Ethercat HAL driver
10 years 3 months ago #78222 by REEEN
Replied by REEEN on topic Ethercat HAL driver
Thank you.
I use debian jessie and jessie for now only suports rt preempt.
You are right I also tried to install etherlab master this way and got an error about missing realtime kernel.
Do you mean that I have to install it from igh homepage ?
10 years 3 months ago #78224 by sirop
Replied by sirop on topic Ethercat HAL driver
REEEN wrote: Thank you.
Either this or try to edit github.com/sittner/ec-debianize/blob/mas...an/configure#L79-L95
adding:
"THE OUTPUT of 'uname -r' ") XENO_CONFIG=`which xeno-config` KERNEL_DEPENDS="$KERNEL_DEPENDS, linux-modules-$KERNEL_VERSION" CONF_EXTRA=" --enable-8139too --enable-e100 --enable-e1000 --enable-e1000e --enable-r8169" ;;
Substitute "THE OUTPUT of 'uname -r' " with the actual output of
uname -r
You can also edit
according to your needs.
10 years 2 months ago - 10 years 2 months ago #78571 by mfalcon
Replied by mfalcon on topic Ethercat HAL driver
hello
I tried several times with the mentioned steps, but I failed to get the whole thing to work, please help me to understand what I am missing. I am a newbie in linuxcnc, and my experience with linux itself is limited . The following are the steps that I made:
Step 0 : you need to install Debian Linuxcnc with RTAI core (I failed to do the following procedure when I tried Linux with
RT Preemption). The following procedure was fully tested with Linux Debian-7.9'-'3.4-9-rtai-686-pae' linuxcnc.
First Part: Intallation of Eathercatlab Hal Component
1st Download ethercat master from IgH from here:
www.etherlab.org/download/ethercat/ethercat-1.5.2.tar.bz2
2nd Open a shellTerminal, and go to the folder that contains the ethercat master, and Untar the file
3rd download debian folder from sittner from here:
github.com/sittner/ec-debianize/archive/master.zip
4th Unzip the file "ec-debianize-master.zip"
5th copy debian folder (the was produced in 4th step) to /ethercat-1.5.2/ (that was produced 2nd step)
6th now in the shell terminal, use the following instructions:
cd ethercat-1.5.2
cd debian
./configure -a
cd ..
sudo apt-get update
dpkg-checkbuilddeps
(I was missing dpatch package)
dpkg-buildpackage
wait until it finishes building. use command "cd .." in the shell to go to the parent directory.
You will find two files : etherlabmaster-dev_1.5.2+hg4b0b90_i386.deb , etherlabmaster_1.5.2+hg4b0b90_i386.deb
7th sudo dpkg -i etherlabmaster_1.5.2+hg4b0b90_i386.deb
8th edit the file : "/etc/default/ethercat"
9th sudo update-ethercat-config
10th sudo dpkg -i etherlabmaster-dev_1.5.2+hg4b0b90_i386.deb
11th restart the machine to get the driver loaded at start. After that you can execute # ethercat master in terminal
Second Part : Installation of linuxcnc with lcec Hal Driver
1st Download sittner linuxcnc modification with lcec inside:
# git clone github.com/sittner/linuxcnc-ethercat.git linuxcnc-ethercat
# cd linuxcnc-ethercat
2nd # make
3rd # sudo make install
4th cd linuxcnc-ethercat/src
5th Build
6th make
7th sudo make install
8th . Copy the built binary to the ethercat directory : sudo cp lcec_conf /usr/bin/
9th restart
after all of this I get the following error when I run the example CDP17_x:
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/lcec.ko: Invalid parameters
./cpd17_x.hal:2: exit value: 1
./cpd17_x.hal:2: insmod for lcec failed, returned -1
See the output of 'dmesg' for more information.
4645
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
how can I resolve this??
Last edit: 10 years 2 months ago by mfalcon.
10 years 2 months ago #78573 by sirop
mfalcon wrote: Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/lcec.ko: Invalid parameters
4645
So what is the output of dmesg wrt this error?
The following user(s) said Thank You: mfalcon
10 years 2 months ago #78574 by mfalcon
kindly find the output of dmesg
[ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f000 (usable) [ 0.000000] BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 00000000df492c00 (usable) [ 0.000000] BIOS-e820: 00000000df492c00 - 00000000e0000000 (reserved) [ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved) [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved) [ 0.000000] BIOS-e820: 00000000fed18000 - 00000000fed1c000 (reserved) [ 0.000000] BIOS-e820: 00000000fed20000 - 00000000fed90000 (reserved) [ 0.000000] BIOS-e820: 00000000feda4000 - 00000000feda5000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved) [ 0.000000] BIOS-e820: 00000000ffe00000 - 0000000100000000 (reserved) [ 0.000000] BIOS-e820: 0000000100000000 - 00000001a0000000 (usable) [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel! [ 0.000000] SMBIOS 2.6 present. [ 0.000000] DMI: Dell Inc. Precision M6500 /0R1203, BIOS A10 06/04/2013 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0xdf492 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-CFFFF write-protect [ 0.000000] D0000-EFFFF uncachable [ 0.000000] F0000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask 000000000 write-back [ 0.000000] 1 base 0E0000000 mask FE0000000 uncachable [ 0.000000] 2 disabled [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] e820 update range: 00000000e0000000 - 0000000100000000 (usable) ==> (reserved) [ 0.000000] initial memory mapped : 0 - 01800000 [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037400000 page 2M [ 0.000000] 0037400000 - 00377fe000 page 4k [ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff] [ 0.000000] RAMDISK: 36530000 - 37290000 [ 0.000000] ACPI: RSDP 000fb870 00024 (v02 DELL ) [ 0.000000] ACPI: XSDT df4a3600 00074 (v01 DELL P2 27DD0604 ASL 00000061) [ 0.000000] ACPI: FACP df4a349c 000F4 (v04 DELL P2 27DD0604 ASL 00000061) [ 0.000000] ACPI: DSDT df4a3c00 0666C (v02 INT430 SYSFexxx 00001001 INTL 20050624) [ 0.000000] ACPI: FACS df4b2400 00040 [ 0.000000] ACPI: HPET df4a3700 00038 (v01 DELL P2 00000001 ASL 00000061) [ 0.000000] ACPI: ____ df4b1c00 00030 (v01 DELL P2 27DD0604 ASL 00000061) [ 0.000000] ACPI: APIC df4a3800 00098 (v01 DELL P2 27DD0604 ASL 00000047) [ 0.000000] ACPI: ASF! df4a3400 00076 (v32 DELL P2 27DD0604 ASL 00000061) [ 0.000000] ACPI: MCFG df4a37c0 0003C (v16 DELL P2 27DD0604 ASL 00000061) [ 0.000000] ACPI: TCPA df4a3b00 00032 (v01 00000000 ASL 00000000) [ 0.000000] ACPI: SLIC df4a389c 00176 (v01 DELL P2 27DD0604 ASL 00000061) [ 0.000000] ACPI: BOOT df4a33c0 00028 (v01 DELL P2 27DD0604 ASL 00000061) [ 0.000000] ACPI: SSDT df4a1150 009F1 (v01 PmRef CpuPm 00003000 INTL 20080729) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 2684MB HIGHMEM available. [ 0.000000] 887MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 377fe000 [ 0.000000] low ram: 0 - 377fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000377fe [ 0.000000] HighMem 0x000377fe -> 0x000df492 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009f [ 0.000000] 0: 0x00000100 -> 0x000df492 [ 0.000000] On node 0 totalpages: 914465 [ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4940200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3951 pages, LIFO batch:0 [ 0.000000] Normal zone: 1744 pages used for memmap [ 0.000000] Normal zone: 221486 pages, LIFO batch:31 [ 0.000000] HighMem zone: 5370 pages used for memmap [ 0.000000] HighMem zone: 681882 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] ACPI: PM-Timer IO Port: 0x1008 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x04] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x05] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x04] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x05] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x06] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x07] disabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1]) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1]) [ 0.000000] ACPI: IOAPIC (id[0x06] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 6, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000 [ 0.000000] SMP: Allowing 8 CPUs, 4 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at e0000000 (gap: e0000000:18000000) [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 17 pages/cpu @f7763000 s48384 r0 d21248 u69632 [ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 907319 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=17e35cc1-4367-4885-9e1a-68a12334a710 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 7316496 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (000377fe:000df492) [ 0.000000] Memory: 3601128k/3658312k available (3495k kernel code, 56732k reserved, 1237k data, 416k init, 2749008k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB) [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB) [ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB) [ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:744 16 [ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000 [ 0.000000] Extended CMOS year: 2000 [ 0.000000] Interrupt pipeline (release #3) [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration failed [ 0.008000] TSC: PIT calibration matches HPET. 1 loops [ 0.008000] Detected 2660.249 MHz processor. [ 0.000004] Calibrating delay loop (skipped), value calculated using timer frequency.. 