Configuration simoreg 6RB2030 siemens
19 Oct 2012 20:12 #25452
by jlviloria
Replied by jlviloria on topic Re:Configuration simoreg 6RB2030 siemens
19 Oct 2012 20:37 #25453
Replied by PCW on topic Re:Configuration simoreg 6RB2030 siemens
A very basic question, are these drives running in torque or velocity mode?
19 Oct 2012 20:42 #25455
by jlviloria
good question.
but not the answer.
but not the answer.
19 Oct 2012 20:46 #25456
by jlviloria
How do I know if it is in torque mode or velocity mode??
Too bad so much ignorance
thanks
thanks
19 Oct 2012 20:50 #25457
by jlviloria
good looks,
When energized the drive, no linuxcnc open, the motor turns slowly. and the tacho there 0.5VDC when linuxcnc open and activate (F2), the voltage goes to zero in trash.
the motor is energized, but warms and vibrates a bit. and oscillating the shaft.
I give the command to move and move to either side.
19 Oct 2012 20:53 #25458
Drive manual
19 Oct 2012 21:12 #25459
Replied by andypugh on topic Re:Configuration simoreg 6RB2030 siemens
jlviloria wrote:
If there are tachos on the motor then the drives are almost certainly velocity mode.
You may need less P-gain. Bear in mind that JTs examples are in inches, you will need smaller gains if working in mm.
(the P gain is how many volts of output you want for every mm of error, basically)
good looks,
19 Oct 2012 22:14 #25463
by jlviloria
Andy, Peter.
I move some of my drive potentiometer?, or everything is done linuxcnc PID?
thanks
thanks
19 Oct 2012 22:55 - 19 Oct 2012 22:56 #25465
No, everything is done in LinuxCNCs PID loop
I would not change any drive potentiometers
unless you know exact;y what you are doing and even then
I would mark their original positions
As Andy hinted at above, a P gain of 20 means 0.5 MM of error
is enough to cause full velocity drive. So this is likely still too high
(lower till the drive stops oscillating)
Last edit: 19 Oct 2012 22:56 by PCW.
20 Oct 2012 00:38 #25467
by jlviloria
Peter,
I must say I have not read much. know my limitation of language, my language is Spanish. and makes me understand some things.
Look and quieter in my house.
I will say what I have done.
Connect all.
enable the drive, it worked perfect, no alarms,
linuxcnc enable (F2)
the servomotors is stop. but left with a small oscillation. heats and feel a vibration when you touch the servomotors.
linuxcnc homed is ok
I move the servomotor in "jog" is ok 40mm/min ---- # # # 177mm/min joint2 Following Error alarm.
give MDI (G1 Z100. F500.) is Ok, but "linuxcnc" only goes up 100mm/min.
questions:
because MDI mode linuxcnc I move my axes over 100mm/min?
is normal. vibration, overheating. at the beginning of the configuration of the servomotor
Motor Siemens
1HU3104-0AD
27.4Nm
1200 RPM
10000 mm/min rapid feed
5000 mm/min feedrate
This is part of my ini.
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = 1
MAX_VELOCITY = 8000
MAX_ACCELERATION = 300
P = 10.0
I = 0.0
D = 0.0
FF0 = 0.06
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = -10.0
ENCODER_SCALE = -10000
OUTPUT_SCALE = 10.0
OUTPUT_MIN_LIMIT = -10.0
OUTPUT_MAX_LIMIT = 10.0
MIN_LIMIT = -9999
MAX_LIMIT = 9999
#HOME_OFFSET = 0.000000
#HOME_SEARCH_VEL = -0.050000
#HOME_LATCH_VEL = -0.016667
#HOME_FINAL_VEL = 0.000000
#HOME_USE_INDEX = NO
#HOME_SEQUENCE = 0
Connect all.
questions:
Motor Siemens
1HU3104-0AD
27.4Nm
1200 RPM
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = 1
MAX_VELOCITY = 8000
P = 10.0
I = 0.0
D = 0.0
FF0 = 0.06
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = -10.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -9999
MAX_LIMIT = 9999
#HOME_SEQUENCE = 0
Time to create page: 0.092 seconds
