loading LinuxCNC on old smithy 1240
4 years 1 month ago #252771 by PCW
Is the 8I20 powered?
4 years 1 month ago #252785 by LPMattei
I would have to say yes, if I swap in the disk with the old version SW it works fine
4 years 1 month ago #252799 by PCW
Can you try commenting out that line (line 86) in the hal file
and trying to start LinuxCNC again.
I think possibly some pin names changed over the years
4 years 1 month ago #252811 by LPMattei
I tried that, then I commented the next 3 lines that failed.
#    setp hm2_5i20.0.stepgen.03.position-scale  [AXIS_3]SCALE
#    setp hm2_5i20.0.stepgen.03.maxaccel        [AXIS_3]STEPGEN_MAXACCEL
#    setp hm2_5i20.0.stepgen.03.maxvel          [AXIS_3]STEPGEN_MAXVEL
then it gave following error
./1240combined.hal:191: Pin 'hm2_5i20.0.8i20.0.0.amp_enable' does not exist
I feel like it is missing something and I will be chasing the errors all the way down.
4 years 1 month ago #252813 by PCW
Can you post the hal/ini files here?
4 years 1 month ago #252880 by LPMattei
Here are both files
Time to create page: 0.108 seconds
