Work with probe
7 years 7 months ago #129586 by andypugh
Replied by andypugh on topic Work with probe
The probe can be seen as a tool, and can use the same offsets as other tools. These include offsets in X and Y as well as tool length.
7 years 6 months ago #131899 by Roguish
Replied by Roguish on topic Work with probe
Verser,
I have done all changes as I find here, but still get error when loading a file, with REMAP ENABLED.
A little help please.
Really like the ProbeScreen.
7 years 6 months ago #131950 by andypugh
I think that this might be the bug here:
github.com/LinuxCNC/linuxcnc/issues/559
Make sure that O<manual_change> isn't % delimited.
7 years 6 months ago #132107 by Roguish
thanks andypugh. that was it. i just did not glean that from the posts.
Roguish.
7 years 5 months ago #133454 by tecno
Replied by tecno on topic Work with probe
I get following error, can somebody please explain what to do about this.
**** probe_screen GETINIINFO **** Preference file path: gmoccapy_preferences **** PROBE SCREEN INFO **** **** To many increments given in INI File for this screen **** **** Only the first 5 will be reachable through this screen **** **** PROBE SCREEN INFO **** **** no valid probe config in INI File **** **** disabled auto tool measurement **** toolnumber = 0 False **** GMOCCAPY INFO **** **** replaced btn_zero_g92 to btn_block_height **** **** GMOCCAPY INFO: Gcode.lang found ****
[DISPLAY] DISPLAY = gmoccapy PREFERENCE_FILE_PATH = gmoccapy_preferences EMBED_TAB_NAME = Probe Screen EMBED_TAB_LOCATION = ntb_user_tabs EMBED_TAB_COMMAND = gladevcp -x {XID} -u python/probe_screen.py probe_icons/probe_screen.glade
[RS274NGC] PARAMETER_FILE = linuxcnc.var FEATURES=30 SUBROUTINE_PATH = macros REMAP=M6 modalgroup=6 prolog=change_prolog ngc=manual_change epilog=change_epilog
Is it the line FEATURES = 30 that is the culprit?
7 years 5 months ago #133531 by pl7i92
Replied by pl7i92 on topic Work with probe
you need toolsensor
[TOOLSENSOR] # Control probe rapid speed RAPID_SPEED = 60
is the ((.axisrc)) as folow set
def my_error_task(self): error = e.poll() while error: kind, text = error if kind in (linuxcnc.NML_ERROR, linuxcnc.OPERATOR_ERROR): icon = "error" else: icon = "info" notifications.add(icon, text) ucomp["error"]=True error = e.poll() self.error_after = self.win.after(200, self.error_task) def my_remove(self, widgets): self.widgets.remove(widgets) if len(self.cache) < 10: widgets[0].pack_forget() self.cache.append(widgets) else: widgets[0].destroy() if len(self.widgets) == 0: ucomp["error"]=False self.place_forget() LivePlotter.error_task = my_error_task Notification.remove = my_remove if hal_present == 1 : ucomp = hal.component("probe.user") ucomp.newpin("error",hal.HAL_BIT,hal.HAL_IN) ucomp.ready()
Time to create page: 0.629 seconds
