Update help ---- PoKeys No moore
- tecno
- Thank you received: 127
17 Jan 2021 04:46 #195646
by tecno
Replied by tecno on topic Update help ---- TOUCH
I am getting nowhere trying to install drivers.
So back to basics.
The touch screen works but is not calibrated to be useful.
My question is what calibrator to use and where put calibration data.
Help would be appreciated.
So back to basics.
bengt@CNC3000:/dev/input/by-id$ ls
usb-eGalax_Inc._USB_TouchController-event-if00 usb-Riitek_Micro_Keyboard-if01-event-mouse
usb-Riitek_Micro_Keyboard-event-if01 usb-Riitek_Micro_Keyboard-if01-mouse
usb-Riitek_Micro_Keyboard-event-kbd
bengt@CNC3000:/dev/input/by-id$The touch screen works but is not calibrated to be useful.
- Hakan
- Thank you received: 482
17 Jan 2021 05:54 #195650
by Hakan
Replied by Hakan on topic Update help ---- TOUCH
- tecno
17 Jan 2021 06:12 #195653
by tecno
Yes I have and can not get it to work.
- Thank you received: 7504
17 Jan 2021 08:47 #195667
Replied by tommylight on topic Update help ---- TOUCH
Does it work on Mint 19.3 ?
- tecno
17 Jan 2021 09:56 #195681
by tecno
Not tested
18 Jan 2021 03:20 #195760
Replied by andypugh on topic Update help ---- TOUCH
Try xinput-calibrator
sudo apt-get install xinput-calibrator
It appears as "Calibrate Touchscreen" in the menu.
- tecno
18 Jan 2021 03:46 #195762
by tecno
Done that but calibration data will not stick.
Have tried both ways saving to
/etc..... 99 conf
/usr......40 conf
Is it maybe so that the data should be somewhere else?
/etc..... 99 conf
/usr......40 conf
18 Jan 2021 04:03 #195763
I think that you can paste it straight in to Xorg,conf.
But by default I don't think that xorg,conf exists.
Xorg --configure
will set it up. But you apparently need to run that with X not running. I am not 100% sure how you do that, but I imagine that the internet knows.
Xorg --configure
- tecno
18 Jan 2021 05:36 #195769
by tecno
Well that did not work, the configure can not detect the USB touch.
18 Jan 2021 06:21 #195775
What is "the configure" ?
Time to create page: 0.129 seconds