5320.49 BogoMIPS (lpj=10640996) [ 0.000013] pid_max: default: 32768 minimum: 301 [ 0.000136] Security Framework initialized [ 0.000143] AppArmor: AppArmor disabled by boot time parameter [ 0.000199] Mount-cache hash table entries: 512 [ 0.000711] Initializing cgroup subsys cpuacct [ 0.000717] Initializing cgroup subsys memory [ 0.000740] Initializing cgroup subsys devices [ 0.000745] Initializing cgroup subsys freezer [ 0.000749] Initializing cgroup subsys net_cls [ 0.000753] Initializing cgroup subsys blkio [ 0.000772] Initializing cgroup subsys perf_event [ 0.000839] CPU: Physical Processor ID: 0 [ 0.000843] CPU: Processor Core ID: 0 [ 0.000851] mce: CPU supports 9 MCE banks [ 0.000876] CPU0: Thermal monitoring handled by SMI [ 0.001071] ACPI: Core revision 20120320 [ 0.028224] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.028877] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.068496] CPU0: Intel(R) Core(TM) i7 CPU M 620 @ 2.67GHz stepping 05 [ 0.175265] Performance Events: PEBS fmt1+, 16-deep LBR, Westmere events, Intel PMU driver. [ 0.175289] CPUID marked event: 'bus cycles' unavailable [ 0.175295] ... version: 3 [ 0.175299] ... bit width: 48 [ 0.175302] ... generic registers: 4 [ 0.175315] ... value mask: 0000ffffffffffff [ 0.175319] ... max period: 000000007fffffff [ 0.175322] ... fixed-purpose events: 3 [ 0.175326] ... event mask: 000000070000000f [ 0.187410] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.199248] CPU 1 irqstacks, hard=f3d14000 soft=f3d16000 [ 0.199253] Booting Node 0, Processors #1 [ 0.209567] Initializing CPU#1 [ 0.210337] CPU1: Thermal monitoring handled by SMI [ 0.212470] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.219198] CPU 2 irqstacks, hard=f3d44000 soft=f3d46000 [ 0.219202] #2 [ 0.229424] Initializing CPU#2 [ 0.230268] CPU2: Thermal monitoring handled by SMI [ 0.232488] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.239147] CPU 3 irqstacks, hard=f3d56000 soft=f3d58000 [ 0.239151] #3 [ 0.249265] Initializing CPU#3 [ 0.250106] CPU3: Thermal monitoring handled by SMI [ 0.252233] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.252330] Brought up 4 CPUs [ 0.252343] Total of 4 processors activated (21281.99 BogoMIPS). [ 0.256111] devtmpfs: initialized [ 0.256886] dummy: [ 0.257026] NET: Registered protocol family 16 [ 0.257316] ACPI: bus type pci registered [ 0.257447] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000) [ 0.257453] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820 [ 0.257465] PCI: Using MMCONFIG for extended config space [ 0.257469] PCI: Using configuration type 1 for base access [ 0.257487] dmi type 0xB1 record - unknown flag [ 0.259030] bio: create slab at 0 [ 0.259309] ACPI: Added _OSI(Module Device) [ 0.259314] ACPI: Added _OSI(Processor Device) [ 0.259318] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.259323] ACPI: Added _OSI(Processor Aggregator Device) [ 0.262427] ACPI: EC: Look up EC in DSDT [ 0.274809] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored [ 0.299274] ACPI: SSDT df4b2480 00043 (v01 LMPWR DELLLOM 00001001 INTL 20050624) [ 0.300016] ACPI: Dynamic OEM Table Load: [ 0.300022] ACPI: SSDT (null) 00043 (v01 LMPWR DELLLOM 00001001 INTL 20050624) [ 0.301009] ACPI: SSDT df4a27e2 00466 (v01 PmRef Cpu0Ist 00003000 INTL 20080729) [ 0.301795] ACPI: Dynamic OEM Table Load: [ 0.301809] ACPI: SSDT (null) 00466 (v01 PmRef Cpu0Ist 00003000 INTL 20080729) [ 0.302239] ACPI: SSDT df4a1c5a 00885 (v01 PmRef Cpu0Cst 00003001 INTL 20080729) [ 0.302993] ACPI: Dynamic OEM Table Load: [ 0.303008] ACPI: SSDT (null) 00885 (v01 PmRef Cpu0Cst 00003001 INTL 20080729) [ 0.303902] ACPI: SSDT df4a24df 00303 (v01 PmRef ApIst 00003000 INTL 20080729) [ 0.304952] ACPI: Dynamic OEM Table Load: [ 0.304958] ACPI: SSDT (null) 00303 (v01 PmRef ApIst 00003000 INTL 20080729) [ 0.305304] ACPI: SSDT df4a1b41 00119 (v01 PmRef ApCst 00003000 INTL 20080729) [ 0.306170] ACPI: Dynamic OEM Table Load: [ 0.306176] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20080729) [ 0.313314] ACPI: Interpreter enabled [ 0.313329] ACPI: (supports S0 S3 S4 S5) [ 0.313387] ACPI: Using IOAPIC for interrupt routing [ 0.442105] ACPI: EC: GPE = 0x10, I/O: command/status = 0x934, data = 0x930 [ 0.444847] ACPI: No dock devices found. [ 0.444867] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.482669] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.558340] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] [ 0.558346] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] [ 0.558360] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] [ 0.558364] pci_root PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff] [ 0.558369] pci_root PNP0A03:00: host bridge window [mem 0xe0000000-0xf7ffffff] [ 0.558374] pci_root PNP0A03:00: host bridge window [mem 0xfc000000-0xfebfffff] [ 0.558378] pci_root PNP0A03:00: host bridge window [mem 0xfec10000-0xfecfffff] [ 0.558391] pci_root PNP0A03:00: host bridge window [mem 0xfed1c000-0xfed1ffff] [ 0.558396] pci_root PNP0A03:00: host bridge window [mem 0xfed90000-0xfed9ffff] [ 0.558401] pci_root PNP0A03:00: host bridge window [mem 0xfed40000-0xfed44fff] [ 0.558405] pci_root PNP0A03:00: host bridge window [mem 0xfeda7000-0xfedfffff] [ 0.558410] pci_root PNP0A03:00: host bridge window [mem 0xfee10000-0xff9fffff] [ 0.558423] pci_root PNP0A03:00: host bridge window [mem 0xffc00000-0xffdfffff] [ 0.558520] PCI host bridge to bus 0000:00 [ 0.558525] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7] [ 0.558529] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.558534] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.558538] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff] [ 0.558551] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xf7ffffff] [ 0.558556] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfebfffff] [ 0.558561] pci_bus 0000:00: root bus resource [mem 0xfec10000-0xfecfffff] [ 0.558565] pci_bus 0000:00: root bus resource [mem 0xfed1c000-0xfed1ffff] [ 0.558570] pci_bus 0000:00: root bus resource [mem 0xfed90000-0xfed9ffff] [ 0.558582] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff] [ 0.558587] pci_bus 0000:00: root bus resource [mem 0xfeda7000-0xfedfffff] [ 0.558592] pci_bus 0000:00: root bus resource [mem 0xfee10000-0xff9fffff] [ 0.558596] pci_bus 0000:00: root bus resource [mem 0xffc00000-0xffdfffff] [ 0.558622] pci 0000:00:00.0: [8086:0044] type 00 class 0x060000 [ 0.558710] pci 0000:00:01.0: [8086:0045] type 01 class 0x060400 [ 0.558777] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold [ 0.558892] pci 0000:00:1a.0: [8086:3b3c] type 00 class 0x0c0320 [ 0.558947] pci 0000:00:1a.0: reg 10: [mem 0xfed1d000-0xfed1d3ff] [ 0.559131] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold [ 0.559199] pci 0000:00:1b.0: [8086:3b56] type 00 class 0x040300 [ 0.559241] pci 0000:00:1b.0: reg 10: [mem 0xf6ffc000-0xf6ffffff 64bit] [ 0.559400] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.559467] pci 0000:00:1c.0: [8086:3b42] type 01 class 0x060400 [ 0.559628] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.559698] pci 0000:00:1c.1: [8086:3b44] type 01 class 0x060400 [ 0.559860] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold [ 0.559926] pci 0000:00:1c.2: [8086:3b46] type 01 class 0x060400 [ 0.560088] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold [ 0.560153] pci 0000:00:1c.3: [8086:3b48] type 01 class 0x060400 [ 0.560326] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold [ 0.560391] pci 0000:00:1c.4: [8086:3b4a] type 01 class 0x060400 [ 0.560552] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold [ 0.560617] pci 0000:00:1c.5: [8086:3b4c] type 01 class 0x060400 [ 0.560778] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold [ 0.560843] pci 0000:00:1c.6: [8086:3b4e] type 01 class 0x060400 [ 0.561004] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold [ 0.561069] pci 0000:00:1c.7: [8086:3b50] type 01 class 0x060400 [ 0.561230] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold [ 0.561305] pci 0000:00:1d.0: [8086:3b34] type 00 class 0x0c0320 [ 0.561360] pci 0000:00:1d.0: reg 10: [mem 0xfed1c000-0xfed1c3ff] [ 0.561535] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold [ 0.561593] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401 [ 0.561753] pci 0000:00:1f.0: [8086:3b03] type 00 class 0x060100 [ 0.561983] pci 0000:00:1f.2: [8086:3b2e] type 00 class 0x01018f [ 0.562026] pci 0000:00:1f.2: reg 10: [io 0x6e70-0x6e77] [ 0.562053] pci 0000:00:1f.2: reg 14: [io 0x6e78-0x6e7b] [ 0.562079] pci 0000:00:1f.2: reg 18: [io 0x6e80-0x6e87] [ 0.562106] pci 0000:00:1f.2: reg 1c: [io 0x6e88-0x6e8b] [ 0.562123] pci 0000:00:1f.2: reg 20: [io 0x6ea0-0x6eaf] [ 0.562150] pci 0000:00:1f.2: reg 24: [io 0x6e90-0x6e9f] [ 0.562266] pci 0000:00:1f.3: [8086:3b30] type 00 class 0x0c0500 [ 0.562308] pci 0000:00:1f.3: reg 10: [mem 0xf6ffb000-0xf6ffb0ff 64bit] [ 0.562370] pci 0000:00:1f.3: reg 20: [io 0x1100-0x111f] [ 0.562465] pci 0000:00:1f.5: [8086:3b2d] type 00 class 0x010185 [ 0.562508] pci 0000:00:1f.5: reg 10: [io 0x6eb0-0x6eb7] [ 0.562534] pci 0000:00:1f.5: reg 14: [io 0x6eb8-0x6ebb] [ 0.562560] pci 0000:00:1f.5: reg 18: [io 0x6ec0-0x6ec7] [ 0.562586] pci 0000:00:1f.5: reg 1c: [io 0x6ec8-0x6ecb] [ 0.562604] pci 0000:00:1f.5: reg 20: [io 0x6ee0-0x6eef] [ 0.562630] pci 0000:00:1f.5: reg 24: [io 0xeff0-0xefff] [ 0.562756] pci 0000:00:1f.6: [8086:3b32] type 00 class 0x118000 [ 0.563052] pci 0000:01:00.0: [10de:061d] type 00 class 0x030000 [ 0.563076] pci 0000:01:00.0: reg 10: [mem 0xf5000000-0xf5ffffff] [ 0.563101] pci 0000:01:00.0: reg 14: [mem 0xe0000000-0xefffffff 64bit pref] [ 0.563121] pci 0000:01:00.0: reg 1c: [mem 0xf2000000-0xf3ffffff 64bit] [ 0.563145] pci 0000:01:00.0: reg 24: [io 0xdf00-0xdf7f] [ 0.563157] pci 0000:01:00.0: reg 30: [mem 0xf6e00000-0xf6e1ffff pref] [ 0.563251] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.563265] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff] [ 0.563271] pci 0000:00:01.0: bridge window [mem 0xf2000000-0xf6efffff] [ 0.563278] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref] [ 0.563398] pci 0000:00:1c.0: PCI bridge to [bus 0b-0b] [ 0.563882] pci 0000:0c:00.0: [8086:4235] type 00 class 0x028000 [ 0.564303] pci 0000:0c:00.0: reg 10: [mem 0xf1ffe000-0xf1ffffff 64bit] [ 0.566078] pci 0000:0c:00.0: PME# supported from D0 D3hot D3cold [ 0.566809] pci 0000:00:1c.1: PCI bridge to [bus 0c-0c] [ 0.566822] pci 0000:00:1c.1: bridge window [mem 0xf1f00000-0xf1ffffff] [ 0.566951] pci 0000:00:1c.2: PCI bridge to [bus 0d-0d] [ 0.567086] pci 0000:00:1c.3: PCI bridge to [bus 0e-0f] [ 0.567101] pci 0000:00:1c.3: bridge window [io 0xc000-0xcfff] [ 0.567110] pci 0000:00:1c.3: bridge window [mem 0xf1c00000-0xf1efffff] [ 0.567130] pci 0000:00:1c.3: bridge window [mem 0xf0000000-0xf01fffff 64bit pref] [ 0.567241] pci 0000:00:1c.4: PCI bridge to [bus 10-10] [ 0.567581] pci 0000:09:00.0: [14e4:1680] type 00 class 0x020000 [ 0.567646] pci 0000:09:00.0: reg 10: [mem 0xf1be0000-0xf1beffff 64bit] [ 0.567698] pci 0000:09:00.0: reg 18: [mem 0xf1bf0000-0xf1bfffff 64bit] [ 0.567888] pci 0000:09:00.0: PME# supported from D3hot D3cold [ 0.567992] pci 0000:00:1c.5: PCI bridge to [bus 09-09] [ 0.568012] pci 0000:00:1c.5: bridge window [mem 0xf1b00000-0xf1bfffff] [ 0.568140] pci 0000:00:1c.6: PCI bridge to [bus 11-11] [ 0.568152] pci 0000:00:1c.6: bridge window [mem 0xf1a00000-0xf1afffff] [ 0.568281] pci 0000:00:1c.7: PCI bridge to [bus 12-12] [ 0.568388] pci 0000:03:01.0: [104c:8039] type 02 class 0x060700 [ 0.568436] pci 0000:03:01.0: reg 10: [mem 0x00000000-0x00000fff] [ 0.568478] pci 0000:03:01.0: supports D1 D2 [ 0.568482] pci 0000:03:01.