LinuxCNC on Linux Mint Debian Edition 6
2 years 6 months ago #298676 by rodw
change your compiler parameters so warnings are not treated as errors. There should be a environment variable you can set.
2 years 6 months ago #298701 by bkt
Really after these error realeck begin to not recognise from SO .... so not work at all. These installation is definitely dead.
2 years 5 months ago #301539 by song_gy
Hi bkt
I'm also trying to install ethercat on LMDE6 but I can't get started. The process I went through is the same as what you found on the forum.
Unable to locate package ethercat-master
Unable to locate package libethercat-dev
Can you share your experience and specific steps for successful installation?
Thank you so much!
2 years 3 months ago #305056 by bkt
sorry for late ... need to read from these point ... forum.linuxcnc.org/9-installing-linuxcnc...n-edition-6?start=20 ..... not remember where but at some point I have the same issue ... but if read post from that point fo sure you find my solutions .... seems need to install some dependancy .... find it using debian package command
1 year 11 months ago - 1 year 11 months ago #315034 by Stanislavz
Hello. Just tried to update to this version from older linux mint - i am not able to set up isolcpus. Tried editing grub file in etc/default, creating new file in grub.d - still no luck. And run update-grub of course. How to add it and test before reboot ?
Or this one is wrong version for parport ?
Last edit: 1 year 11 months ago by Stanislavz.
1 year 11 months ago #315041 by tommylight
For parallel port use the Wheezy ISO from the downloads page.
Time to create page: 0.415 seconds
