Update help ---- PoKeys No moore
28 Jan 2021 04:37 #196923 by andypugh
Replied by andypugh on topic Update help ---- HAL issues
I don't understand what you are saying.
The screenshot showed that jog counts was getting through.
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
28 Jan 2021 04:39 - 28 Jan 2021 08:15 #196924 by tecno
Replied by tecno on topic Update help ---- HAL issues
Now I think I got it what you are saying, correct?
# The Axis select inputs
#net mpg <= hm2_7i76e.0.7i73.0.1.input-03-not    ### This setting disables the MPG
#net mpg-x axis.x.jog-enable <= hm2_7i76e.0.7i73.0.1.input-06-not
#net mpg-y axis.y.jog-enable <= hm2_7i76e.0.7i73.0.1.input-05-not
#net mpg-z axis.z.jog-enable <= hm2_7i76e.0.7i73.0.1.input-04-not
net mpg-x joint.0.jog-enable axis.x.jog-enable <= hm2_7i76e.0.7i73.0.1.input-06-not
net mpg-y joint.1.jog-enable axis.y.jog-enable <= hm2_7i76e.0.7i73.0.1.input-05-not
net mpg-z joint.2.jog-enable axis.z.jog-enable <= hm2_7i76e.0.7i73.0.1.input-04-not
Last edit: 28 Jan 2021 08:15 by tecno. Reason: edit text
  • tecno
  • Platinum Member
  • Platinum Member
28 Jan 2021 08:16 #196941 by tecno
Replied by tecno on topic Update help ---- HAL/MPG Solved
MPG up and running.
28 Jan 2021 08:49 #196944 by andypugh
Replied by andypugh on topic Update help ---- HAL/MPG Solved
And what was the problem?
You could now consider using the 7i73 built-in encoders. Do you have a pin
hm2_7i76e.0.7i73.0.1.enc0.count ?
You can subsitute that anywhere that you now have encoder.0.count.
Then, if that works, remove the loadrt and addf for the software encoder counter.
  • tecno
  • Platinum Member
  • Platinum Member
28 Jan 2021 09:18 #196947 by tecno
Only place I have encoder.0.count is here
# The encoder output counts to the axis. Only the selected axis will move.
net encoder-counts <= encoder.0.counts >>>>>>>>>>>>>>>>>> so replace with hm2_7i76e.0.7i73.0.1.enc0.count
net encoder-counts => joint.0.jog-counts axis.x.jog-counts
net encoder-counts => joint.1.jog-counts axis.y.jog-counts
net encoder-counts => joint.2.jog-counts axis.z.jog-counts
What lodart/addf needs to be deleted? Any setp/set for hm2_7i76e.0.7i73.0.1.enc0.count?
28 Jan 2021 09:25 #196950 by andypugh
The loadrt / addf to remove are the ones related to encoder.0
But chck that hm2_7i76e.0.7i73.0.1.enc0 works first (ie, with halshow)
  • tecno
  • Platinum Member
  • Platinum Member
28 Jan 2021 09:33 - 28 Jan 2021 09:45 #196952 by tecno
Will check with HALSHOW first.
# Jog Pendant
loadrt encoder num_chan=1 >>>>>>>>>>>>>>>>>>>Delete
loadrt mux4 count=1
addf encoder.capture-position servo-thread>>>>>>>>Delete
addf encoder.update-counters servo-thread>>>>>>>>Delete
addf mux4.0 servo-thread
setp siggen.1.frequency 5
Last edit: 28 Jan 2021 09:45 by tecno. Reason: Edited to be correct ;)
28 Jan 2021 09:40 #196953 by andypugh
Keep the siggen, it flashes a light.
The following user(s) said Thank You: tecno
  • tecno
  • Platinum Member
  • Platinum Member
28 Jan 2021 09:44 #196955 by tecno
Once again Andy THANK YOU for your support !!
  • tecno
  • Platinum Member
  • Platinum Member
02 Feb 2021 12:32 #197462 by tecno
Replied by tecno on topic Update help ---- HAL to SIM
Is there a way for me to make a SIM version of my Mill config?
Want to play around with PoKeys55 on a remote MPG.
Time to create page: 0.566 seconds
