Work with probe
7 years 5 months ago #133603 by tecno
Replied by tecno on topic Work with probe
Have to take a closer look on this, not so easy to change parameters.
I *only* need to handle the shoot-over as all parameters are set in the ngc file here in forum.linuxcnc.org/49-basic-configuratio...obe?start=260#133566 to get the manual tool-change to work.
7 years 5 months ago #133716 by tecno
So, feeling better today and thinking clearly better so here my simple solution.
F #<_hal[probe.ps_searchvel]>
G91
G38.2 Z #<_ini[TOOLSENSOR]MAXPROBE>
G1 Z0.76 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< added travel 0.5mm and slowed down Z movement
; This is commented out only for sim.
F #<_hal[probe.ps_probevel]>
G38.2 Z-0.5
7 years 5 months ago #133722 by pl7i92
Replied by pl7i92 on topic Work with probe
as simply as you coudt get it
Nice if it workes
7 years 5 months ago #133723 by tecno
Seems to be working OK now, have been testing with several tool changes and all is running well.
Next in line to be solved is how to measure large end mills and also figure out offset to the high speed spindle so I can measure the tools on it too.
7 years 4 months ago - 7 years 4 months ago #137881 by InnerBushman
Replied by InnerBushman on topic Work with probe
Hello.
I have encountered some problems with probe screen V2 from the very beginning.
12:45:30 Error: EOF in file:/usr/share/axis/images/axis.ngc seeking o-word: o<xplus> from line: 0 12:45:10 Error: Named parameter #<_ini[toolsensor]rapid_speed> not defined
I have defined the missing variable manually via MDI to try and progress. I was able to work around this issue but a proper solution would be appreciated. I then googled for the next issue and found that removing '%' from nc files could fix it but the problem is there's no '%' in ANY of them!
Is there anyone who can try and help me fix it? Thanks in advance.
LinuxCNC/AXIS version 2.7.14
Cheers,
Bushman
Last edit: 7 years 4 months ago by InnerBushman.
7 years 4 months ago #137887 by andypugh
Replied by andypugh on topic Work with probe
You need to add the entries to the INI file.
[TOOLSENSOR] RAPID_SPEED = 100
For example.
You might also need to enable INI file access from G-code:
linuxcnc.org/docs/2.8/html/config/ini-co...sec:rs274ngc-section
[RS274NGC] FEATURES = 12
Time to create page: 0.120 seconds
