LinuxCNC on Linux Mint Debian Edition 6
2 years 7 months ago #296093 by bkt
about video .... is random .... i've not a preferred music in particular ..... but i've some type of preferred snow image missing /media/kunena/emoticons/wink.png
2 years 7 months ago - 2 years 7 months ago #296482 by bkt
[color=#e74c3c]E: [/color]Unable to locate package ethercat-master [color=#e74c3c]E: [/color]Unable to locate package libethercat-dev
seems not able connect repository .... what the name of right repositories for these two libs? so I can add to my list .... using command or adress of rodw obtain only these messages at least .... and ethercat was not installed with Lcnc 2.9.2 deb package ....
git clone gitlab.com/etherlab.org/ethercat.git ethercat-master fatal: repository 'gitlab.com/etherlab.org/ethercat.git' does not exist
Last edit: 2 years 7 months ago by bkt.
2 years 7 months ago #296483 by bkt
so ok ... git repo was moved to HTTPS ..... clone it .... but after bootstrap i obtin these error:
./bootstrap: line 40: autoreconf: command not found
and process stop without ./configure file made ready.
2 years 7 months ago #296485 by bkt
repo is moved to HTTPS ... so now can clone it ... easy solve ... but now I have these problem:
~/ethercat-master$ ./bootstrap + touch ChangeLog + mkdir -p m4 + autoreconf -i ./bootstrap: line 40: autoreconf: command not found
2 years 7 months ago #296486 by bkt
easy solution:
sudo apt-get install autoconf after need to install
sudo apt-get install libtool now hope all is solve ....
2 years 7 months ago #296487 by bkt
unfortunately i receive these error during make all modules step:
make[2]: Entering directory '/home/ich/ethercat-master/tool'
  CC       ../master/soe_errors.o
  CXX      ethercat-Command.o
during IPA pass: cp
Command.cpp:532:1: internal compiler error: Segmentation fault
  532 | }
0x1afaeb6 internal_error(char const*, ...)
    ???:0
so I use wrong version? i use stable-1.5 ... need to use stable-1.6 ??
Time to create page: 0.252 seconds
