Testers Needed for New RTAI Packages
  • Bari
  • Bari's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Mar 2020 22:16 #161059 by Bari
Replied by Bari on topic Testers Needed for New RTAI Packages
Did you apply all 4 patches?
  • Bari
  • Platinum Member
  • Platinum Member
21 Mar 2020 22:20 #161060 by Bari
Intel replaced the mess that was BIOS with an even worse horrendous OS called EFI. Now we have to work with the garbage they force upon us.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
21 Mar 2020 22:37 #161062 by BeagleBrainz
Replied by BeagleBrainz on topic Testers Needed for New RTAI Packages
Sure did.
The only thing I've done differently is where I've been extracting the sources, instead of /usr/src, everything is done from a directory in my home directory. Even the linux link is within that structure. All the patches apply without error, and the build goes without error, packages build and install fine. As I said it all boots fine. When the rtai modules are built, after a reboot, everything builds without error, packages install fine and cd into the the testsuite directory the test runs without error.
Had the same thing with the -173 build but now on the -174 build.
So it looks like the RTAI may not be an option for boards that are a pure (without csm/legacy option) UEFI boot ?
  • Bari
  • Platinum Member
  • Platinum Member
21 Mar 2020 23:06 #161065 by Bari
Yes, for now.
Intel has had a better option for 20 years. They could have used coreboot/LinuxBIOS. But our PC's have to be secure from us so we have EFI.
  • BeagleBrainz
  • Visitor
  • Visitor
21 Mar 2020 23:13 #161066 by BeagleBrainz
Ok cool thanx.
The reason i thought it was a config issue on my behalf, sorry if I didn't make that clear, is generally I'll point blame at myself first before looking for others to blame.
22 Mar 2020 11:57 #161121 by andypugh
Replied by andypugh on topic Testers Needed for New RTAI Packages
www.linuxcnc.org/temp now contains a set of 4.14.174 packages for for kernel, rtai and linuxCNC.
This _should_ support i915 Intel graphics, unless I messed it all up.
22 Mar 2020 18:03 #161149 by phillc54
Replied by phillc54 on topic Testers Needed for New RTAI Packages
I am still restricted to 1024x768, do I need to install more than just the linux-image?
phill@buster:~$ uname -a
Linux buster 4.14.174-rtai-amd64 #2 SMP PREEMPT Sun Mar 23 14:26:24 GMT 2020 x86_64 GNU/Linux
phill@buster:~$ xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 1024 x 768, maximum 1024 x 768
default connected 1024x768+0+0 0mm x 0mm
   1024x768       0.00*
   800x600        0.00
   640x480        0.00
Boot to a console and try Xorg -configure:
modprobe: FATAL: module i915 not found in directory /lib/modules/4.14.174-rtai-amd64
  • BeagleBrainz
  • Visitor
  • Visitor
22 Mar 2020 18:19 #161151 by BeagleBrainz
Downloaded the package and it's not there.
If enabled in config it should be here
/lib/modules/4.14.174-rtai-amd64/kernel/drivers/gpu/drm/i915
I've built both -173 & -174 with intel i915.
On my test machine if I set it up for intel graphics the modules are loaded and I get full resolution. This is a T530 with Optimus disabled.
Only issue I have is the when booting using UEFI only one core is reported.....Legacy boot has both cores there. Trying to get an answer on the RTAI mailing list.
22 Mar 2020 19:10 #161155 by phillc54
This is the contents of my /lib/modules/4.14.174-rtai-amd64/kernel/drivers/gpu/drm/
amd ast bochs cirrus drm_kms_helper.ko drm.ko i2c mgag200 radeon ttm udl vgem
23 Mar 2020 15:19 #161269 by andypugh
I am a bit puzzled, but it does seem that the i915 support was not enabled. Also missing (and probably an annoyance only to me) was the VMWare support, which explains why the VM on my Mac has such low resolution.
I am building a new version.
Time to create page: 0.320 seconds