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.568532] pci 0000:03:01.1: [104c:803a] type 00 class 0x0c0010 [ 0.568571] pci 0000:03:01.1: reg 10: [mem 0xf19f9000-0xf19f97ff] [ 0.568597] pci 0000:03:01.1: reg 14: [mem 0xf19fc000-0xf19fffff] [ 0.568734] pci 0000:03:01.1: supports D1 D2 [ 0.568738] pci 0000:03:01.1: PME# supported from D0 D1 D2 D3hot [ 0.568789] pci 0000:03:01.2: [104c:803b] type 00 class 0x018000 [ 0.568828] pci 0000:03:01.2: reg 10: [mem 0xf19fa000-0xf19fafff] [ 0.568984] pci 0000:03:01.2: supports D1 D2 [ 0.568988] pci 0000:03:01.2: PME# supported from D0 D1 D2 D3hot [ 0.569030] pci 0000:03:01.3: [104c:803c] type 00 class 0x080501 [ 0.569076] pci 0000:03:01.3: reg 10: [mem 0xf19fb000-0xf19fb0ff] [ 0.569229] pci 0000:03:01.3: supports D1 D2 [ 0.569241] pci 0000:03:01.3: PME# supported from D0 D1 D2 D3hot [ 0.569351] pci 0000:00:1e.0: PCI bridge to [bus 03-04] (subtractive decode) [ 0.569372] pci 0000:00:1e.0: bridge window [mem 0xf1900000-0xf19fffff] [ 0.569384] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode) [ 0.569389] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode) [ 0.569403] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.569407] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode) [ 0.569413] pci 0000:00:1e.0: bridge window [mem 0xe0000000-0xf7ffffff] (subtractive decode) [ 0.569417] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfebfffff] (subtractive decode) [ 0.569422] pci 0000:00:1e.0: bridge window [mem 0xfec10000-0xfecfffff] (subtractive decode) [ 0.569436] pci 0000:00:1e.0: bridge window [mem 0xfed1c000-0xfed1ffff] (subtractive decode) [ 0.569441] pci 0000:00:1e.0: bridge window [mem 0xfed90000-0xfed9ffff] (subtractive decode) [ 0.569446] pci 0000:00:1e.0: bridge window [mem 0xfed40000-0xfed44fff] (subtractive decode) [ 0.569451] pci 0000:00:1e.0: bridge window [mem 0xfeda7000-0xfedfffff] (subtractive decode) [ 0.569464] pci 0000:00:1e.0: bridge window [mem 0xfee10000-0xff9fffff] (subtractive decode) [ 0.569471] pci 0000:00:1e.0: bridge window [mem 0xffc00000-0xffdfffff] (subtractive decode) [ 0.569551] pci_bus 0000:04: [bus 04-07] partially hidden behind transparent bridge 0000:03 [bus 03-04] [ 0.569669] pci_bus 0000:00: on NUMA node 0 [ 0.569676] ACPI: PCI Interrupt Routing Table [_SB_.PCI0._PRT] [ 0.570934] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PCIE._PRT] [ 0.571214] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.AGP2._PRT] [ 0.571354] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.RP01._PRT] [ 0.571512] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.RP02._PRT] [ 0.571673] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.RP03._PRT] [ 0.571824] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.RP04._PRT] [ 0.571967] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.RP05._PRT] [ 0.572117] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.RP06._PRT] [ 0.572261] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.RP07._PRT] [ 0.572412] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.RP08._PRT] [ 0.572550] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f) [ 0.598991] ACPI: PCI Interrupt Link [LNKA] (IRQs 10 *11) [ 0.599181] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 7) *10 [ 0.599374] ACPI: PCI Interrupt Link [LNKC] (IRQs 10 *11) [ 0.599568] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 7 *10 11) [ 0.599758] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15) [ 0.599952] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 10 11 12 14 15) [ 0.600117] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled. [ 0.600280] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled. [ 0.600495] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.600505] vgaarb: loaded [ 0.600508] vgaarb: bridge control possible 0000:01:00.0 [ 0.600574] PCI: Using ACPI for IRQ routing [ 0.603897] PCI: Discovered peer bus 3f [ 0.603901] PCI: root bus 3f: using default resources [ 0.603968] PCI host bridge to bus 0000:3f [ 0.603981] pci_bus 0000:3f: root bus resource [io 0x0000-0xffff] [ 0.603986] pci_bus 0000:3f: root bus resource [mem 0x00000000-0xffffffff] [ 0.603999] pci 0000:3f:00.0: [8086:2c62] type 00 class 0x060000 [ 0.604055] pci 0000:3f:00.1: [8086:2d01] type 00 class 0x060000 [ 0.604115] pci 0000:3f:02.0: [8086:2d10] type 00 class 0x060000 [ 0.604159] pci 0000:3f:02.1: [8086:2d11] type 00 class 0x060000 [ 0.604213] pci 0000:3f:02.2: [8086:2d12] type 00 class 0x060000 [ 0.604258] pci 0000:3f:02.3: [8086:2d13] type 00 class 0x060000 [ 0.604635] PCI: pci_cache_line_size set to 64 bytes [ 0.605086] reserve RAM buffer: 000000000009f000 - 000000000009ffff [ 0.605091] reserve RAM buffer: 00000000df492c00 - 00000000dfffffff [ 0.605394] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0 [ 0.605419] hpet0: 8 comparators, 64-bit 14.318180 MHz counter [ 0.607472] Switching to clocksource hpet [ 0.607642] pnp: PnP ACPI init [ 0.607669] ACPI: bus type pnp registered [ 0.645910] pnp 00:00: [bus 00-ff] [ 0.645916] pnp 00:00: [io 0x0000-0x0cf7 window] [ 0.645920] pnp 00:00: [io 0x0cf8-0x0cff] [ 0.645933] pnp 00:00: [io 0x0d00-0xffff window] [ 0.645938] pnp 00:00: [mem 0x000a0000-0x000bffff window] [ 0.645942] pnp 00:00: [mem 0x000d0000-0x000dffff window] [ 0.645947] pnp 00:00: [mem 0xe0000000-0xf7ffffff window] [ 0.645951] pnp 00:00: [mem 0xfc000000-0xfebfffff window] [ 0.645964] pnp 00:00: [mem 0xfec10000-0xfecfffff window] [ 0.645968] pnp 00:00: [mem 0xfed1c000-0xfed1ffff window] [ 0.645973] pnp 00:00: [mem 0xfed90000-0xfed9ffff window] [ 0.645977] pnp 00:00: [mem 0xfed40000-0xfed44fff window] [ 0.645981] pnp 00:00: [mem 0xfeda7000-0xfedfffff window] [ 0.645994] pnp 00:00: [mem 0xfee10000-0xff9fffff window] [ 0.645998] pnp 00:00: [mem 0xffc00000-0xffdfffff window] [ 0.646125] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active) [ 0.646176] pnp 00:01: [irq 12] [ 0.646235] pnp 00:01: Plug and Play ACPI device, IDs DLL02ef PNP0f13 (active) [ 0.646273] pnp 00:02: [io 0x0060] [ 0.646285] pnp 00:02: [io 0x0064] [ 0.646291] pnp 00:02: [io 0x0062] [ 0.646295] pnp 00:02: [io 0x0066] [ 0.646304] pnp 00:02: [irq 1] [ 0.646360] pnp 00:02: Plug and Play ACPI device, IDs PNP0303 (active) [ 0.646397] pnp 00:03: [io 0x0070-0x0071] [ 0.646415] pnp 00:03: [irq 8] [ 0.646418] pnp 00:03: [io 0x0072-0x0077] [ 0.646479] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.646520] pnp 00:04: [io 0x0061] [ 0.646524] pnp 00:04: [io 0x0063] [ 0.646528] pnp 00:04: [io 0x0065] [ 0.646531] pnp 00:04: [io 0x0067] [ 0.646589] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.646626] pnp 00:05: [io 0x002e-0x002f] [ 0.646630] pnp 00:05: [io 0x0c80-0x0caf] [ 0.646642] pnp 00:05: [io 0x0cc0-0x0cff] [ 0.646757] system 00:05: [io 0x0c80-0x0caf] has been reserved [ 0.646771] system 00:05: [io 0x0cc0-0x0cff] could not be reserved [ 0.646777] system 00:05: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.646821] pnp 00:06: [dma 4] [ 0.646825] pnp 00:06: [io 0x0000-0x000f] [ 0.646837] pnp 00:06: [io 0x0080-0x0085] [ 0.646840] pnp 00:06: [io 0x0087-0x008f] [ 0.646844] pnp 00:06: [io 0x00c0-0x00df] [ 0.646848] pnp 00:06: [io 0x0010-0x001f] [ 0.646852] pnp 00:06: [io 0x0090-0x0091] [ 0.646855] pnp 00:06: [io 0x0093-0x009f] [ 0.646919] pnp 00:06: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.646965] pnp 00:07: [io 0x00f0-0x00ff] [ 0.646975] pnp 00:07: [irq 13] [ 0.647033] pnp 00:07: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.647136] pnp 00:08: [mem 0xfed00000-0xfed003ff] [ 0.647243] system 00:08: [mem 0xfed00000-0xfed003ff] has been reserved [ 0.647258] system 00:08: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active) [ 0.684364] pnp 00:09: [mem 0xfed40000-0xfed44fff] [ 0.684369] pnp 00:09: [io 0x0cb0-0x0cbb] [ 0.684491] system 00:09: [io 0x0cb0-0x0cbb] has been reserved [ 0.684497] system 00:09: [mem 0xfed40000-0xfed44fff] has been reserved [ 0.684503] system 00:09: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.687009] pnp 00:0a: [io 0x0900-0x092f] [ 0.687014] pnp 00:0a: [io 0x0931-0x0933] [ 0.687018] pnp 00:0a: [io 0x0935-0x097f] [ 0.687022] pnp 00:0a: [io 0x0092] [ 0.687034] pnp 00:0a: [io 0x00b2-0x00b3] [ 0.687038] pnp 00:0a: [io 0x0020-0x0021] [ 0.687041] pnp 00:0a: [io 0x00a0-0x00a1] [ 0.687045] pnp 00:0a: [irq 0 disabled] [ 0.687049] pnp 00:0a: [io 0x04d0-0x04d1] [ 0.687053] pnp 00:0a: [io 0x1000-0x1005] [ 0.687065] pnp 00:0a: [io 0x1008-0x100f] [ 0.687212] system 00:0a: [io 0x0900-0x092f] has been reserved [ 0.687217] system 00:0a: [io 0x0931-0x0933] has been reserved [ 0.687230] system 00:0a: [io 0x0935-0x097f] has been reserved [ 0.687236] system 