Update help ---- PoKeys No moore
02 Feb 2021 15:38 #197478 by Todd Zuercher
Replied by Todd Zuercher on topic Update help ---- HAL to SIM
Yes, but how easy it might be will depend on the hardware your simulating.
It is quite easy to simulate a parallel port config. (In fact Stepconfig has a check box for it.)
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 Feb 2021 15:54 #197480 by tecno
Replied by tecno on topic Update help ---- HAL to SIM
ETH = 7i76e + 7i85 + 7i73 and i want to add Pokeys
  • tecno
  • Platinum Member
  • Platinum Member
03 Feb 2021 13:51 #197590 by tecno
Is there a simple SIM config so I can play with, add PoKeys55.
Have installed
forum.linuxcnc.org/24-hal-components/298...keys?start=90#162953
X/Y/Z/A
x1, x0.1, x0.01
Analog Feed
Analog Speed
MPG
Would like to play with this with my laptop and not in relatively cold workshop.
Any help would be appreciated. (this MPG project started 2011 or so)
03 Feb 2021 17:22 #197606 by andypugh
Replied by andypugh on topic Update help ---- HAL to SIM
I would suggest starting with sim->axis->mm
Then try out your Pokeys additions to that, all in a new HAL file that is added to the INI file.
Then you can (probably) transfer that HAL file to your real machine.
  • tecno
  • Platinum Member
  • Platinum Member
04 Feb 2021 02:41 #197625 by tecno
OK, thanks Andy.
Is there any hal file to be found with PoKeys I/O's that I can have look at?
05 Feb 2021 04:46 #197719 by andypugh
Not in the sample configs. There might be something on the forum.
  • tecno
  • Platinum Member
  • Platinum Member
05 Feb 2021 12:39 #197765 by tecno
Replied by tecno on topic Update help ---- PoKeys HELP
Been poking around this hornets nest for a couple of days and I get nowhere except if I program matrix keys with macros as a keyboard key.
All functions I have in Win work but now in LCNC nothing!!!!!
ESTOP works in Win
2 analog 11-pos swithes work in Win
MPG works in Win
LCD and LED work in win
As step one I would like to get the easiest parts to work ESTOP and Analog.
06 Feb 2021 04:31 #197819 by newbynobi
Replied by newbynobi on topic Update help ---- PoKeys HELP
@tecno,
have a look in the gmoccapy Sim folder, there is a gmoccapy with simulated hardware like an mpg or even hardware button, so it might be a good start to build your own simulated hatdware.
Norbert
  • tecno
  • Platinum Member
  • Platinum Member
07 Feb 2021 06:13 #197910 by tecno
Replied by tecno on topic Update help ---- PoKeys No moore
I give up with Pokeys55 to LCNC
Time to create page: 0.179 seconds
