Lathe Macros
27 Sep 2022 10:40 #252842
Replied by andypugh on topic Lathe Macros
I am not clear which version isn't working?
You probably need the old version with LinuxCNC 2.8 and Python 2.
27 Sep 2022 10:41 #252843
- virencq
- Thank you received: 5
28 Sep 2022 01:22 - 29 Sep 2022 16:07 #252905
by virencq
Replied by virencq on topic Lathe Macros
Both are your versions.
Initial version of lathe macros with separate image files works well with 2.9.
Latest have only 1 .svg file.
I am running 2.9 installed as well as master RIP environment. Image is not showing, though input fields shows.
No luck in any of them, I need especially the drill section.
Last edit: 29 Sep 2022 16:07 by virencq.
29 Sep 2022 21:37 #253053
If you are using 2.9 then the version in the repository really should work:
github.com/LinuxCNC/linuxcnc/tree/master...occapy/lathe_configs
You need the .svg, ui, .py and .ngc files.
- virencq
30 Sep 2022 12:43 #253093
by virencq
Yes, it's working on PC.
I am using Raspberry PI 4 for my lathe here it's not working.
I have installed RSVG too.
30 Sep 2022 12:52 #253095
What isn't working? What error messages do you see (you might have to start LinuxCNC from the command "linuxcnc" to see them)
- virencq
30 Sep 2022 14:26 - 30 Sep 2022 14:27 #253102
by virencq
Macro Image not showing.
Below is the error message from the terminal.
Last edit: 30 Sep 2022 14:27 by virencq.
30 Sep 2022 15:25 #253106
**** GLADE VCP ERROR: With xml file: lathemacro.ui : could not create GladeXML object
Which version of libglade do you have installed? You could see if Synaptic has an update to offer.
- virencq
02 Oct 2022 10:26 #253239
by virencq
Checked libglade is updated.
What else to check
What else to check
02 Oct 2022 17:13 #253269
Can you open the .ui file directly in the Glade editor?
The following user(s) said Thank You: virencq
Time to create page: 0.261 seconds
