LinuxCNC on Raspberry Pi 5
  • Platinum Member
  • Platinum Member
22 Dec 2023 10:52 #288817 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
If it's Rod's image can you change the resolution and does it identify the display\monitor? From what I've seen it's stuck at a single resolution and it can't identify the dsiaplay as the RPi4 images can.
22 Dec 2023 19:57 #288840 by flyingbrick
Replied by flyingbrick on topic LinuxCNC on Raspberry Pi 5
Hi mate.
Yes, this seems to function fine, resolution changes when settings modified as per this image attached.
I am using image Lcnc210_pi5 within image_pi5_rt.zip shared earlier by elovalvo
22 Dec 2023 20:00 #288842 by flyingbrick
If you need me to install rods image to check the same thing, this is no problem.
22 Dec 2023 20:20 #288843 by rodw
Replied by rodw on topic LinuxCNC on Raspberry Pi 5
Yes, my image uses debian so it won't have the pi specific menu options.. Some settings can be changed using  sudo menuconfig.
But if you could try adding
video=HDMI-A-1:1920x1080M@60D
to cmdline.txt or equivalent, It would be helpful. If it works, I can add it to the installer.
Its still a pain because the Pi 5 needs to be at the bleeding edge of the raspberry kernel and the PREEMPT_RT is lagging behind that.
  • Platinum Member
  • Platinum Member
22 Dec 2023 20:59 #288844 by Cant do this anymore bye all
Hi mate.
Ok looks like that might be based on a official Raspberry Pi image. Is there just one panel at the top ?
22 Dec 2023 22:26 - 22 Dec 2023 22:27 #288850 by flyingbrick
Yeap. I have one of these on the way
shop.pimoroni.com/products/nvme-base?variant=41219587178579
Edit. I find this the most awkward forum when replying to people.
Last edit: 22 Dec 2023 22:27 by flyingbrick.
  • Platinum Member
  • Platinum Member
23 Dec 2023 00:48 #288853 by Cant do this anymore bye all
The following user(s) said Thank You: flyingbrick
  • Platinum Member
  • Platinum Member
23 Dec 2023 01:00 - 23 Dec 2023 01:08 #288854 by Cant do this anymore bye all
Latest RPi production kerenl (2023-12-05) is Linux kernel 6.1.63 for the most recent Raspberry OS Image,latest 6.1 series RT is 6.1.67, so it would not seem that the RPi 5 does not need a "bleeding edge" kernel, it's just there is a mismatch between latest RPi production kernel and the latest rt-preempt. If anything the preferred RPi kernel is behind the rt-preempt patch.
www.raspberrypi.com/software/operating-s...spberry-pi-os-64-bit
In actual fact the latest 64 bit image is the same for all models. After running a self (same recipe) made image for the RPi5 and using the official image and installing a RT kernel & linuxcnc, the official image appears to be a more "smoother & integrated" experience for the 5, tho I did change from Wayland to X so I could run a xfce desktop. The pre made images for the 4 are fine.
Although in saying that Rod if you have sources of info to the contrary I'd be quite happy to see it and amend my answer.
Last edit: 23 Dec 2023 01:08 by Cant do this anymore bye all.
23 Dec 2023 02:15 #288859 by flyingbrick
Yeah it was a toss up between the pineberry and the one I got. I chose mine because it was cheaper and had a cool design on the back haha, plus the company is a bit older.
The following user(s) said Thank You: Cant do this anymore bye all
23 Dec 2023 04:47 #288862 by flyingbrick
Re:one panel at the top.. not entirely sure what you mean but I think you are right
Time to create page: 0.178 seconds
