- Configuring LinuxCNC
- Basic Configuration
- How to connect Home switches for dual motor on 3 Axis machine [2.8 Pre Master]
- denhen89
- Thank you received: 27
24 Jan 2018 20:47 #104958
by denhen89
Replied by denhen89 on topic How to connect Home switches for dual motor on 3 Axis machine [2.8 Pre Master]
Sorry, i forgot to tell something. The psu output voltage can be regulated. Max. is 15V, i forgot to lower it, but if all other switches are working only the Y2 home switch from the HMA+ terminal not, then i think it has nothing to do with the voltage.
God damned, what can it be
- Mike_Eitel
- Thank you received: 183
24 Jan 2018 20:50 #104959
by Mike_Eitel
Replied by Mike_Eitel on topic How to connect Home switches for dual motor on 3 Axis machine [2.8 Pre Master]
Is your bob galvanic isolating,vor somehow restricting the signal to the port to 5 v?
- denhen89
24 Jan 2018 20:56 #104960
by denhen89
Actually i am not sure about that.Thats the BOB, but its in polish: www.ebmia.pl/plyta-glowna-sterowania-sskmb2-p-42777.html
I did change the output voltage to 11V for the switches. Tested, still same.
- Mike_Eitel
24 Jan 2018 20:57 #104961
by Mike_Eitel
Take a 1k resistor ( only for safety) and connect bob +5v to thr input, nothing else connected.
Do you see clear response in hal pin?
If yes regard sensor, If no try with other bob input.
If same behaviour, have a look to your sw, if not swear as you can suspect defective port hw.
- Grotius
- Thank you received: 2349
24 Jan 2018 21:02 #104962
by Grotius
Replied by Grotius on topic How to connect Home switches for dual motor on 3 Axis machine [2.8 Pre Master]
In Gmocappy there is a routine that read's the ini file.
If we have a routine that can write the ini file and the hal file....
Then we have no work anymore here....
Haha.
Haha.
- Clive S
- Thank you received: 486
24 Jan 2018 21:06 #104964
by Clive S
My experience with these proxy switch NPN generally have a 10K R inside that limits the current so although it might measure 15V tthe current will be small. I have many time used them on 24V without issue. But depending on the BOB they might need a pull up R as Rod suggested.
Replied by Clive S on topic How to connect Home switches for dual motor on 3 Axis machine [2.8 Pre Master]
- denhen89
24 Jan 2018 21:06 #104965
by denhen89
Mike, can i test it without the 1k resistor ? I dont have one here..
Grotius, actually i dont know what you try to say. I am an beginner, so if you like to help then it would be great if you could try to explain it for me.
- Mike_Eitel
24 Jan 2018 21:10 #104966
by Mike_Eitel
Found a difficult to read plan in your link. I'm quite sure that your inputs are isolated. You overload the opto coupler cny74-4 with 3 times higher current as foreseen, but i would not fear that. Gives you better noise reduction on the probably longer cables.
So swap the to sensors and look in halshow.
- Mike_Eitel
24 Jan 2018 21:11 #104967
by Mike_Eitel
Yes you need only wire
- Mike_Eitel
24 Jan 2018 21:16 #104968
by Mike_Eitel
Do you know how to use halshow?
Start your project, ha a look in the menus and choose halshow
Go to pin, then find your parport signals.....
Right side open the watch tab and cklick on left side on according pin .. so you see the status in the right window.
Time to create page: 0.116 seconds
