Work with probe
7 years 7 months ago #128155 by pl7i92
Replied by pl7i92 on topic Work with probe
the mauell toolchange is interfeard with the probescreen so M6 is inconsist at this moment they are working to solve this
be patiant within the next 14 days or so it may be fixed
7 years 7 months ago #128177 by vmihalca
Replied by vmihalca on topic Work with probe
I have done everything that was mentioned in the instructions (or at least that's what I think) and now I have an issue at tool change from MDI.
How should I do a tool change now that I have ProbeScreen, whose installation required me to comment the manual tool change in my hal file.
I am attaching a video below with all the settings that I've made and what's the current behavior.
If I've missed something, please let me know
The following user(s) said Thank You: verser
7 years 7 months ago - 7 years 7 months ago #128199 by verser
Replied by verser on topic Work with probe
My fault. In the installation instructions did not make important lines in my-mill-postgui.hal:
net tool-change probe.toolchange-change <= iocontrol.0.tool-change net tool-changed probe.toolchange-changed <= iocontrol.0.tool-changed net tool-prep-number probe.toolchange-number <= iocontrol.0.tool-prep-number
Changed (".hal correction for tool change", "del "%" from macros")
Last edit: 7 years 7 months ago by verser.
7 years 7 months ago - 7 years 7 months ago #128228 by vmihalca
Hi Verser, thanks for the awesome work!
I have made the changes and it does the tool change without freezing.
Now after I do an M6 T1 G43 i get an info message sayin "No tool measurement. Please take care of the entry in the tool table."
In order to use the Remap M6, I've put the probe in the spindle and measured the height of the TS Height and it got updated.
Then I've loaded a tool using either M6 T1 (tried with and without G43).
The table moves to the coordinates of the tool setter, it goes down until it touches and then I get this error:
"Probe is already tripped when starting G38.2 or G38.3 move" and it stops there...
Any idea how should I fix this?
Last edit: 7 years 7 months ago by vmihalca.
7 years 7 months ago #128230 by ikkuh
Replied by ikkuh on topic Work with probe
Does anybody know if both Probe Screen V2 for LinuxCNC and gmoccapy probing can be installed at the same time?
7 years 7 months ago #128234 by Mike_Eitel
Replied by Mike_Eitel on topic Work with probe
I have it with v1
The following user(s) said Thank You: ikkuh
Time to create page: 0.650 seconds
