Work with probe
3 years 3 months ago - 3 years 3 months ago #274613 by Serg452
Replied by Serg452 on topic Work with probe
Another question. The remap enable button has disappeared. I use a tool in a cone BT40 and every time there is no need to measure. What should I do?
Last edit: 3 years 3 months ago by Serg452.
The following user(s) said Thank You: verser
3 years 3 months ago #274688 by verser
Replied by verser on topic Work with probe
Probe Screen v2.8.1  -  added sensitivity  to MDI commands G20, G21.
3 years 3 months ago #274793 by jcdammeyer
Replied by jcdammeyer on topic Work with probe
I ignored the fact that the screen was metric. Changed all the rates and distances to imperial and just use it that way. I don't think the version of the probe screen I'm using issues a G21. If it did I probably removed it.
3 years 3 months ago - 3 years 3 months ago #274860 by jcdammeyer
JohnnyCNC,
Excellent work on this. But I'm puzzled.
Your updated document refers to measure_tools_inch.ngc which you included along with the date in the file name. (Actually the document refers to "measure_tools inch.ngc" Note missing underscore so that's a spot in the document that could be tweaked.)
But it also refers to measure_toolsetter_height.ngc which is not included.
Where is this file? None of the other zip files have a file with precisely this file name.
Last edit: 3 years 3 months ago by jcdammeyer.
3 years 3 months ago #274863 by JohnnyCNC
Replied by JohnnyCNC on topic Work with probe
Thanks. The date was added so that if I post a revised version it will be apparent which is the latest.  I'll fix my doc to correct the missing underscore.
Currently I am trying to get this to work with 2.9 and QTDragon_HD.  The issue is that the probing is now being done in Python and I haven't figured out how to update a numbered parameter from within Python.  I need to save the probed value with some math applied to parameter #4001.
Attached is the file.  This is used with no actual tool in the spindle.  It measures where the Z is when the nose of the spindle trips the tool setter.
File Name: measure_to...7-05.ngc
File Size:1 KB
3 years 3 months ago #274864 by JohnnyCNC
Hmm, apparently the forum added the date and not me. Probably for the same reason. There was no date on the file that I selected to post.
Time to create page: 0.901 seconds
