scurve trajectory planner
1 year 7 months ago #324281 by Grotius
Replied by Grotius on topic scurve trajectory planner
Hi Meiser,
That could only done by ./build_cmake script
# flush build dir
rm -rf *
Hmm. That script is designed by Joco. But i take responsebility for it.
I know also from previous years, that this can indeed remove things you dont want to.
I experienced the same years ago, in a moment i lost my entire home dir content.
Will remove the rm in all scripts now. Sorry Meiser.
1 year 7 months ago - 1 year 7 months ago #324293 by Grotius
@Arciera,
Attached a gcode sample. A cw and a ccw square. That contains the problem.
Extra torsion turn:
No extra torsion turn:
The investegation, i printed the clothoid result and take a look at the theta values, and compared them :
** where != means is not.
If clothoid output is like this, fit is ok:
  • theta10 Z != 0
  • theta 20 XY = 0
  • theta 14 Z = 0
  • theta 24 XY = 0
If clothoid output is like this, fit is not ok:
  • theta10 Z != 0
  • theta 20 XY = 0
  • theta 14 Z = 0
  • theta 24 XY != 0
This let me think about how to solve this. When you have the not ok situation,
you can introduce a tiny error to get the fit off-plane. A off plane fit seems to solves this issue.
So when you add 1e-6 (ultra tiny error) to one off the trimmed line's z-position, it goes off plane. Problem is solved.
So when lines have no intersection, there is no extra torsion turn.
Now i did not test any further. So i hope this is it.
Last edit: 1 year 7 months ago by Grotius.
The following user(s) said Thank You: akb1212, Aciera
1 year 7 months ago #324297 by Aciera
Replied by Aciera on topic scurve trajectory planner
that's quite interesting.
1 year 7 months ago #324308 by ruediger123
Replied by ruediger123 on topic scurve trajectory planner
Hello,
I've been following this topic for a long time, great work.
I looked at the jerk with the Hal oscilloscope, there seemed to be outliers.
see image.
The following user(s) said Thank You: akb1212, Grotius
1 year 7 months ago #324323 by Grotius
@Arciera,
Yes. Interesting.
The clothoid takes as input the xy angle and the z angle. Derived from the 3d vector.
I personally should not design the abstract like this, where it uses xy & z angles.
I should prefer to design the abstract in pure 3d vector format. As this is cleaner in my view.
Now we need to transform xy & z angles into 3d vectors etc. I think this could be avoided.
If we should store extra info about a line vector self axis rotation 0 up to 2*M_PI. We could do a clothoid fit with multiple
torsion turns for example. The clothoid fit would then look like a helix fit.
There is still some kind of overfitting in some cases, where the clothoid fit is valid, but takes extra space into the workpiece.
This is inherent to the 4-clothoid-spline fit, as a 2-clothoid-spline can not fit like that, as it has less contrains.
I was considering to create a 2 clothoid spline library based on this 3d clothoid library. This is like downgrading the current
4-clothoid-spline. But will decide that later this year.
Hi Ruediger,
We are aware of spikes. Haha.
Even the most elegant curve seems to show acceleration spikes in halscope.
I dont have the J0 jerk pin here in my axis config.
One way to rule out spikes is to introduce back-end runners. They will filter out all spikes.
Good find btw. And nice you did some research on the codebase.
1 year 7 months ago - 1 year 7 months ago #324365 by ruediger123
Hello,
attached is the hal file with the jerk pins.
Gruß Rüdiger
File Name: sim_lib.tcl.txt
File Size:16 KB
Last edit: 1 year 7 months ago by ruediger123.
Time to create page: 0.138 seconds
