Work with probe
8 years 1 hour ago #119782 by Roguish
Replied by Roguish on topic Work with probe
Very nice update and upgrade, thanks.
what is the best way to update my system?
8 years 1 hour ago #119784 by verser
Replied by verser on topic Work with probe
In fact, the upgrade of the previous version in the system is similar to the initial installation. You need to follow the instructions of the Readme file and copy everything manually to the right places and make edits to the files .ini ...-postgui.hal
7 years 11 months ago #120973 by Roguish
thanks. installed. have not used yet. soon. B)
also looked at your products. very nice touch probe.
The following user(s) said Thank You: verser
7 years 11 months ago #121491 by FernV
Replied by FernV on topic Work with probe
Hi Serguei
On github.com/verser-git/probe_screen probe_screen.py is 10 months old and probe_screen.glade is 3 years old.
Where is Probe Screen V2 ?
Fern
7 years 11 months ago #121499 by racedirector
Replied by racedirector on topic Work with probe
FernV wrote: Hi Serguei
Fern
github.com/verser-git/probe_screen_v2 as from above :)
The following user(s) said Thank You: FernV
7 years 11 months ago - 7 years 11 months ago #121550 by FernV
I installed V2 and after making a change in my .hal file from
net probe-in <= parport.0.pin-11-in-not
to
it finally seems to work. I do not know if it is mentionned somewhere but now some users may find why it is not working.
It looks good and I think is a great addition.
However I had a case with Axis and NativeCAM did not load and the error was:
HAL : ERROR : duplicate component name 'gladevcp'
GLADE VCP ERROR :Asking for a HAL component using a name that already exists.
The fix was to change ini file from
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u python/probe_screen.py -x {XID} probe_icons/probe_screen.glade
to
EMBED_TAB_COMMAND=halcmd loadusr -Wn prbscr gladevcp -c prbscr -u python/probe_screen.py -x {XID} probe_icons/probe_screen.glade
or any other name
I noticed that with gmoccapy, when pressing a jog button and the screen change that it will jog until <esc> is pressed.
Also the spinbuttons do not accept the dot from the numeric keypad, a keydown callback like I did in NCAM could fix this.
I will fork your work and write a few patches, specially for the default values either for mm or inches (very simple)
Keep on your nice work
Fern
Last edit: 7 years 11 months ago by FernV. Reason: include the fix
Time to create page: 0.334 seconds
