to loose where i was last at.
4 years 4 days ago #255325
Sorry, I forgot that I am using the option to address the drives by serial number.
Don't be surprised if that doesn't seem to have worked either, but if you look carefully you might see that there is now a different error message
setp hm2_5i20.0.8i20.0.0.current-maxlim 30
setp hm2_5i20.0.8i20.0.0.current-minlim -30
setp hm2_5i20.0.8i20.0.0.current-scalemax 30
Time to create page: 0.057 seconds
