LinuxCNC on Linux Mint Debian Edition 6
2 years 7 months ago - 2 years 7 months ago #295946 by tommylight
Where did you get the LinuxCNC 2.9.2 deb?
There are two repos with it (were) and they are/were not the same, the one on highlab server should work.
Link
forum.linuxcnc.org/9-installing-linuxcnc...-of-linuxcnc?start=0
Last edit: 2 years 7 months ago by tommylight.
The following user(s) said Thank You: bkt
2 years 7 months ago - 2 years 7 months ago #295949 by bkt
@ tommylight .... from linuxcnc download .deb file .... not remember exactly ... not for sure from .... but think exactly from here: linuxcnc.org/downloads/ .... not for sure from packages.debian.org or ftp.debian.org/debian/pool/main/l/linuxcnc/ .... but think at least that page point directly to ftp.debian ... right?
any how restart to install LMDE6 dowloaded from Linux Mint page ( linuxmint.com/download_lmde.php ) .... actually I use these (uname -a):
Linux mint 6.1.0-12amd64 #1 SMP PREEMT_DYNAMIC Debian 6.1.52-1 (2023-09-07) x86_64 GNU/Linux
is right these?
Last edit: 2 years 7 months ago by bkt.
2 years 7 months ago #295950 by tommylight
How did you get that kernel?
Install LMDE6 again, no idea where and how are you installing things, but doing random things and expecting stuff to work, usually does not work. :)
2 years 7 months ago #295955 by bkt
if you use my link you obtain that kernel ..... linuxmint.com/download_lmde.php .....
So where can dowload LMDE6 with right kernel for Lcnc 2.9.2??
2 years 7 months ago #295956 by bkt
at least I install with these kernel (linuxmint.com/download_lmde.php ) "not usual" If I understand well tommylight for test an N95 board .... result is ridicolus .... so think something is really wrong ....
2 years 7 months ago #295957 by bkt
need to try with other rt-preempt kernel ...
Time to create page: 0.458 seconds
