- Thank you received: 4153
based on my dmesg I can see enp3s0 go down than go up .... and when go down master stop to work until unp3s0 link go up again .... not see I use enp1s0 at all really .... plus I add a new image about desktop warning about enp3s0 (and 2 image for show you mac adress is the same I write on config)What NIC are you using for ethercat? Is the MAC address set correctly in this file?
Check the MAC Address with ip a
Your file mentions enp3s0 but thats not what you are using based on dmesg
you caught me, I'm doing other experiment other these where try to use these little pc with realtek port, so i need it .... having said this, it has nothing to do with the fact that enp3s0 is not working properly.... in fact that is enp1s0.you own a registered public IP address.
