Configuration simoreg 6RB2030 siemens
John I have everything connected. the motor is running very, very slow. the encoder is working me. linuxcnc screen in this recording me servo movement.
linuxcnc activate when I give, I get the Following Error joint2 alarm.
I know this because my business is, but any help would be great. I think I have everything connected properly.
enable only a single actuator, as it is my first test with this.
and remove the encoder data when I get the same message, but sometimes the servomotor starts faster.
thanks in advance
jorge viloria
Do you have output from the 7i77 to the servo amps?
Have you tuned the PID loop at all?
Just curious what is your native language? I can tell it is not English and it frustrates me that I can not understand exactly what your trying to say.
Lets try and start from scratch...
If you turn the axis by hand does the DRO in Axis read correctly?
That is that the analog output of the 7I77 drives the motor in the proper direction
to correct a position error, not make it larger (and runaway)
You do this by setting the following error large enough (say 1 inch or 25 mm)
that you can see what the drive is doing before it faults out with a following error
wiki.linuxcnc.org/cgi-bin/wiki.pl?Following_Error
For God is wonderful ....! it will be trivial for you but for me it is a great achievement.
Thanks John, Andy, Peter .... have been very patient with me.
John, I'm from Barranquilla, Colombia. my native language is Spanish. I rely on google translator, so I guess sometimes things do not make sense for you.
Friends work ..! I succeed in controlling the servomotor.
I'm setting the machine in mm, so had problems all the examples I've seen are in inches. and all the despair I noticed measurement units.
The question now, where do I start for get the correct PID?
remember in milimeter
thanks
I've started a velocity drive tuning page here:
gnipsel.com/linuxcnc/tuning/servo.html
I still need to add the halscope screen shots...
I am confused with PID.
1. this moving me servomotors
2. for now I only moved the P to 120 but I have not managed to stop the motor oscillate and vibrate a little.
3. the servomotors are hot.
4. servomotors move the positive and negative. (not as steady as it should be)
5. speak in a reply ZERO POT, see my Servo has one. as I adjust that, you had to move some "switch" your siemens servo?
6. Any other advice, how could configure PID.
thanks
It has good basic information for tuning velocity mode servos
Do not let you servos oscillate! its hard on the motors/drives and mechanical parts
oscillation probably means your P gain is too high
(I am assuming you only have P and FF1 at this point as you should)
