Update help ---- PoKeys No moore
- ikkuh
- Thank you received: 48
08 Jan 2021 07:44 - 08 Jan 2021 07:48 #194488
by ikkuh
That's the route I took after a lot of problems. I switched soon to the buildbot version and only have self made problems now.
Gmoccapy is very current if you use the buildbot.
buildbot.linuxcnc.org/
There are certain problems with Debian 10 (Buster), you will have no problem getting mvp to work I think.
What touchscreen do you have? I have now a 23" Hanns-g and started out with a 17" General touch . Both work pretty good, the Hanns-g is more modern and worked straight out of the box and is controllable with the Debian touch screen software.
Replied by ikkuh on topic Update help
Think I will try latest ISO with Debian10.
Last edit: 08 Jan 2021 07:48 by ikkuh.
- tecno
- Thank you received: 127
08 Jan 2021 07:54 #194490
by tecno
Replied by tecno on topic Update help
Sorry but MrMurphy was on short visit.
So now there is no GRUB on this 128GB SSD
- ikkuh
08 Jan 2021 07:59 #194491
by ikkuh
Do not make it to hard for yourself. Boot from the LinuxCNC iso, use a SSD that can be overwritten and choose the install option.
linuxcnc.org/downloads/
- tecno
08 Jan 2021 08:25 #194493
by tecno
Only 2.5" hhd:s available.
re OS I need touch working so I will try latest Mint20
- tecno
08 Jan 2021 09:37 #194504
by tecno
sudo apt-add-repository 'deb buildbot.linuxcnc.org/ stretch 2.8-rtpreempt'
above syntax does not work
- ikkuh
08 Jan 2021 09:39 - 08 Jan 2021 09:43 #194506
by ikkuh
We can help you better if you give us the error message
Is this the problem?
Mint-apt vs Debian-apt
forums.linuxmint.com/viewtopic.php?t=269626
forums.linuxmint.com/viewtopic.php?p=147...4f003c1af28#p1470794
Mint still has two versions of apt - the Debian apt (usr/bin/apt) and a Mint apt python wrapper (usr/local/bin/apt). Unless you've messed with your $PATH or uninstalled the package mintsystem (which provides the mint apt) the latter has precedence when simply using apt in the terminal. To specifically run debian apt you need to use /usr/bin/apt in Mint.
Compare the output of
apt -h (Mint's apt python wrapper)
to
/usr/bin/apt -h (Debian apt)
Mint's apt brings various package management commands into one command. Under the hood it is still running the original commands.
e.g You can use apt showhold which actually runs apt-mark showhold or apt deb which actually runs sudo dpkg -i and asks you nicely for your password.
Similarly if you apt install it actually runs sudo /usr/bin/apt install and asks you nicely for your password..... :D
Last edit: 08 Jan 2021 09:43 by ikkuh.
- tecno
08 Jan 2021 09:59 #194509
by tecno
I can not install uspace too many dependencies missing etc
bengt@CNC3000:~$ sudo apt-get -y install linuxcnc-uspace
Läser paketlistor… Färdig
Bygger beroendeträd
Läser tillståndsinformation… Färdig
Några paket kunde inte installeras. Det kan betyda att du har begärt
en omöjlig situation eller, om du använder den instabila utgåvan
att några nödvändiga paket ännu inte har skapats eller flyttats
ut från ”Incoming”.
Följande information kan vara till hjälp för att lösa situationen:
Följande paket har beroenden som inte kan tillfredsställas:
linuxcnc-uspace : Beroende av: libboost-python1.62.0 men det kan inte installeras
Beroende av: libpython2.7 (>= 2.7) men det kommer inte att installeras
Beroende av: python2.7-glade2 men det kan inte installeras eller
python-glade2 men det kan inte installeras
Beroende av: python2.7-numpy eller
python-numpy men det kommer inte att installeras
Beroende av: python-gtksourceview2 men det kan inte installeras
Beroende av: python-gst-1.0 men det kan inte installeras
Beroende av: python-gtkglext1 men det kan inte installeras
Beroende av: python-configobj men det kan inte installeras
Rekommenderar: linuxcnc-doc-en men det kommer inte att installeras eller
linuxcnc-doc
Rekommenderar: python-pyqt5 men det kan inte installeras
Rekommenderar: python-pyqt5.qsci men det kan inte installeras
Rekommenderar: python-pyqt5.qtopengl men det kan inte installeras
Rekommenderar: python-pyqt5.qtsvg men det kan inte installeras
Rekommenderar: python-pyqt5.qtwebkit men det kan inte installeras
Rekommenderar: python-opencv men det kan inte installeras
Rekommenderar: python-rsvg men det kan inte installeras
Rekommenderar: python-dbus.mainloop.pyqt5 men det kan inte installeras
Rekommenderar: python-espeak men det kan inte installeras
Rekommenderar: espeak
Rekommenderar: pyqt5-dev-tools men det kommer inte att installeras
Rekommenderar: hostmot2-firmware-all men det kan inte installeras
Rekommenderar: linux-image-rt-amd64 men det kan inte installeras
E: Kunde inte korrigera problemen, du har hållit tillbaka trasiga paket.
Bygger beroendeträd
ut från ”Incoming”.
linuxcnc-doc
- ikkuh
08 Jan 2021 10:47 #194514
by ikkuh
It's not clear to me what instructions you are following and what you want to achieve.
All I know is you will go deep into the rabbit hole and will be frustrated. I know, I have been there.
I remember when I upgraded I ran dist-upgrade in stead of upgrade. This solved all the missing dependencies for me.
I have been using Debian for years, all my servers and even pc's use Debian. I am glad that I made the switch years ago.
I hope you can still use your machine now, even after all the problems. My advice is to order one or two SSD's, they are very cheap now. Use the LinuxCNC ISO and install onto the SSD. That way you have a decent version of operating system and you are supported by LinuxCNC in the future.
I read that Norbert is doing stuff with gmoccapy to make it even better. So maybe a little wait for the release of new gmoccapy?
- tecno
08 Jan 2021 11:35 #194521
by tecno
This what I am following now (the Mint 20 has no Preempt-RT) so I have to start once again.
The SSD has to wait as I am not made of money, I am on pension
Install Linux Mint 19.3
-Copy and paste these lines in terminal, one by one:
sudo apt update
wget http://ftp.us.debian.org/debian/pool/main/l/linux/linux-image-4.9.0-13-rt-amd64_4.9.228-1_amd64.deb
sudo gdebi linux-image-4.9.0-13-rt-amd64_4.9.228-1_amd64.deb
sudo apt-key adv --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E
-For Master version, unstable, still under development
sudo apt-add-repository 'deb http://buildbot.linuxcnc.org/ stretch master-rtpreempt'
-OR, not both.
-For 2.8 version, stable, to be current release
sudo apt-add-repository 'deb http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt'
sudo apt-get update
sudo apt-get -y install linuxcnc-uspacePlease Log in or Create an account to join the conversation.
- tecno
08 Jan 2021 12:21 #194525
by tecno
Is this correct Preempt-RT
bengt@CNC3000:~$ uname -a
Linux CNC3000 5.0.0-32-generic #34~18.04.2-Ubuntu SMP Thu Oct 10 10:36:02 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Time to create page: 0.212 seconds