00:0a: [io 0x04d0-0x04d1] has been reserved [ 0.687240] system 00:0a: [io 0x1000-0x1005] has been reserved [ 0.687245] system 00:0a: [io 0x1008-0x100f] has been reserved [ 0.687259] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.687314] pnp 00:0b: [io 0xf400-0xf4fe] [ 0.687327] pnp 00:0b: [io 0x0086] [ 0.687330] pnp 00:0b: [io 0x1006-0x1007] [ 0.687334] pnp 00:0b: [io 0x100a-0x1059] [ 0.687338] pnp 00:0b: [io 0x1080-0x10bf] [ 0.687342] pnp 00:0b: [io 0x1100-0x111f] [ 0.687345] pnp 00:0b: [io 0x1010-0x102f] [ 0.687357] pnp 00:0b: [io 0x0809] [ 0.687501] system 00:0b: [io 0xf400-0xf4fe] has been reserved [ 0.687506] system 00:0b: [io 0x1006-0x1007] has been reserved [ 0.687520] system 00:0b: [io 0x100a-0x1059] could not be reserved [ 0.687525] system 00:0b: [io 0x1080-0x10bf] has been reserved [ 0.687530] system 00:0b: [io 0x1100-0x111f] has been reserved [ 0.687535] system 00:0b: [io 0x1010-0x102f] has been reserved [ 0.687540] system 00:0b: [io 0x0809] has been reserved [ 0.687554] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.739540] pnp 00:0c: [mem 0x00000000-0x0009efff] [ 0.739545] pnp 00:0c: [mem 0x0009f000-0x0009ffff] [ 0.739549] pnp 00:0c: [mem 0x000c0000-0x000cffff] [ 0.739553] pnp 00:0c: [mem 0x000e0000-0x000fffff] [ 0.739557] pnp 00:0c: [mem 0x00100000-0xdf492bff] [ 0.739570] pnp 00:0c: [mem 0xdf492c00-0xdfefffff] [ 0.739574] pnp 00:0c: [mem 0xdff00000-0xdfffffff] [ 0.739578] pnp 00:0c: [mem 0xffe00000-0xffffffff] [ 0.739582] pnp 00:0c: [mem 0xffa00000-0xffbfffff] [ 0.739586] pnp 00:0c: [mem 0xfec00000-0xfec0ffff] [ 0.739590] pnp 00:0c: [mem 0xfee00000-0xfee0ffff] [ 0.739604] pnp 00:0c: [mem 0xfed20000-0xfed3ffff] [ 0.739608] pnp 00:0c: [mem 0xfed45000-0xfed8ffff] [ 0.739612] pnp 00:0c: [mem 0xfeda0000-0xfeda3fff] [ 0.739616] pnp 00:0c: [mem 0xfeda4000-0xfeda4fff] [ 0.739620] pnp 00:0c: [mem 0xfeda5000-0xfeda5fff] [ 0.739633] pnp 00:0c: [mem 0xfeda6000-0xfeda6fff] [ 0.739637] pnp 00:0c: [mem 0xfed1e000-0xfed1efff] [ 0.739641] pnp 00:0c: [mem 0xfed18000-0xfed1bfff] [ 0.739645] pnp 00:0c: [mem 0xf8000000-0xfbffffff] [ 0.739870] system 00:0c: [mem 0x00000000-0x0009efff] could not be reserved [ 0.739876] system 00:0c: [mem 0x0009f000-0x0009ffff] could not be reserved [ 0.739881] system 00:0c: [mem 0x000c0000-0x000cffff] could not be reserved [ 0.739895] system 00:0c: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.739901] system 00:0c: [mem 0x00100000-0xdf492bff] could not be reserved [ 0.739906] system 00:0c: [mem 0xdf492c00-0xdfefffff] has been reserved [ 0.739911] system 00:0c: [mem 0xdff00000-0xdfffffff] has been reserved [ 0.739925] system 00:0c: [mem 0xffe00000-0xffffffff] has been reserved [ 0.739930] system 00:0c: [mem 0xffa00000-0xffbfffff] has been reserved [ 0.739936] system 00:0c: [mem 0xfec00000-0xfec0ffff] could not be reserved [ 0.739941] system 00:0c: [mem 0xfee00000-0xfee0ffff] has been reserved [ 0.739946] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved [ 0.739960] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved [ 0.739965] system 00:0c: [mem 0xfeda0000-0xfeda3fff] has been reserved [ 0.739970] system 00:0c: [mem 0xfeda4000-0xfeda4fff] has been reserved [ 0.739975] system 00:0c: [mem 0xfeda5000-0xfeda5fff] has been reserved [ 0.739989] system 00:0c: [mem 0xfeda6000-0xfeda6fff] has been reserved [ 0.739994] system 00:0c: [mem 0xfed1e000-0xfed1efff] has been reserved [ 0.739999] system 00:0c: [mem 0xfed18000-0xfed1bfff] has been reserved [ 0.740004] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved [ 0.740010] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.746922] pnp: PnP ACPI: found 13 devices [ 0.746934] ACPI: ACPI bus type pnp unregistered [ 0.746939] PnPBIOS: Disabled by ACPI PNP [ 0.786588] pci 0000:03:01.0: res[13]=[io 0x0100-0x00ff] get_res_add_size add_size 100 [ 0.786594] pci 0000:03:01.0: res[14]=[io 0x0100-0x00ff] get_res_add_size add_size 100 [ 0.786601] pci 0000:00:1e.0: bridge window [io 0x1000-0x0fff] to [bus 03-04] add_size 1000 [ 0.786607] pci 0000:03:01.0: res[15]=[mem 0x04000000-0x03ffffff pref] get_res_add_size add_size 4000000 [ 0.786622] pci 0000:00:1e.0: bridge window [mem 0x04000000-0x03ffffff pref] to [bus 03-04] add_size 4000000 [ 0.786635] pci 0000:00:1e.0: res[15]=[mem 0x04000000-0x03ffffff pref] get_res_add_size add_size 4000000 [ 0.786640] pci 0000:00:1e.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000 [ 0.786661] pci 0000:00:1e.0: BAR 15: can't assign mem pref (size 0x4000000) [ 0.786668] pci 0000:00:1e.0: BAR 13: assigned [io 0x2000-0x2fff] [ 0.786682] pci 0000:00:1f.6: BAR 0: assigned [mem 0xf0200000-0xf0200fff 64bit] [ 0.786698] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.786703] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff] [ 0.786718] pci 0000:00:01.0: bridge window [mem 0xf2000000-0xf6efffff] [ 0.786725] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref] [ 0.786732] pci 0000:00:1c.0: PCI bridge to [bus 0b-0b] [ 0.786763] pci 0000:00:1c.1: PCI bridge to [bus 0c-0c] [ 0.786780] pci 0000:00:1c.1: bridge window [mem 0xf1f00000-0xf1ffffff] [ 0.786796] pci 0000:00:1c.2: PCI bridge to [bus 0d-0d] [ 0.786827] pci 0000:00:1c.3: PCI bridge to [bus 0e-0f] [ 0.786833] pci 0000:00:1c.3: bridge window [io 0xc000-0xcfff] [ 0.786852] pci 0000:00:1c.3: bridge window [mem 0xf1c00000-0xf1efffff] [ 0.786860] pci 0000:00:1c.3: bridge window [mem 0xf0000000-0xf01fffff 64bit pref] [ 0.786881] pci 0000:00:1c.4: PCI bridge to [bus 10-10] [ 0.786912] pci 0000:00:1c.5: PCI bridge to [bus 09-09] [ 0.786922] pci 0000:00:1c.5: bridge window [mem 0xf1b00000-0xf1bfffff] [ 0.786946] pci 0000:00:1c.6: PCI bridge to [bus 11-11] [ 0.786956] pci 0000:00:1c.6: bridge window [mem 0xf1a00000-0xf1afffff] [ 0.786980] pci 0000:00:1c.7: PCI bridge to [bus 12-12] [ 0.787015] pci 0000:03:01.0: res[15]=[mem 0x04000000-0x03ffffff pref] get_res_add_size add_size 4000000 [ 0.787041] pci 0000:03:01.0: res[16]=[mem 0x04000000-0x03ffffff] get_res_add_size add_size 4000000 [ 0.787046] pci 0000:03:01.0: res[13]=[io 0x0100-0x00ff] get_res_add_size add_size 100 [ 0.787052] pci 0000:03:01.0: res[14]=[io 0x0100-0x00ff] get_res_add_size add_size 100 [ 0.787059] pci 0000:03:01.0: BAR 0: assigned [mem 0xfc000000-0xfc000fff] [ 0.787086] pci 0000:03:01.0: BAR 15: can't assign mem pref (size 0x4000000) [ 0.787107] pci 0000:03:01.0: BAR 16: can't assign mem (size 0x4000000) [ 0.787112] pci 0000:03:01.0: BAR 13: assigned [io 0x2000-0x20ff] [ 0.787117] pci 0000:03:01.0: BAR 14: assigned [io 0x2400-0x24ff] [ 0.787125] pci 0000:03:01.0: BAR 0: assigned [mem 0xfc000000-0xfc000fff] [ 0.787149] pci 0000:03:01.0: BAR 16: can't assign mem (size 0x4000000) [ 0.787171] pci 0000:03:01.0: BAR 15: can't assign mem pref (size 0x4000000) [ 0.787176] pci 0000:03:01.0: BAR 14: assigned [io 0x2000-0x20ff] [ 0.787181] pci 0000:03:01.0: BAR 13: assigned [io 0x2400-0x24ff] [ 0.787186] pci 0000:03:01.0: CardBus bridge to [bus 04-07] [ 0.787199] pci 0000:03:01.0: bridge window [io 0x2400-0x24ff] [ 0.787207] pci 0000:03:01.0: bridge window [io 0x2000-0x20ff] [ 0.787216] pci 0000:00:1e.0: PCI bridge to [bus 03-04] [ 0.787222] pci 0000:00:1e.0: bridge window [io 0x2000-0x2fff] [ 0.787240] pci 0000:00:1e.0: bridge window [mem 0xf1900000-0xf19fffff] [ 0.787439] pci 0000:00:1e.0: setting latency timer to 64 [ 0.787459] pci 0000:03:01.0: enabling device (0000 -> 0003) [ 0.787477] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.787490] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.787494] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.787498] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff] [ 0.787503] pci_bus 0000:00: resource 8 [mem 0xe0000000-0xf7ffffff] [ 0.787508] pci_bus 0000:00: resource 9 [mem 0xfc000000-0xfebfffff] [ 0.787512] pci_bus 0000:00: resource 10 [mem 0xfec10000-0xfecfffff] [ 0.787525] pci_bus 0000:00: resource 11 [mem 0xfed1c000-0xfed1ffff] [ 0.787529] pci_bus 0000:00: resource 12 [mem 0xfed90000-0xfed9ffff] [ 0.787533] pci_bus 0000:00: resource 13 [mem 0xfed40000-0xfed44fff] [ 0.787538] pci_bus 0000:00: resource 14 [mem 0xfeda7000-0xfedfffff] [ 0.787542] pci_bus 0000:00: resource 15 [mem 0xfee10000-0xff9fffff] [ 0.787555] pci_bus 0000:00: resource 16 [mem 0xffc00000-0xffdfffff] [ 0.787559] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff] [ 0.787563] pci_bus 0000:01: resource 1 [mem 0xf2000000-0xf6efffff] [ 0.787568] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref] [ 0.787573] pci_bus 0000:0c: resource 1 [mem 0xf1f00000-0xf1ffffff] [ 0.787586] pci_bus 0000:0e: resource 0 [io 0xc000-0xcfff] [ 0.787590] pci_bus 0000:0e: resource 1 [mem 0xf1c00000-0xf1efffff] [ 0.787595] pci_bus 0000:0e: resource 2 [mem 0xf0000000-0xf01fffff 64bit pref] [ 0.787599] pci_bus 0000:09: resource 1 [mem 0xf1b00000-0xf1bfffff] [ 0.787604] pci_bus 0000:11: resource 1 [mem 0xf1a00000-0xf1afffff] [ 0.787608] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff] [ 0.787621] pci_bus 0000:03: resource 1 [mem 0xf1900000-0xf19fffff] [ 0.787625] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7] [ 0.787629] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff] [ 0.787633] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff] [ 0.787638] pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000dffff] [ 0.787651] pci_bus 0000:03: resource 8 [mem 0xe0000000-0xf7ffffff] [ 0.787655] pci_bus 0000:03: resource 9 [mem 0xfc000000-0xfebfffff] [ 0.787659] pci_bus 0000:03: resource 10 [mem 0xfec10000-0xfecfffff] [ 0.787664] pci_bus 0000:03: resource 11 [mem 0xfed1c000-0xfed1ffff] [ 0.787668] pci_bus 0000:03: resource 12 [mem 0xfed90000-0xfed9ffff] [ 0.787672] pci_bus 0000:03: resource 13 [mem 0xfed40000-0xfed44fff] [ 0.787685] pci_bus 0000:03: resource 14 [mem 0xfeda7000-0xfedfffff] [ 0.787689] pci_bus 0000:03: resource 15 [mem 0xfee10000-0xff9fffff] [ 0.787694] pci_bus 0000:03: