LinuxCNC on Raspberry Pi 5
- csutke
16 Jun 2024 15:48 #303113
by csutke
Replied by csutke on topic LinuxCNC on Raspberry Pi 5
Also, for anyone wanting to use a touchscreen with Pi5, know that the on screen keyboards seem to be completely unusable at the moment.
- csutke
17 Jun 2024 00:31 #303140
by csutke
Update:
Switching to X11 works MUCH better for Axis, but it still doesn't understand multitouch in the Axis preview.
Switching to X11 can be done by
1. Advanced => X11
2. I had to install the gldriver from here to get X11 to show output: askubuntu.com/questions/1501903/x11-sess...10-on-raspberry-pi-5
This also seems to have fixed the issues with the on-screen keyboard (onboard).
At this point it is a fully functional system, with some minor annoyances with navigating the preview window.
I will make a patch for Axis to try and address some of the touch bugs.
1.
raspi-config2. I had to install the gldriver from here to get X11 to show output: askubuntu.com/questions/1501903/x11-sess...10-on-raspberry-pi-5
- swepeter
- Thank you received: 3
05 Jul 2024 21:36 #304497
by swepeter
Replied by swepeter on topic LinuxCNC on Raspberry Pi 5
First of all thanks for the great work.
is it just me or is the link on the website wrong?
www.linuxcnc.org/iso/rpi-5-debian-bookwo...23-11-17-1520.img.xz
it say: LinuxCNC 2.9.2
but when I start it it say 2.9.1
I thought I had an older one so I reinstalled today and still the same.
Can I upgrade linuxCNC and GMOCCAPY?
i had some issues with GMOCCAPY now compared to when I was running the PI4 that I installed years ago.
One issue I had was when I pressed the aport button during a probing script, it did not stop but the GUI changed.
I will try to reproduce.
I copied my old config. Can that be the issue? I thought you could
github.com/swepeter/PrintNC
Thanks all
Thanks all
- timaer
- Thank you received: 4
24 Jul 2024 07:59 #305946
by timaer
Replied by timaer on topic LinuxCNC on Raspberry Pi 5
Hey,elovalvo,I've installed your image in my rasppi5 machine,but met a problem while I installed the linuxcnc-ethercat ,I cant run "sudo apt install -y linux-headers-$(uname -r) ethercat-master linuxcnc-ethercat",because I cant find the right kernel version of header,could you offered that ? Thank you
- elovalvo
- Thank you received: 127
26 Jul 2024 15:13 #306099
by elovalvo
Replied by elovalvo on topic LinuxCNC on Raspberry Pi 5
if you are using the image from this link
forum.linuxcnc.org/9-installing-linuxcnc...pi-5?start=40#303752
maybe they should already be installed.
I've never used Ethercat so I've never had this problem.
However you can see at this link
linuxconfig.org/how-to-install-linux-ker...ders-on-raspberry-pi
The following user(s) said Thank You: timaer
- timaer
27 Jul 2024 02:46 #306144
by timaer
Thank you so much ,that's very helpful.
- Krister
- Visitor
17 Oct 2024 16:44 #312410
by Krister
Replied by Krister on topic LinuxCNC on Raspberry Pi 5
Hi One problem solved and one remain ,I replaced the analog optical sensor to a "digital" one and the revolution meter start to work . the reading is ok and the reading is controled with a speedometer. the other problem is the red and green LED weryfing to start the process from the G-code program G97 S600 M3 The program start at 150 rpm and the red LED starts at 350 rev, it is mirror action , it should start at ca 450 and stopp at ca 700 revs ,it is programd with 150 % tolerans .
- msurmei
23 Nov 2024 09:07 #315090
by msurmei
Replied by msurmei on topic LinuxCNC on Raspberry Pi 5
Maybe it's useful info ...
i had to power the RPI5 using a normal 5V/10A DIN power supply. Manage to do it and keep 4.7V at 3.1 A , enough for RPI to avoid detection of an undervoltage condition.
But then I was curios about the official RPI power supply ... and I have tested it with an electronic load: I've got the same voltage ( around 5.14V) from 0.5A up to 5.9 A .. at 6A it shuts itself down nice and safely ).
I think the official power supply is dinamically compensating the cable impedance by increasing the output voltage from the regulator based on measured current .
So if you need 5A , be very careful with the cable or just use the official power supply , if possible ...
All of these where done with PD disabled ( a small USB-C breakout board with 5.11kohm on CC lines)
- lblabr
01 Dec 2024 09:05 #315717
by lblabr
Replied by lblabr on topic LinuxCNC on Raspberry Pi 5
Hi everyone!
i'm quite new to linuxcnc and have some basic knowledge about linux, i don't want to compile a kernel and that stuff, installing specific packages are nit a problem...
at the moment i'm using a raspi 5 image from linuxcnc download page.
I have some resolution problems with my 7" touchpad, it loads the one and only available resolution 1920x...
i would like to have another resolution, my problem is that the "normal" things for raspi do not worl with debian image.
2 Questions:
- how do i do that with the linuxcnc debian image ?
- should i switch to the image provided here with raspios ?
i'm using the raspi together witth mesa ethernet card
thanks a lot
Lars
2 Questions:
thanks a lot
Lars
- Thank you received: 7386
01 Dec 2024 13:15 #315729
Replied by tommylight on topic LinuxCNC on Raspberry Pi 5
In a terminal, what does
xrandr
Return for available resolutions?
xrandr
Time to create page: 4.672 seconds
