Update help ---- PoKeys No moore
06 Jan 2021 10:28 #194244 by tommylight
Replied by tommylight on topic Update help
Very nice, indeed.
Regards,
Tom.
The following user(s) said Thank You: tecno
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Jan 2021 11:49 #194384 by tecno
Replied by tecno on topic Update help
HELP HILFE
What is the easiest way to install 2.8 from 2.7.14.
(want to keep LM as Touch works = too much grey hair to do this once more ;) )
Have to do this to get Gmoccapy tool table to work.
07 Jan 2021 13:12 #194394 by tommylight
How did you end up with 2.7 on Linux Mint?
Is it RTAI or Preempt-RT? Type "uname -a" in a terminal to check.
If Preempt:
Open "software sources" from the "administration" menu
itsfoss.com/how-to-remove-or-delete-ppas-quick-tip/
notice the repo it is using and remove the existing LinuxCNC entry, it should say Stretch and if it does do:
sudo apt-add-repository 'deb buildbot.linuxcnc.org/ stretch 2.8-rtpreempt'
sudo apt-get update
sudo apt-get -y install linuxcnc-uspace
  • tecno
  • Platinum Member
  • Platinum Member
07 Jan 2021 13:30 #194396 by tecno
Long time since I struggled to get my Touch screens to work, only way was to take the long road with LM and at that time 2.7.8 upgraded to 2.7.14.
Running 7i76e so it must be Preempt-RT
Whynot Buster?
So LCNC must be removed not upgraded?
My HOME needs to saved right?
07 Jan 2021 14:00 #194403 by tommylight
Everything in Linux gets removed before upgrading, this is no windows/patch/over/patch/over/patch.....
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
Takes anything from 5 to 30 minutes to a fully installed Linux Mint/Preempt/LinuxCNC, after downloading, so do not worry about it, just make sure to backup the config.
  • tecno
  • Platinum Member
  • Platinum Member
07 Jan 2021 14:12 #194408 by tecno
A bit confused...
Is this ONLY LCNC or do you want me to install LM 19.3 ?
!!! I do not want to have TOUCH screen issues.
Do you think Debian10 can handle my older Touch screens?
Lathe and Milling machine both have LM + touch working
07 Jan 2021 15:17 #194420 by Mike_Eitel
Replied by Mike_Eitel on topic Update help
I would/will buy (ca 20-30$) a ssd. Copy your hd and then try on that.
So you can easy see if your touch is supported or not.
I have (some day in the future) the same procedure in front of me. Early strech and some oder 2.8 pre master. Touch was a pain in the...
Mike
  • tecno
  • Platinum Member
  • Platinum Member
07 Jan 2021 15:30 #194421 by tecno
Think I will try latest ISO with Debian10. I have a small 2.5 to test with.
Yes touch is a pain in the rear ;)
07 Jan 2021 17:31 #194433 by tommylight
My last post was to show that you do not have to worry as it is very easy to install it, the one before that was for upgrading.
The choice is yours.
On Mint most touch screens work, not so much on Debian.
07 Jan 2021 17:42 #194436 by tommylight
You can test if the touch screen works from a live session on a USB, then install if it works.
Time to create page: 0.374 seconds