resource 16 [mem 0xffc00000-0xffdfffff] [ 0.787698] pci_bus 0000:04: resource 0 [io 0x2400-0x24ff] [ 0.787702] pci_bus 0000:04: resource 1 [io 0x2000-0x20ff] [ 0.787715] pci_bus 0000:3f: resource 4 [io 0x0000-0xffff] [ 0.787719] pci_bus 0000:3f: resource 5 [mem 0x00000000-0xffffffff] [ 0.787915] NET: Registered protocol family 2 [ 0.788048] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.788441] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.789075] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.789362] TCP: Hash tables configured (established 131072 bind 65536) [ 0.789367] TCP: reno registered [ 0.789372] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.789382] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.789600] NET: Registered protocol family 1 [ 0.789829] pci 0000:01:00.0: Boot video device [ 0.790059] PCI: CLS 64 bytes, default 64 [ 0.790151] Unpacking initramfs... [ 1.530763] Freeing initrd memory: 13696k freed [ 1.535838] Simple Boot Flag at 0x79 set to 0x1 [ 1.537025] audit: initializing netlink socket (disabled) [ 1.537062] type=2000 audit(1470824488.416:1): initialized [ 1.570253] highmem bounce pool size: 64 pages [ 1.570271] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 1.570866] VFS: Disk quotas dquot_6.5.2 [ 1.570937] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.571114] msgmni has been set to 1691 [ 1.571497] alg: No test for stdrng (krng) [ 1.571555] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 1.571570] io scheduler noop registered [ 1.571574] io scheduler deadline registered [ 1.571624] io scheduler cfq registered (default) [ 1.572806] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 1.572843] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 1.572847] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 1.573650] acpiphp: Slot [1] registered [ 1.574062] GHES: HEST is not enabled! [ 1.574090] isapnp: Scanning for PnP cards... [ 1.933512] isapnp: No Plug & Play device found [ 1.933619] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.934678] Linux agpgart interface v0.103 [ 1.935374] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12 [ 1.936194] i8042: Warning: Keylock active [ 1.939387] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.939452] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 1.939721] mousedev: PS/2 mouse device common for all mice [ 1.939812] rtc_cmos 00:03: RTC can wake from S4 [ 1.940070] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0 [ 1.940116] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs [ 1.940454] TCP: cubic registered [ 1.940637] NET: Registered protocol family 10 [ 1.941202] Mobile IPv6 [ 1.941208] NET: Registered protocol family 17 [ 1.941215] Registering the dns_resolver key type [ 1.941345] Using IPI No-Shortcut mode [ 1.941632] PM: Hibernation image not present or could not be loaded. [ 1.941663] registered taskstats version 1 [ 1.941952] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0 [ 1.943239] rtc_cmos 00:03: setting system clock to 2016-08-10 10:21:30 UTC (1470824490) [ 1.943460] Freeing unused kernel memory: 416k freed [ 1.943797] Write protecting the kernel text: 3496k [ 1.943857] Write protecting the kernel read-only data: 984k [ 1.969577] udevd[59]: starting version 175 [ 2.059657] usbcore: registered new interface driver usbfs [ 2.059725] usbcore: registered new interface driver hub [ 2.059964] usbcore: registered new device driver usb [ 2.060917] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.061071] ehci_hcd 0000:00:1a.0: setting latency timer to 64 [ 2.061080] ehci_hcd 0000:00:1a.0: EHCI Host Controller [ 2.061145] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1 [ 2.061223] ehci_hcd 0000:00:1a.0: debug port 2 [ 2.065168] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported [ 2.065227] ehci_hcd 0000:00:1a.0: irq 20, io mem 0xfed1d000 [ 2.072153] tg3.c:v3.123 (March 21, 2012) [ 2.075941] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00 [ 2.076011] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.076018] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.076033] usb usb1: Product: EHCI Host Controller [ 2.076038] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 2.076044] usb usb1: SerialNumber: 0000:00:1a.0 [ 2.076427] hub 1-0:1.0: USB hub found [ 2.076448] hub 1-0:1.0: 2 ports detected [ 2.076780] ehci_hcd 0000:00:1d.0: setting latency timer to 64 [ 2.076790] ehci_hcd 0000:00:1d.0: EHCI Host Controller [ 2.076823] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 2.076888] ehci_hcd 0000:00:1d.0: debug port 2 [ 2.080820] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported [ 2.080845] ehci_hcd 0000:00:1d.0: irq 20, io mem 0xfed1c000 [ 2.091925] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00 [ 2.091985] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.091992] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.092007] usb usb2: Product: EHCI Host Controller [ 2.092013] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 2.092019] usb usb2: SerialNumber: 0000:00:1d.0 [ 2.092341] hub 2-0:1.0: USB hub found [ 2.092363] hub 2-0:1.0: 2 ports detected [ 2.095622] SCSI subsystem initialized [ 2.105199] libata version 3.00 loaded. [ 2.106109] ata_piix 0000:00:1f.2: version 2.13 [ 2.106165] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ] [ 2.106295] ata_piix 0000:00:1f.2: setting latency timer to 64 [ 2.107197] scsi0 : ata_piix [ 2.107870] scsi1 : ata_piix [ 2.114111] tg3 0000:09:00.0: eth0: Tigon3 [partno(BCM95761e) rev 5761100] (PCI Express) MAC address f0:4d:a2:4f:db:6a [ 2.114122] tg3 0000:09:00.0: eth0: attached PHY is 5761 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0]) [ 2.114139] tg3 0000:09:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1] [ 2.114147] tg3 0000:09:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit] [ 2.115988] ata1: SATA max UDMA/133 cmd 0x6e70 ctl 0x6e78 bmdma 0x6ea0 irq 19 [ 2.116002] ata2: SATA max UDMA/133 cmd 0x6e80 ctl 0x6e88 bmdma 0x6ea8 irq 19 [ 2.117117] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ] [ 2.117224] ata_piix 0000:00:1f.5: setting latency timer to 64 [ 2.118577] scsi2 : ata_piix [ 2.119837] scsi3 : ata_piix [ 2.120278] ata3: SATA max UDMA/133 cmd 0x6eb0 ctl 0x6eb8 bmdma 0x6ee0 irq 19 [ 2.120288] ata4: SATA max UDMA/133 cmd 0x6ec0 ctl 0x6ec8 bmdma 0x6ee8 irq 19 [ 2.126546] microcode: CPU0 sig=0x20655, pf=0x10, revision=0x3 [ 2.167816] firewire_ohci 0000:03:01.1: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2 [ 2.169751] microcode: CPU0 updated to revision 0x4, date = 2013-06-28 [ 2.169784] microcode: CPU1 sig=0x20655, pf=0x10, revision=0x3 [ 2.174895] microcode: CPU1 updated to revision 0x4, date = 2013-06-28 [ 2.174919] microcode: CPU2 sig=0x20655, pf=0x10, revision=0x3 [ 2.180189] microcode: CPU2 updated to revision 0x4, date = 2013-06-28 [ 2.180220] microcode: CPU3 sig=0x20655, pf=0x10, revision=0x3 [ 2.185448] microcode: CPU3 updated to revision 0x4, date = 2013-06-28 [ 2.185685] microcode: Microcode Update Driver: v2.00 , Peter Oruba [ 2.387175] usb 1-1: new high-speed USB device number 2 using ehci_hcd [ 2.452898] ata3: SATA link down (SStatus 0 SControl 300) [ 2.466872] ata4: SATA link down (SStatus 0 SControl 300) [ 2.523183] usb 1-1: New USB device found, idVendor=8087, idProduct=0020 [ 2.523189] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 2.523690] hub 1-1:1.0: USB hub found [ 2.523811] hub 1-1:1.0: 6 ports detected [ 2.530792] Refined TSC clocksource calibration: 2660.153 MHz. [ 2.530802] Switching to clocksource tsc [ 2.634533] usb 2-1: new high-speed USB device number 2 using ehci_hcd [ 2.666612] firewire_core 0000:03:01.1: created device fw0: GUID 354fc0003287e281, S400 [ 2.766583] usb 2-1: New USB device found, idVendor=8087, idProduct=0020 [ 2.766588] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 2.766906] hub 2-1:1.0: USB hub found [ 2.767081] hub 2-1:1.0: 8 ports detected [ 2.838162] usb 1-1.3: new high-speed USB device number 3 using ehci_hcd [ 2.913950] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 2.913984] ata2.01: SATA link down (SStatus 0 SControl 300) [ 2.914014] ata2.01: link offline, clearing class 3 to NONE [ 2.917939] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 2.917974] ata1.01: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 2.922139] ata2.00: ATAPI: HL-DT-ST DVD+/-RW GS20N, A110, max UDMA/133 [ 2.934249] ata1.00: ATA-8: WDC WD1600BJKT-75F4T0, 11.01A11, max UDMA/133 [ 2.934254] ata1.00: 312581808 sectors, multi 8: LBA48 NCQ (depth 0/32) [ 2.934502] ata1.01: ATA-8: WDC WD10JPVT-22A1YT0, 01.01A01, max UDMA/133 [ 2.934508] ata1.01: 1953525168 sectors, multi 8: LBA48 NCQ (depth 0/32) [ 2.937663] usb 1-1.3: New USB device found, idVendor=05ca, idProduct=1815 [ 2.937669] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.937673] usb 1-1.3: Product: Laptop_Integrated_Webcam_3M [ 2.937677] usb 1-1.3: Manufacturer: CN04P5V97248708H00JR [ 2.938192] ata2.00: configured for UDMA/133 [ 2.942264] ata1.00: configured for UDMA/133 [ 2.950770] ata1.01: configured for UDMA/133 [ 2.951033] scsi 0:0:0:0: Direct-Access ATA WDC WD1600BJKT-7 11.0 PQ: 0 ANSI: 5 [ 2.951499] scsi 0:0:1:0: Direct-Access ATA WDC WD10JPVT-22A 01.0 PQ: 0 ANSI: 5 [ 2.955086] scsi 1:0:0:0: CD-ROM HL-DT-ST DVD+-RW GS20N A110 PQ: 0 ANSI: 5 [ 2.956448] sdhci: Secure Digital Host Controller Interface driver [ 2.956463] sdhci: Copyright(c) Pierre Ossman [ 2.957220] sdhci-pci 0000:03:01.3: SDHCI controller found [104c:803c] (rev 0) [ 2.957342] mmc0: no vmmc regulator found [ 2.957451] Registered led device: mmc0:: [ 2.958605] mmc0: SDHCI controller on PCI [0000:03:01.3] using DMA [ 2.965534] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB) [ 2.965816] sd 0:0:0:0: [sda] Write Protect is off [ 2.965824] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 