LinuxCNC on Raspberry Pi 5
- Thank you received: 4008
10 Dec 2024 07:14 #316378
Replied by rodw on topic LinuxCNC on Raspberry Pi 5
Pleas use Balena Etcher instead of the Pi Imager if you can't burn an image. It is much more reliable
- resmond
- Thank you received: 3
12 Dec 2024 13:32 #316514
by resmond
Replied by resmond on topic LinuxCNC on Raspberry Pi 5
Thanks for getting back to me.
I wanted to that that I got the image to burn onto a card through random internet searches / and re-try's. I'm sure we are all familiar with middle of the night stubbornness. LOL
Once burned the image seemed quite quite good to me with the caveat that my next step will be to get my 7i95T board configured so I haven't yet tested end-to operation.
I used saved versions of all the raspberypi.org and raspbian.org config files for apt including the keyring files that are needed. So it was quick to update/upgrade/apt install a reasonable collection of Pi specific config tools.
So thanks for making that image available.
I do have a few questions/hopes about embedding some of those tweaks into the Pi 4/5 specific IMG's.
1) Include the Pi specific APT/PGP files on the conditional build you are using for the Pi.
2) Include the core Pi executables as well with serious bonus points for adding those to the default app-lauch UI like is being done for LinuxCNC.
Those two things would substantially reduce the newbie headwinds for those that are either new or rusty on Linux.
Thanks so much for all your work!
Richard
Richard
12 Dec 2024 17:45 #316532
The builder we have forked is based on Debian, not Rpi but we do fetch and build the Rpi kernel from source.
That way you get the best of both worlds.
Linuxcnc is a Debian application so all the menu features are installed from Linuxcnc deb files.
Its not intended as a generic Rpi installation so it won't include any standard pi applications which could add additional latency.
- Thank you received: 425
14 Dec 2024 04:56 #316624
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Just checked out your new image that you linked a couple of posts ago. Video works ok when using min hdmi to DVI adapter.
Just for those of us that are a bit silly what is the correct procedure & values to setup
1: LANGAUGE (currently unset)
2: LC_ALL (currently unset)
LANG = "en_AU.UTF-8" is fine.
Currently starting to test the new hm2_spix driver
14 Dec 2024 05:11 #316625
14 Dec 2024 06:10 #316626
Doesn't have an option for setting LANGUAGE.
Had to use
Then log out and login for it to take effect.
Had to use
sudo update-locale LANGUAGE="en_AU:en"Then log out and login for it to take effect.
14 Dec 2024 06:35 #316628
The default settings come from userdata.txt github.com/rodw-au/rpi-img-builder-lcnc/...9.3/userdata.txt#L40
I.m not sure LANGUAGE needs to be set for the locale if its en_US.UTF-8 as we use for the default config
On my chrome book, locale reports
rod@penguin:~$ locale
LANG=en_US.UTF-8
LANGUAGE=
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
On my Debian PC in my office, I get
rod@debian:~$ locale
LANG=en_AU.UTF-8
LANGUAGE=en_AU:en
LC_CTYPE="en_AU.UTF-8"
LC_NUMERIC="en_AU.UTF-8"
LC_TIME="en_AU.UTF-8"
LC_COLLATE="en_AU.UTF-8"
LC_MONETARY="en_AU.UTF-8"
LC_MESSAGES="en_AU.UTF-8"
LC_PAPER="en_AU.UTF-8"
LC_NAME="en_AU.UTF-8"
LC_ADDRESS="en_AU.UTF-8"
LC_TELEPHONE="en_AU.UTF-8"
LC_MEASUREMENT="en_AU.UTF-8"
LC_IDENTIFICATION="en_AU.UTF-8"
LC_ALL=
LANG=en_US.UTF-8
LANGUAGE=
LC_ALL=
LANG=en_AU.UTF-8
LANGUAGE=en_AU:en
LC_ALL=
14 Dec 2024 08:55 #316632
Perl complains if LC_ALL or LANGUAGE isn't set.
14 Dec 2024 10:18 #316636
Why on earth are we using perl in a Linuxcnc project? What's wrong with Python? At least its supported by the project.
14 Dec 2024 11:08 #316638
Debian dpkg-buildpackage uses perl, perl complains when running menu-config without LANGUAGE set.
So perl hasn't anything to do with Linuxcnc but when building packages, I had to build linuxcnc to have the hm2_spix driver for the Rpi5.
Time to create page: 2.063 seconds
