LinuxCNC on Raspberry Pi 5
14 Feb 2024 22:08 #293352 by RNZ
Replied by RNZ on topic LinuxCNC on Raspberry Pi 5
I think this is particularly concerning. The ethernet connection just seems unstable. As pointed out, there simply should not be packet loss.
I will try replacing the Pi 5 with a PC tomorrow to trying eliminating the 7i96s as part of the problem.
cnc@linuxcnc:~/Downloads/7i96s/configs/hostmot2$ sudo chrt 99 ping -i .001 -q 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
7234 packets transmitted, 7233 received, 0.0138236% packet loss, time 7240ms
rtt min/avg/max/mdev = 0.101/0.106/0.132/0.002 ms
15 Feb 2024 00:14 - 15 Feb 2024 00:54 #293358 by RNZ
Replaced RPi 5 with HP desktop running LinuxCNC 0.29.1, connected to 7i96s over CAT6 cable.
Quick test shows 0% packet loss for 40,000 packets.
And a longer test:
2312351 sent, 2312350 received  <<<<<<<  Loss of 1 packet
rtt min/avg/max/mdev = 0.177/0.266/0.455/0.019 ms
Last edit: 15 Feb 2024 00:54 by RNZ.
  • Platinum Member
  • Platinum Member
15 Feb 2024 01:53 #293360 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Seems ATM the RPi5 isn't the best candidate for Linuxcnc.
15 Feb 2024 21:30 #293439 by PCW
Replied by PCW on topic LinuxCNC on Raspberry Pi 5
Here's half a days worth of pinging a 7i96S on a Intel PC:
^C--- 10.10.10.10 ping statistics ---
72908387 packets transmitted, 72908387 received, 0% packet loss, time 72908386ms
rtt min/avg/max/mdev = 0.067/0.082/0.361/0.010 ms
15 Feb 2024 23:24 - 15 Feb 2024 23:25 #293464 by RNZ
This command FOLLOWED BY CTRL+C consistently leads to a single dropped packet in about 50% of runs. Perhaps this is happening due to the Ctrl+C causing the code to exist a loop somewhere while not awaiting the last packet to return from the 7i96s...?
sudo chrt 99 ping -O -i .001 -q 10.10.10.10
569 packets transmitted, 568 received, 0.175747% packet loss, time 568ms
1400 packets transmitted, 1399 received, 0.0714286% packet loss, time 1400ms
320 packets transmitted, 319 received, 0.3125% packet loss, time 319ms
Changing to
sudo chrt 99 ping -O -i .001 -q 10.10.10.10 -c 500
where the -c 500 causes the ping code to exit after 500 cycles consistently (100%) results in 0% packet loss (ca. 20 attempts).
Last edit: 15 Feb 2024 23:25 by RNZ.
15 Feb 2024 23:42 #293465 by PCW
Probably not important, bu I cannot duplicate that:
pcw@pcw-HP-Compaq-Elite-8300-USDT:/proc/irq/25$ sudo chrt 99 ping -i .001 -q 10.10.10.10
^C
532 packets transmitted, 532 received, 0% packet loss, time 531ms
rtt min/avg/max/mdev = 0.073/0.083/0.110/0.006 ms
^C
500 packets transmitted, 500 received, 0% packet loss, time 499ms
rtt min/avg/max/mdev = 0.071/0.083/0.116/0.006 ms
^C
1143 packets transmitted, 1143 received, 0% packet loss, time 1142ms
rtt min/avg/max/mdev = 0.072/0.083/0.111/0.006 ms
^C
908 packets transmitted, 908 received, 0% packet loss, time 906ms
rtt min/avg/max/mdev = 0.073/0.083/0.114/0.006 ms
^C
565 packets transmitted, 565 received, 0% packet loss, time 564ms
rtt min/avg/max/mdev = 0.072/0.083/0.114/0.006 ms
^C
421 packets transmitted, 421 received, 0% packet loss, time 420ms
rtt min/avg/max/mdev = 0.072/0.083/0.112/0.006 ms
^C
332 packets transmitted, 332 received, 0% packet loss, time 331ms
rtt min/avg/max/mdev = 0.073/0.084/0.116/0.007 ms
^C
381 packets transmitted, 381 received, 0% packet loss, time 380ms
rtt min/avg/max/mdev = 0.072/0.084/0.112/0.007 ms
^C
588 packets transmitted, 588 received, 0% packet loss, time 587ms
rtt min/avg/max/mdev = 0.073/0.083/0.120/0.006 ms
^C
484 packets transmitted, 484 received, 0% packet loss, time 483ms
rtt min/avg/max/mdev = 0.073/0.084/0.122/0.007 ms
^C
452 packets transmitted, 452 received, 0% packet loss, time 451ms
rtt min/avg/max/mdev = 0.073/0.084/0.109/0.006 ms
  • Moderator
  • Moderator
15 Feb 2024 23:42 #293466 by tommylight
Replied by tommylight on topic LinuxCNC on Raspberry Pi 5
Try another keyboard.
16 Feb 2024 00:00 #293467 by RNZ
LOL wasn't sure whether you were having me on or not... anyways, I unplugged the wireless KB/mouse dongle and replaced it with a wired KB....... the 1x dropped packet issue remains. Weirdy.
  • Moderator
  • Moderator
16 Feb 2024 00:05 #293468 by tommylight
Booting from MicroSD or NVME?
If first, try a different one, if you can.
Or a USB stick...
If NVME, skip the above.
Also, in a terminal
sensors
should show temperatures, if the processor is above 60-65C, slap some cooling on it.
16 Feb 2024 00:15 - 16 Feb 2024 00:16 #293470 by RNZ
So....... this morning the Pi 5 has been quite stable in terms if ethernet comms. I might naively be thought to have caused this because I added 1x 0.1 uF and 1x 47 uF/16 V electrolytic capacitor across the blue terminal block (photo a couple of pages back) which is across the +5V / 0V rail.
I did this for a few reasons. First, because yesterday I plugged in the 7i96s while the Pi was running which may have caused the Pi to reset. Possibly the voltage at the Pi dipped due to 7i96s capacitance. I don't know if the Pi has any decent amount of power supply capacitance -- perhaps it is hidden under the heatsink (not a good place for electrolytic capacitors to live).
Second, the 5V/3A Meanwell PSU datasheet does not specify the output capacitance (or stability if you add capacitance). But in any case, the resetting of the Pi could suggest it doesn't have a lot of output capacitance.
Third, the 5V rail wiring is a bit long and all over the place, so could be picking up noise from other appliances, so this could suppress it a bit.
I also raised the Meanwell 5V rail voltage from 5.0 to 5.1V at the PSU terminals. Voltage drop in the wiring is about 100 mV according to my dodgy DMM, thus perhaps the rail was causing instability.
Well, things were quite stable, so I reversed all of the above and things are still stable !!! I can repeatedly send 50,000 packets with 1 ms spacing and get 0% loss.
Last edit: 16 Feb 2024 00:16 by RNZ.
The following user(s) said Thank You: rdtsc
Time to create page: 0.589 seconds
