Update help ---- PoKeys No moore
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 Jan 2021 10:46 #193855 by tecno
Update help was created by tecno
Description: Debian GNU/Linux 7.11 (wheezy)
I have one laptop to test things with, need to update but not finding where files are.
Want to test webcam in gmoccapy and need suitable videoplaer. Where to find correct path?
  • Moderator
  • Moderator
02 Jan 2021 11:45 #193861 by tommylight
Replied by tommylight on topic Update help
Wheezy is way past end of life, so anything regarding it will not be easy to find or install.
Manually downloading things might work:
pkgs.org/download/linux-image-generic
is just an example, search in the upper right corner.
If you want to update LinuxCNC, most probably it will not work as it uses the RTAI kernel, but give this a try:
linuxcnc.org/docs/2.8/html/getting-start...#cha:Installing-RTAI
  • tecno
  • Platinum Member
  • Platinum Member
02 Jan 2021 11:51 #193864 by tecno
Replied by tecno on topic Update help
Hello Toma, happy new year from Sweden.
Ahh it looks like it is best to upgrade directly to latest RT.
So what short do I take to upgrade OS and LCNC?
  • Moderator
  • Moderator
02 Jan 2021 12:48 #193871 by tommylight
Happy New Year and all the best wishes.
Official ISO is the easiest and quickest way:
linuxcnc.org/downloads/
The first link.
Regards,
Tom.
  • tecno
  • Platinum Member
  • Platinum Member
02 Jan 2021 13:58 - 02 Jan 2021 14:25 #193882 by tecno
So, installed 2.8.0
Still not able to update or install webcam
ABOVE FIXED Loose network cable
Last edit: 02 Jan 2021 14:25 by tecno.
  • Moderator
  • Moderator
02 Jan 2021 14:48 #193889 by tommylight
  • tecno
  • Platinum Member
  • Platinum Member
02 Jan 2021 16:10 #193895 by tecno
EMBED_TAB_NAME = Camera
EMBED_TAB_COMMAND = mpv /dev/video0 --wid {XID} --vf-add=drawbox=-1:2:-1:240:t=1 --vf-add=drawbox=2:-1:320:-1:t=1 --no-border
This is a bit complicated. Above works OK with the built in WebCam in my laptop but I cannot get my external Logitech 3000 to work with those settings.
The camera works with webcamoid where I can select cameras.
Even disabled built in camera and still no go.
Anybody to give me some hints here?
  • Moderator
  • Moderator
02 Jan 2021 16:49 #193897 by tommylight
02 Jan 2021 17:54 #193903 by phillc54
Replied by phillc54 on topic Update help
Have you tried the qtvcp camview?
There is a modified version here:
forum.linuxcnc.org/plasmac/40057-camera-...choff?start=0#182507
Although this one is more suited to plasma machines
  • tecno
  • Platinum Member
  • Platinum Member
03 Jan 2021 02:59 #193933 by tecno
#EMBED_TAB_COMMAND = mpv /dev/video0 --wid {XID} --vf-add=drawbox=-1:2:-1:240:t=1 --vf-add=drawbox=2:-1:320:-1:t=1 --no-border
EMBED_TAB_COMMAND = mplayer -wid {XID} tv:// -vf rectangle=-1:2:-1:240,rectangle=2:-1:320:-1
It works with MPLAYER. Have to do some tweaking as picture is way too dark.
Time to create page: 0.117 seconds
