@ tommylight .... precisely:
after install LMDE6 from linux mint sites need to do almost one of these two steps
sudo apt install linux-image-rt-amd64
and you'll get the default real-time 6.1 kernel
sudo apt install -t bookworm-backports linux-image-rt-amd64
and you'll get the latest available from backports.
After you can use apt for install linuxcnc 2.9.0 or other packages using gedbi install only .... not test on 2.10 version ... but in 2.9.0, 2.9.1 and 2.9.2 only.
in my case isol cpu get bad result .... but set grub in these way:
GRUB_CMDLINE_LINUX_DEFAULT="-original paramters- intel_idle.max_cstate=0 processor.max_cstate=0 idle=poll"
I improve to 40% more or less the latency performances with sdev to 2,3 istead of 4,1 ...
And I'm not disable audio and vt-x from bios .....
@cornholio ... don't worry.... the fact is that I'm always under pressure.... sometimes I can't be sociable...once many years ago I had a helmet like that..... now one with the star like us navy.... but it's been on a shelf for a few years.
.... by the way, how come on dmax there are all these Australians looking for gold in the red lands? I've been seeing these things in the evening for two Saturdays already.... they've intrigued me.... not so much about the gold.... so much about digging up dirt in places that aren't exactly my Alps. Is these so usual or fashionable? or only a tv show?
P.S. terrible these new wisiwig on forum .....