2.965855] sd 0:0:1:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB) [ 2.965864] sd 0:0:1:0: [sdb] 4096-byte physical blocks [ 2.965925] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 2.966074] sd 0:0:1:0: [sdb] Write Protect is off [ 2.966082] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00 [ 2.966158] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 2.971046] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 2.971173] sd 0:0:1:0: Attached scsi generic sg1 type 0 [ 2.971282] scsi 1:0:0:0: Attached scsi generic sg2 type 5 [ 2.995279] sda: sda1 sda2 [ 3.010612] usb 1-1.4: new full-speed USB device number 4 using ehci_hcd [ 3.026313] sdb: sdb1 sdb2 < sdb5 > [ 3.026555] sd 0:0:0:0: [sda] Attached SCSI disk [ 3.027200] sd 0:0:1:0: [sdb] Attached SCSI disk [ 3.038183] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda caddy [ 3.038189] cdrom: Uniform CD-ROM driver Revision: 3.20 [ 3.038638] sr 1:0:0:0: Attached scsi CD-ROM sr0 [ 3.124216] usb 1-1.4: New USB device found, idVendor=0a5c, idProduct=5800 [ 3.124223] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 3.124237] usb 1-1.4: Product: 5880 [ 3.124240] usb 1-1.4: Manufacturer: Broadcom Corp [ 3.124244] usb 1-1.4: SerialNumber: 0123456789ABCD [ 3.124420] usb 1-1.4: config 0 descriptor?? [ 3.205268] usb 1-1.6: new full-speed USB device number 5 using ehci_hcd [ 3.298907] usb 1-1.6: New USB device found, idVendor=0a5c, idProduct=4500 [ 3.298914] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.298919] usb 1-1.6: Product: BCM2046B1 [ 3.298922] usb 1-1.6: Manufacturer: Broadcom [ 3.299337] hub 1-1.6:1.0: USB hub found [ 3.299538] hub 1-1.6:1.0: 3 ports detected [ 3.568380] usb 1-1.6.1: new full-speed USB device number 6 using ehci_hcd [ 3.663016] usb 1-1.6.1: New USB device found, idVendor=413c, idProduct=8161 [ 3.663023] usb 1-1.6.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 3.671199] input: HID 413c:8161 as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6.1/1-1.6.1:1.0/input/input1 [ 3.671363] generic-usb 0003:413C:8161.0001: input,hidraw0: USB HID v1.11 Keyboard [HID 413c:8161] on usb-0000:00:1a.0-1.6.1/input0 [ 3.671420] usbcore: registered new interface driver usbhid [ 3.671423] usbhid: USB HID core driver [ 3.731974] usb 1-1.6.2: new full-speed USB device number 7 using ehci_hcd [ 3.826867] usb 1-1.6.2: New USB device found, idVendor=413c, idProduct=8162 [ 3.826873] usb 1-1.6.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 3.829943] input: HID 413c:8162 as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6.2/1-1.6.2:1.0/input/input2 [ 3.830121] generic-usb 0003:413C:8162.0002: input,hidraw1: USB HID v1.11 Mouse [HID 413c:8162] on usb-0000:00:1a.0-1.6.2/input0 [ 8.461286] PM: Starting manual resume from disk [ 8.461293] PM: Hibernation image partition 8:21 present [ 8.461296] PM: Looking for hibernation image. [ 8.461601] PM: Image not found (code -22) [ 8.461606] PM: Hibernation image not present or could not be loaded. [ 8.669332] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null) [ 10.486588] udevd[399]: starting version 175 [ 10.833977] wmi: Mapper loaded [ 10.991154] ACPI: AC Adapter [AC] (on-line) [ 11.047635] yenta_cardbus 0000:03:01.0: CardBus bridge found [1028:02ef] [ 11.047701] yenta_cardbus 0000:03:01.0: CardBus bridge to [bus 04-07] [ 11.047710] yenta_cardbus 0000:03:01.0: bridge window [io 0x2400-0x24ff] [ 11.047731] yenta_cardbus 0000:03:01.0: bridge window [io 0x2000-0x20ff] [ 11.047743] yenta_cardbus 0000:03:01.0: bridge window [mem 0xf0400000-0xf07fffff] [ 11.047762] yenta_cardbus 0000:03:01.0: bridge window [mem 0xf0800000-0xf0bfffff] [ 11.047779] yenta_cardbus 0000:03:01.0: Using CSCINT to route CSC interrupts to PCI [ 11.047794] yenta_cardbus 0000:03:01.0: Routing CardBus interrupts to PCI [ 11.047806] yenta_cardbus 0000:03:01.0: TI: mfunc 0x01001b22, devctl 0x66 [ 11.054919] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input3 [ 11.056988] ACPI: Lid Switch [LID] [ 11.057117] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4 [ 11.057135] ACPI: Power Button [PBTN] [ 11.057242] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5 [ 11.057258] ACPI: Sleep Button [SBTN] [ 11.135869] ACPI: Battery Slot [BAT0] (battery present) [ 11.278956] yenta_cardbus 0000:03:01.0: ISA IRQ mask 0x0cf8, PCI irq 19 [ 11.278975] yenta_cardbus 0000:03:01.0: Socket status: 30000006 [ 11.278986] pci_bus 0000:03: Raising subordinate bus# of parent bus (#03) from #04 to #07 [ 11.279013] yenta_cardbus 0000:03:01.0: pcmcia: parent PCI bridge window: [io 0x2000-0x2fff] [ 11.279031] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x2000-0x2fff: excluding 0x2000-0x20ff 0x2400-0x24ff [ 11.291139] yenta_cardbus 0000:03:01.0: pcmcia: parent PCI bridge window: [mem 0xf1900000-0xf19fffff] [ 11.291147] pcmcia_socket pcmcia_socket0: cs: memory probe 0xf1900000-0xf19fffff: excluding 0xf19f0000-0xf19fffff [ 11.325061] cfg80211: Calling CRDA to update world regulatory domain [ 11.467259] intel ips 0000:00:1f.6: CPU TDP doesn't match expected value (found 25, expected 29) [ 11.467380] intel ips 0000:00:1f.6: failed to get i915 symbols, graphics turbo disabled until i915 loads [ 11.467605] intel ips 0000:00:1f.6: IPS driver initialized, MCP temp limit 90 [ 11.538082] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: [ 11.540999] acpi device:2b: registered as cooling_device0 [ 11.542744] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:29/LNXVIDEO:01/input/input6 [ 11.542769] ACPI: Video Device [VID1] (multi-head: yes rom: no post: no) [ 11.544102] clean. [ 11.544193] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: excluding 0x4d0-0x4d7 [ 11.545406] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean. [ 11.546362] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: excluding 0xc80-0xcbf [ 11.547183] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff: excluding 0xc0000-0xcffff 0xe0000-0xfffff [ 11.547266] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: excluding 0xa0000000-0xa0ffffff [ 11.547354] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: excluding 0x60000000-0x60ffffff [ 11.547441] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean. [ 11.663821] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2) [ 11.682695] input: Dell WMI hotkeys as /devices/virtual/input/input7 [ 11.736021] iTCO_vendor_support: vendor-support=0 [ 11.743541] Intel(R) Wireless WiFi Link AGN driver for Linux, in-tree: [ 11.743547] Copyright(c) 2003-2012 Intel Corporation [ 11.743864] iwlwifi 0000:0c:00.0: pci_resource_len = 0x00002000 [ 11.743877] iwlwifi 0000:0c:00.0: pci_resource_base = f813c000 [ 11.743882] iwlwifi 0000:0c:00.0: HW Revision ID = 0x0 [ 11.743890] iwlwifi 0000:0c:00.0: pci_enable_msi failed(0Xffffffff) [ 11.890989] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07 [ 11.891316] iTCO_wdt: Found a PM55 TCO device (Version=2, TCOBASE=0x1060) [ 11.891494] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) [ 11.923614] [drm] Initialized drm 1.1.0 20060810 [ 12.002610] iwlwifi 0000:0c:00.0: loaded firmware version 8.83.5.1 build 33692 [ 12.002906] iwlwifi 0000:0c:00.0: CONFIG_IWLWIFI_DEBUG disabled [ 12.002913] iwlwifi 0000:0c:00.0: CONFIG_IWLWIFI_DEBUGFS disabled [ 12.002928] iwlwifi 0000:0c:00.0: CONFIG_IWLWIFI_DEVICE_TRACING disabled [ 12.002933] iwlwifi 0000:0c:00.0: CONFIG_IWLWIFI_DEVICE_TESTMODE disabled [ 12.002939] iwlwifi 0000:0c:00.0: CONFIG_IWLWIFI_P2P disabled [ 12.002945] iwlwifi 0000:0c:00.0: Detected Intel(R) Ultimate N WiFi Link 5300 AGN, REV=0x24 [ 12.003129] iwlwifi 0000:0c:00.0: L1 Disabled; Enabling L0S [ 12.029893] iwlwifi 0000:0c:00.0: device EEPROM VER=0x120, CALIB=0x4 [ 12.029900] iwlwifi 0000:0c:00.0: Device SKU: 0xF0 [ 12.029905] iwlwifi 0000:0c:00.0: Valid Tx ant: 0x7, Valid Rx ant: 0x7 [ 12.029930] iwlwifi 0000:0c:00.0: Tunable channels: 13 802.11bg, 24 802.11a channels [ 12.030091] Registered led device: phy0-led [ 12.094120] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs' [ 12.273869] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input8 [ 12.286136] input: HDA Intel Dock Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9 [ 12.286365] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10 [ 12.286600] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11 [ 12.286819] input: HDA Intel Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12 [ 12.400413] psmouse serio1: synaptics: Touchpad model: 1, fw: 7.4, id: 0x1e0b1, caps: 0xd447b3/0xf4040d/0x8a0000 [ 12.400425] psmouse serio1: synaptics: serio: Synaptics pass-through port at isa0060/serio1/input0 [ 12.437202] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input13 [ 12.512599] Linux media interface: v0.10 [ 12.527515] Linux video capture interface: v2.00 [ 12.644822] uvcvideo: Found UVC 1.00 device Laptop_Integrated_Webcam_3M (05ca:1815) [ 12.646616] input: Laptop_Integrated_Webcam_3M as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/input/input14 [ 12.646789] usbcore: registered new interface driver uvcvideo [ 12.646793] USB Video Class driver (1.1.1) [ 12.819441] [drm] nouveau 0000:01:00.0: Detected an NV50 generation card (0x092e80a2) [ 12.826629] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS [ 12.906670] [drm] nouveau 0000:01:00.0: ... appears to be valid [ 12.906675] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN [ 12.906681] [drm] nouveau 0000:01:00.0: BIT BIOS found [ 12.906686] [drm] nouveau 0000:01:00.0: Bios version 62.92.a2.00 [ 12.906700] [drm] nouveau 0000:01:00.0: TMDS table version 2.0 [ 12.906914] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do [ 12.906930] [drm] nouveau 0000:01:00.0: DCB version 4.0 [ 12.906938] [drm] nouveau 0000:01:00.0: DCB outp 00: 01000323 00010034 [ 12.906944] [drm] nouveau 0000:01:00.0: DCB outp 01: 02011300 00000028 [ 