Work with probe
7 years 7 months ago #128048 by tommylight
Replied by tommylight on topic Work with probe
tony978 wrote: Debug file information:
NGC file not found: ngc=manual_change - 74:REMAP = M6 modalgroup=6 prolog=change_prolog ngc=manual_change epilog=change_epilog
There is a file missing for the remap you are using. It has to be in the same folder where the config files are.
7 years 7 months ago #128051 by tony978
Replied by tony978 on topic Work with probe
Does v1 need to be installed before v2 ?
.axisrc needs to be in ./user or root ?
7 years 7 months ago #128097 by franstrein
Replied by franstrein on topic Work with probe
I still run in the error I posted some weeks back. I tried to change the remap line to use ngc=change to test it, but that didn't help.
Is anyone happen any suggestions here?
Thanks a lot,
Frans
franstrein wrote: Hi,
As I mentioned in another thread, I added NativeCam and the Probe v2 functions to my gmoccapy 1.5.4 and Linux 2.7.14 setup.
Most things work very good.
The only issue is that when I try to execute a gcode file generated by my HSM Express CAM functions, I get an error:
In line 0 of the gcode file the pycall(remap.change_prolog) call fails
I expect this to be caused by the line
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=manual_change epilog=change_epilog
in my INI file. I needed to add that for the probe screens to work, according to the instructions at
github.com/verser-git/probe_screen_v2
Is there a conflict with a similar mapping ??
Any suggestions?
Thanks,
Frans
7 years 7 months ago #128098 by andypugh
Replied by andypugh on topic Work with probe
That REMAP is for tool change. I can't see any reason you would need that for the probe screen.
What happens if you comment it out?
7 years 7 months ago #128121 by tony978
commenting it out works to get it to start , I'm getting a errpr eof in my loaded nc file
it is seaking o-word<down> from line 1 . so that mean a nc file with probe routines needs to be loaded for this screen to work ?
7 years 7 months ago - 7 years 7 months ago #128147 by Ferdl
Replied by Ferdl on topic Work with probe
Hi all,
I'm facing with one problem. The Probe Screen V2 can be loaded and it seams to work. But if I load a gcode it will not be displayed in the axis Preview.
If I remove the M6 command in the gcode the tool path will be displayed...
Any idea what can be wrong? I saw from some user they having the same problem...
By the way it is a great extension for linuxcnc.
Ferdi
Last edit: 7 years 7 months ago by Ferdl.
Time to create page: 0.516 seconds
