- Thank you received: 22
ubuntu 14.04.1 linuxcnc help
10 years 10 months ago - 10 years 10 months ago #66745
by tjmarch
Replied by tjmarch on topic ubuntu 14.04.1 linuxcnc help
Andy wrote
Which is what I will do then if Jedicut dose not work out
Gantry beam will be removable so CNC can be used as 4 axis foam cutting CNC. Foam cutting can be done with Linuxcnc but I want to try a windozes program called Jedicut, (opensource, freeware}. Jedicut dose not use gcode dose not require limit switches and will work over USB using a homemade USB to parallel port dongle that off loads timeing to arduino in dongle. VM has USB support so dongle will work. The advantage of Jedicut is there is no need for CAM software you go from drawing straight to CNC
Andy Thanks for your help
Tim
I think you can just create a stepconf configuration for each machine.
Tim
Last edit: 10 years 10 months ago by tjmarch.
10 years 10 months ago #66750
by tjmarch
Andy
One more question,
Stepconf dose not have choice for Gantrykins X, Y1, Y2, Z, A axise's setup.
So would I chose X,Y,Z, A in Stepconf and alter or
Just choose gantry-hs in Confiuration Selector and add A axis to INI file and HAL file
Tim
One more question,
Tim
10 years 10 months ago - 10 years 10 months ago #66752
by tjmarch
Andy
After thinking about it, I am guessing I will need to create confi's for both and combine some info form both config's
am I correct
Tim
am I correct
Tim
10 years 10 months ago #66754
You didn't say you wanted to use gantrykins....
To set things up per your drawing, you just allocate more than one parallel port pin to be Y-axis-step etc.
Replied by andypugh on topic ubuntu 14.04.1 linuxcnc help
tjmarch wrote: Stepconf dose not have choice for Gantrykins X, Y1, Y2, Z, A axise's setup.
10 years 10 months ago #66756
by tjmarch
Andy
I did mention Gantrykins in post:
forum.linuxcnc.org/forum/9-installing-li...help?start=110#66666
But that was not a direct conversation with you sorry about confusion
And Thanks for the help
Tim
Tim
10 years 10 months ago #66758
If you want to use Gantryjkins then I strongly recommend using the joints-axes branch.
forum.linuxcnc.org/forum/49-basic-config...ation?start=20#66683
tjmarch wrote: I did mention Gantrykins