12.906960] [drm] nouveau 0000:01:00.0: DCB outp 02: 01122306 0f220d00 [ 12.906966] [drm] nouveau 0000:01:00.0: DCB outp 03: 01122302 00020d00 [ 12.906972] [drm] nouveau 0000:01:00.0: DCB outp 04: 02133316 0f320e00 [ 12.906978] [drm] nouveau 0000:01:00.0: DCB outp 05: 02133312 00120e00 [ 12.906991] [drm] nouveau 0000:01:00.0: DCB conn 00: 00000040 [ 12.906996] [drm] nouveau 0000:01:00.0: DCB conn 01: 00000100 [ 12.907000] [drm] nouveau 0000:01:00.0: DCB conn 02: 00005246 [ 12.907005] [drm] nouveau 0000:01:00.0: DCB conn 03: 0000a346 [ 12.907024] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xD741 [ 12.930663] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xDCF6 [ 12.933547] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xEA6B [ 12.933561] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xEB69 [ 12.934653] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xEDE2 [ 12.934658] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table at offset 0xEE47 [ 12.954477] [drm] nouveau 0000:01:00.0: 0xEE47: Condition still not met after 20ms, skipping following opcodes [ 12.962086] [TTM] Zone kernel: Available graphics memory: 433116 kiB [ 12.962093] [TTM] Zone highmem: Available graphics memory: 1807620 kiB [ 12.962098] [TTM] Initializing pool allocator [ 12.962133] [drm] nouveau 0000:01:00.0: Detected 1024MiB VRAM (GDDR3) [ 12.962152] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining [ 12.962179] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture) [ 12.993326] usb 1-1.6.3: new full-speed USB device number 8 using ehci_hcd [ 13.007070] cfg80211: World regulatory domain updated: [ 13.007085] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 13.007091] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 13.007096] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 13.007101] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 13.007106] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 13.007119] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 13.007124] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 13.007128] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 13.007133] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 13.012419] [drm] nouveau 0000:01:00.0: Off-chip encoder 6/0 unsupported [ 13.012425] [drm] nouveau 0000:01:00.0: Off-chip encoder 2/0 unsupported [ 13.012429] [drm] nouveau 0000:01:00.0: Off-chip encoder 6/1 unsupported [ 13.012433] [drm] nouveau 0000:01:00.0: Off-chip encoder 2/1 unsupported [ 13.014674] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010). [ 13.014678] [drm] No driver support for vblank timestamp query. [ 13.014683] [drm] nouveau 0000:01:00.0: ACPI backlight interface available, not registering our own [ 13.021732] [drm] nouveau 0000:01:00.0: 4 available performance level(s) [ 13.021748] [drm] nouveau 0000:01:00.0: 0: core 200MHz shader 400MHz memory 120MHz voltage 850mV fanspeed 100% [ 13.021756] [drm] nouveau 0000:01:00.0: 1: core 275MHz shader 550MHz memory 301MHz voltage 850mV fanspeed 100% [ 13.021775] [drm] nouveau 0000:01:00.0: 2: core 383MHz shader 767MHz memory 301MHz voltage 850mV fanspeed 100% [ 13.021784] [drm] nouveau 0000:01:00.0: 3: core 600MHz shader 1500MHz memory 1000MHz voltage 1010mV fanspeed 100% [ 13.021794] [drm] nouveau 0000:01:00.0: c: core 275MHz shader 550MHz memory 300MHz voltage 850mV [ 13.088971] usb 1-1.6.3: New USB device found, idVendor=413c, idProduct=8160 [ 13.088978] usb 1-1.6.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 13.088984] usb 1-1.6.3: Product: Dell Wireless 365 Bluetooth Module [ 13.088997] usb 1-1.6.3: Manufacturer: Dell Computer Corp [ 13.136668] Bluetooth: Core ver 2.16 [ 13.136719] NET: Registered protocol family 31 [ 13.136724] Bluetooth: HCI device and connection manager initialized [ 13.136730] Bluetooth: HCI socket layer initialized [ 13.136734] Bluetooth: L2CAP socket layer initialized [ 13.136755] Bluetooth: SCO socket layer initialized [ 13.156647] usbcore: registered new interface driver btusb [ 13.813657] dell_wmi: Received unknown WMI event (0x11) [ 14.552423] [drm] nouveau 0000:01:00.0: allocated 1920x1200 fb: 0x330000, bo f6ca1000 [ 14.552575] fbcon: nouveaufb (fb0) is primary device [ 14.831719] Console: switching to colour frame buffer device 240x75 [ 14.835909] fb0: nouveaufb frame buffer device [ 14.835913] drm: registered panic notifier [ 14.835921] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0 [ 14.846102] dell_wmi: Received unknown WMI event (0x11) [ 15.928789] Adding 12557308k swap on /dev/sdb5. Priority:-1 extents:1 across:12557308k [ 15.958353] EXT4-fs (sdb1): re-mounted. Opts: (null) [ 16.244809] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro [ 16.402441] loop: module loaded [ 16.535048] EtherCAT: Master driver 1.5.2 2eff7c993a63 [ 16.535289] EtherCAT: 1 master waiting for devices. [ 16.606459] ec_generic: EtherCAT master generic Ethernet device module 1.5.2 2eff7c993a63 [ 16.606495] EtherCAT: Accepting F0:4D:A2:4F:DB:6A as main device for master 0. [ 16.606521] ec_generic: Binding socket to interface 2 (eth0). [ 16.608331] EtherCAT 0: Starting EtherCAT-IDLE thread. [ 16.608407] EtherCAT 0: Link state of ecm0 changed to UP. [ 16.616407] EtherCAT WARNING 0: 1 datagram TIMED OUT! [ 17.613832] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 18.129061] RPC: Registered named UNIX socket transport module. [ 18.129069] RPC: Registered udp transport module. [ 18.129074] RPC: Registered tcp transport module. [ 18.129078] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 18.179657] FS-Cache: Loaded [ 18.213512] NFS: Registering the id_resolver key type [ 18.213551] FS-Cache: Netfs 'nfs' registered for caching [ 18.221751] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 18.611393] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 19.449356] psmouse serio2: Failed to deactivate mouse on synaptics-pt/serio0 [ 19.612942] EtherCAT WARNING 0: 123 datagrams TIMED OUT! [ 19.904257] psmouse serio2: Failed to enable mouse on synaptics-pt/serio0 [ 20.610495] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 20.717488] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input15 [ 21.161367] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 21.161382] Bluetooth: BNEP filters: protocol multicast [ 21.181695] Bluetooth: RFCOMM TTY layer initialized [ 21.181714] Bluetooth: RFCOMM socket layer initialized [ 21.181720] Bluetooth: RFCOMM ver 1.11 [ 21.608053] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 22.436301] lp: driver loaded but no devices found [ 22.605796] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 22.705328] ppdev: user-space parallel port driver [ 23.603170] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 23.699437] iwlwifi 0000:0c:00.0: L1 Disabled; Enabling L0S [ 23.702383] iwlwifi 0000:0c:00.0: Radio type=0x0-0x2-0x0 [ 23.860518] iwlwifi 0000:0c:00.0: L1 Disabled; Enabling L0S [ 23.863528] iwlwifi 0000:0c:00.0: Radio type=0x0-0x2-0x0 [ 23.919350] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 23.994233] EtherCAT 0: Link state of ecm0 changed to DOWN. [ 24.058368] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 24.568967] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/serio2/input/input16 [ 26.318457] tg3 0000:09:00.0: eth0: Link is up at 100 Mbps, full duplex [ 26.318464] tg3 0000:09:00.0: eth0: Flow control is on for TX and on for RX [ 26.318485] EtherCAT 0: Link state of ecm0 changed to UP. [ 26.318711] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 26.324563] EtherCAT WARNING 0: 50 datagrams TIMED OUT! [ 27.326057] EtherCAT WARNING 0: 124 datagrams TIMED OUT! [ 28.323647] EtherCAT WARNING 0: 120 datagrams TIMED OUT! [ 29.321211] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 30.318774] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 31.316282] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 32.313838] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 33.311397] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 34.308954] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 35.306512] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 36.304088] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 37.305649] EtherCAT WARNING 0: 124 datagrams TIMED OUT! [ 38.307171] EtherCAT WARNING 0: 124 datagrams TIMED OUT! [ 39.308732] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 40.310262] EtherCAT WARNING 0: 124 datagrams TIMED OUT! [ 41.311810] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 42.313359] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 43.310929] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 44.309946] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 45.306031] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 46.307631] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 47.305170] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 48.306725] EtherCAT WARNING 0: 123 datagrams TIMED OUT! [ 49.308232] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 50.305831] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 51.307385] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 52.308916] EtherCAT WARNING 0: 124 datagrams TIMED OUT! [ 53.310458] EtherCAT WARNING 0: 123 datagrams TIMED OUT! [ 54.312401] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 55.313526] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 56.311082] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 57.312631] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 58.310188] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 59.307748] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 60.309340] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 61.306850] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 62.304407] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 