LinuxCNC on Linux Mint Debian Edition 6
3 years 3 weeks ago #282458 by scotth
I have one problem. After install, everything loaded and worked fine. I needed to go back and look at a few things on mint 21.2, swapped drives and mint 21.2 ran fine. The problem is I can't get Linux Mint Debian Edition 6 to boot again. No problem with 21.2. I see the same problem with bookworm. LinuxCNC run's no problems there.
This is the problem I see on the HP 8300.
3 years 3 weeks ago #282475 by tommylight
I switch drives daily and often, sometimes several times a day, never had any issue with booting, but that does not help you, so
-were the two hard drives connected at the same time?
-did you update/upgrade Mint while it was on
-do you have "secure boot" enabled? Disable this, now and always. :)
if all of those are "no", then check the wiring first and foremost, SATA connectors can be inserted backwards, after braking the little tab that does not take much effort.
Then check the BIOS to see if the drive is enabled, on HP press F11 (not sure) at power on to bring the "boot menu" and see if the hdd/ssd is listed there.
3 years 3 weeks ago #282480 by scotth
Tommy,
No, I unplug the other drive while building a system.
No, I did the upgrade with no extra drives on the system.
No secure boot, although I tried with it on also, no joy.
The old 21.2 boots no problem though.
I will look tomorrow on F11. The boss has plans for me tonight.
3 years 3 weeks ago #282568 by tommylight
Had the Dell Optiplex 980 wired to Mesa 7i92 for 2 full days running gcode, works fine, no dropped links or latency issues at all.
The following user(s) said Thank You: my1987toyota, GeckoWorks
3 years 3 weeks ago #282707 by my1987toyota
If by some miracle I get some time to try it on one of my Dell Optiplex 9020 SFF I will give it a shot  image missing /media/kunena/emoticons/smile.png
3 years 3 weeks ago #282708 by tommylight
Off topic:
Toyota, how's the recovery going?
Time to create page: 0.263 seconds
