LinuxCNC on Linux Mint Debian Edition 6
- Thank you received: 7478
11 Mar 2024 00:19 #295609
That is the shared portion of the SystemD trying to get replaced, SystemD runs pretty much everything on Linux.
Replied by tommylight on topic LinuxCNC on Linux Mint Debian Edition 6
Did not make a fuss about this the first round, but if you do get this again, reinstall Linux.
systemd : Depends: libsystemd-shared (= 252.22-1~deb12u1) but version 252.12-1~deb12u1 is about to be installed
- phillc54
- Thank you received: 2100
11 Mar 2024 02:11 #295613
by phillc54
Replied by phillc54 on topic LinuxCNC on Linux Mint Debian Edition 6
Not if you use Devuan.That is the shared portion of the SystemD trying to get replaced, SystemD runs pretty much everything on Linux.
11 Mar 2024 15:26 #295640
Devuan is still using SystemV, and deserve respect for not complying to the mess with SysD.
The following user(s) said Thank You: phillc54, zu4lu
- bkt
- Thank you received: 114
13 Mar 2024 22:16 #295859
by bkt
Replied by bkt on topic LinuxCNC on Linux Mint Debian Edition 6
I think the problem comes from package 2.9.2 which searches for an older version of lib systemD.... I have installed LMDE6 latest version... which evidently brings an updated systemD.... if I can spend my two cents.. .. if one criticism can be made of open sources it is the fragmentation .... it is not logical .... it is like throwing oneself to the multinationals .... well I will never understand this .... but at my home They say that the world is beautiful because it is varied... so I look at the beauty...
bkt
bkt
- Thank you received: 426
14 Mar 2024 00:37 #295862
Replied by Cant do this anymore bye all on topic LinuxCNC on Linux Mint Debian Edition 6
Kinda interesting as like I said I never came up against these issues, maybe Mint updated the ISO. Everything went smooth, even allowing for the change from a RTAI version to a uspace version.
Maybe the goblins are at play. The same ones that are pulling the hair from my head through my nose and ears.
- bkt
15 Mar 2024 06:58 #295939
by bkt
aha aha
15 Mar 2024 09:20 - 15 Mar 2024 10:16 #295946
Where did you get the LinuxCNC 2.9.2 deb?
There are two repos with it (were) and they are/were not the same, the one on highlab server should work.
Link
forum.linuxcnc.org/9-installing-linuxcnc...-of-linuxcnc?start=0
Link
Last edit: 15 Mar 2024 10:16 by tommylight.
The following user(s) said Thank You: bkt
- bkt
15 Mar 2024 10:12 - 15 Mar 2024 10:17 #295949
by bkt
@ tommylight .... from linuxcnc download .deb file .... not remember exactly ... not for sure from .... but think exactly from here: linuxcnc.org/downloads/ .... not for sure from packages.debian.org or ftp.debian.org/debian/pool/main/l/linuxcnc/ .... but think at least that page point directly to ftp.debian ... right?
any how restart to install LMDE6 dowloaded from Linux Mint page (linuxmint.com/download_lmde.php) .... actually I use these (uname -a):
is right these?
Linux mint 6.1.0-12amd64 #1 SMP PREEMT_DYNAMIC Debian 6.1.52-1 (2023-09-07) x86_64 GNU/Linuxis right these?
Last edit: 15 Mar 2024 10:17 by bkt.
15 Mar 2024 10:19 #295950
How did you get that kernel?
Install LMDE6 again, no idea where and how are you installing things, but doing random things and expecting stuff to work, usually does not work.
- bkt
15 Mar 2024 12:26 #295955
by bkt
if you use my link you obtain that kernel ..... linuxmint.com/download_lmde.php .....
So where can dowload LMDE6 with right kernel for Lcnc 2.9.2??
Time to create page: 0.476 seconds
