LinuxCNC on Linux Mint Debian Edition 6
2 years 11 months ago #285938 by rodw
And there area way to install ethercat with apt ... or need the usual dowload of iegh file and install ethercat glue?
Yes, there is as etherlabmaster now maintain their own third party repository which includes the linuxcnc driver.
This is all set up for you in the official debian bookworm version
try this
echo "Install ethercat repository" sudo mkdir -p /usr/local/share/keyrings/ wget -O- https://build.opensuse.org/projects/science:EtherLab/signing_keys/download?kind=gpg | gpg --dearmor | sudo dd of=/etc/apt/trusted.gpg.d/science_EtherLab.gpg tee -a /etc/apt/sources.list.d/ighvh.sources > /dev/null <<EOT Types: deb Signed-By: /etc/apt/trusted.gpg.d/science_EtherLab.gpg Suites: ./ URIs: http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/ EOT
Then run the apt install commands in my ethercat sticky.
The following user(s) said Thank You: tommylight, bkt
2 years 7 months ago #295511 by bkt
so finally I try to use LMDE 6 .... I have a little bit time .... I try to install new 2.9.2 ..... first problem .... long list of fix broken dependancy ..... but problematic one is these:
systemd : Depends: libsystemd-shared (= 252.22-1~deb12u1) but version 252.12-1~deb12u1 is about to be installed
think no one appreciate a downgrtade of library .... how can fix these?
2 years 7 months ago #295514 by tommylight
AFter installing LMDE6:
sudo apt update
sudo apt upgrade
sudo apt install linuxcnc-uspace
That always works, although it does install a bit older build of LinuxCNC.
2 years 7 months ago #295589 by bkt
try to do whay you suggest ... but result was lcnc version 2.9.0 ,,,, that is not desired ....
2 years 7 months ago #295598 by tommylight
2 years 7 months ago #295604 by Cant do this anymore bye all
I have a VM running LMDE, was setup for RTAI, removed the RTAI stuff the other night and no issues installing a RT kernel & 2.9.2 uspace.
Time to create page: 0.079 seconds
