scurve trajectory planner
26 Jan 2025 21:01 #319911 by juliankoenig87
Replied by juliankoenig87 on topic scurve trajectory planner
Oh, forget about the cpu load. Its to late. I forgot that I tested the axis cycle time.
The following user(s) said Thank You: Lcvette
  • Grotius
  • Grotius's Avatar Topic Author
  • Platinum Member
  • Platinum Member
28 Jan 2025 15:16 #319994 by Grotius
Replied by Grotius on topic scurve trajectory planner
Hi Julian,
Did some updates.
The scurve is now conversed to c code. I think this is easyer for bug solving.
And it can now be used directly in lcnc components.
I forgot to apply the feed overide to the end velocity's of segments.
Now it's running much faster.
I came accross a new bug. When a new buffer was loaded, the velocity was starting from zero when
using feed overides around 300%. Lower than that the bug was not visible.
This now is solved. During a new buffer load and transition the velocity keeps up.
There was also a endvel=0 error, wich halted motion,  is solved by pushing the motion into a new segment,
depending on rundir.
Extreme feed overides:
The following user(s) said Thank You: akb1212, bkt, tivoi, Lcvette, Aciera, RDA, Darium, Beef, Unlogic
28 Jan 2025 16:06 #319997 by juliankoenig87
Hi Grotius.
Really cool! Tomorrow I will have some time to test around. I also wrote a small ncode with some loops to test P and F values. Will test and provide tomorrow.
The conversion I dont get right now. Of course I know how to use components and so on, but have to look how you mean it.
28 Jan 2025 16:40 #319998 by Lcvette
Replied by Lcvette on topic scurve trajectory planner
Hi Grotius.
Julian, can you join the qtpyvcp chat room?
matrix.to/#/#qtpyvcp:matrix.org
  • Grotius
  • Platinum Member
  • Platinum Member
29 Jan 2025 11:13 #320071 by Grotius
I was thinking about a algo to smooth trajectory path's. This is just an idea.
1. Create a triangle's & find gravity point off triangle's. Triangle is constructed in a loop by path point's n+0, n+1, n+2.
2. Max deviation point lies on the line n+1 up to the gravity point, but not exceed the gravity point. P=0 up to P=Infinity.
3. Connect the gravity points by a  line. (red).
4. Create half way line points on the line. (blue).
5. Connect half way line points by linestrip. (blue). Second stage.
6. Replace linestrip by a cubic spline.
Properties:
Works in 3d space.
Conversion of arc's to linestrips is required.
The new trajectory tends to move inwards when on a circle.
Let me know what you think.
The following user(s) said Thank You: Aciera, Beef
29 Jan 2025 12:49 #320080 by Aciera
Replied by Aciera on topic scurve trajectory planner
Works in 3d space.
1. Nice
2. Seems unproblematic as that is what a lot of cam output does anyway and deviation can be easily calculated and adjusted.
3. I think that's the same behavior as the current planner.
The following user(s) said Thank You: bkt, Grotius
30 Jan 2025 05:58 - 30 Jan 2025 06:01 #320134 by juliankoenig87
I like the idea also. So you want to go nearer to the points before doing a spline.
I thought of splitting the resulting red points (limiting by gravity point an P) by half for example if the next angle is also in the same direction. Could be more sophisticated of course. Just a rough idea. This way we are not getting more inside in this situations.
Splitting in half between edgepoint and last point if next angle is the ame direction. And going one step back if the direction will change (not perfectly described of course).
Last edit: 30 Jan 2025 06:01 by juliankoenig87.
  • Grotius
  • Platinum Member
  • Platinum Member
30 Jan 2025 14:08 - 30 Jan 2025 14:27 #320149 by Grotius
Today i thought maybe add a path filter to the planner. This is also just an idea that came up.
It uses no G64 P[x] value.
It uses no path blending and or fillets etc.
It works as backend filter for any path using G64 P[x] values.
It uses a hal_path_filter input parameter between 0 and 3000. Imagine 0 up to 3000 servo-cycles.
This is a simple algoritme that calculates the avarage of toolpath points [bufsize] in real time.
The runtime property is that how lower the speed, how closer it gets to the path. Deviation is small.
How faster the speed, deviation becomes bigger.
If normally the motion stops every gcode line because no G64 P[x] value is given, this algo keeps
up velocity's. In fact it automaticly generates endvelocity's for the trajectory.
In halscope the joint.x velocity and acceleration values, are nice.
hal_path_filter = 500
hal_path_filter = 1000
hal_path_filter = 2000
hal_path_filter = 3000
Show multiple filter values, 500, 750, 1000.
Let me know what you think?
Last edit: 30 Jan 2025 14:27 by Grotius.
The following user(s) said Thank You: Beef
  • Grotius
  • Platinum Member
  • Platinum Member
30 Jan 2025 15:04 - 30 Jan 2025 15:30 #320152 by Grotius
@Arciera,
Thanks for responce.
Yes, looks like so.
@Julian,
Also thanks for responce.
The idea is polyline simplyfication. Then i thought maybe use :
Douglas-Peucker
Visvalingam-Whyatt
However both algo's don't satisfy cnc path smoothing.
Then i tried something on a paper with a pen myself. And came up with the triangles
centroid idea.
In Cgal they use the idea off convex hull for triangles.
However,
this idea is not really using a convex hull method, it's more like a forward sweep convex hull or
triangle-fan.
When the resulting line strip looks ok. Then doing a splinify is problably most succesfully.
However, if you use the "filter algo from previous post" then used as the planners back-end,
the result is maybe good enhough, you don't need the splinify.
I don't get it. .  But does'nt matter. Thanks for your help yesterday !
From DeepSeek:
Possible Names or Related Algorithms:
Laplacian Smoothing:
A common technique in mesh and curve smoothing that averages points with their neighbors. Your method is somewhat similar but uses centroids and halfway points instead of direct averaging.
Centroidal Voronoi Tessellation (CVT)
While not a direct match, CVT involves optimizing point positions (like centroids) to achieve smoothness in a geometric structure.
It looks like the algo is similar to Laplacian smoothing for the first stage. liqimai.github.io/blog/AAAI-18/
However the Laplacian is not using centrold's. And here it show's only the 2d solution. And algo is
working different as we use it.
Then it has no second stage.
Last edit: 30 Jan 2025 15:30 by Grotius.
The following user(s) said Thank You: bkt, Darium, Beef
30 Jan 2025 17:20 #320163 by bkt
Replied by bkt on topic scurve trajectory planner
... month of study in vision system algorythm ... finally see a real utilizations ....
Time to create page: 0.331 seconds