63.301964] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 64.299521] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 65.297078] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 66.294638] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 67.292213] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 68.289765] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 69.287312] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 70.288857] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 71.286413] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 72.283972] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 73.281531] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 74.279088] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 75.276644] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 76.274203] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 77.271763] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 78.269317] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 79.266889] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 80.264431] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 81.261988] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 82.259547] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 83.257103] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 84.254660] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 85.252217] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 86.249791] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 87.247332] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 88.244889] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 89.242446] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 90.240020] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 91.237562] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 92.235119] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 93.232677] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 94.230232] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 95.227793] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 96.225348] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 97.222907] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 98.220468] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 99.218022] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 100.215583] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 101.213136] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 102.210693] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 103.208250] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 104.205807] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 105.207372] EtherCAT WARNING 0: 124 datagrams TIMED OUT! [ 106.208907] EtherCAT WARNING 0: 121 datagrams TIMED OUT! [ 107.206485] EtherCAT WARNING 0: 112 datagrams TIMED OUT! [ 108.212001] EtherCAT WARNING 0: 113 datagrams TIMED OUT! [ 109.217544] EtherCAT WARNING 0: 114 datagrams TIMED OUT! [ 110.215121] EtherCAT WARNING 0: 111 datagrams TIMED OUT! [ 111.216649] EtherCAT WARNING 0: 117 datagrams TIMED OUT! [ 112.214236] EtherCAT WARNING 0: 114 datagrams TIMED OUT! [ 113.211761] EtherCAT WARNING 0: 119 datagrams TIMED OUT! [ 114.213306] EtherCAT WARNING 0: 112 datagrams TIMED OUT! [ 115.210863] EtherCAT WARNING 0: 122 datagrams TIMED OUT! [ 116.208418] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 117.205977] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 118.203532] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 119.201094] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 120.198649] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 121.196205] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 122.193762] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 123.191319] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 124.188878] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 125.186435] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 126.183993] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 127.181549] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 128.179107] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 129.176664] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 130.174224] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 131.171779] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 132.169366] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 133.166896] EtherCAT WARNING 0: 124 datagrams TIMED OUT! [ 133.318401] I-pipe: head domain RTAI registered. [ 133.318419] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 133.318674] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 133.318683] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 8312360, CLK_FREQ 2660249000, CPU_FREQ 2660249000 [ 133.318689] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 133.318706] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8312360, 8312360, 8273750 [ 133.352602] RTAI[malloc]: global heap size = 2097152 bytes, . [ 133.352687] , , kstacks pool size = 524288 bytes. [ 133.352695] RTAI[sched]: hard timer type/freq = APIC/8312360(Hz); default timing: oneshot; linear timed lists. [ 133.352701] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2660249000 hz. [ 133.352705] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 133.377189] RTAI[math]: loaded. [ 133.612115] EtherCAT: Requesting master 0... [ 133.612124] EtherCAT: Successfully requested master 0. [ 133.613219] EtherCAT ERROR 0 0:1: PDO entry 0x6000:01 is not mapped. [ 133.613226] LCEC: master 0 PDO entry registration failed [ 133.613240] EtherCAT 0: Releasing master... [ 133.613255] EtherCAT 0: Released. [ 134.168449] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 134.431542] RTAI[math]: unloaded. [ 134.435102] SCHED releases registered named ALIEN PEDV$D [ 134.441791] RTAI[malloc]: unloaded. [ 134.539538] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 134.543249] I-pipe: head domain RTAI unregistered. [ 134.543566] RTAI[hal]: unmounted. [ 135.169992] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 136.167548] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 137.165106] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 138.162663] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 139.160223] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 140.157777] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 141.155336] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 142.152894] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 143.150449] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 144.148008] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 145.145563] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 146.143120] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 147.140678] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 148.138237] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 149.135793] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 150.133350] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 151.130908] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 152.128470] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 153.126023] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 154.123580] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 155.121138] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 156.118696] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 157.116252] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 158.113810] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 159.111367] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 160.108927] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 161.106484] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 162.104041] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 163.101597] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 164.103152] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 165.100710] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 166.098264] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 167.095821] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 168.093401] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 169.094945] EtherCAT WARNING 0: 123 datagrams TIMED OUT! [ 170.092482] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 171.090040] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 172.087595] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 173.085152] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 174.082709] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 175.080269] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 176.081817] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 177.079389] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 178.076933] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 179.074490] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 180.072048] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 181.069605] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 182.067162] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 183.064720] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 184.062274] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 185.059834] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 186.057391] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 187.054946] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 188.052504] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 189.050062] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 190.047621] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 191.045175] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 192.042733] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 193.040292] EtherCAT WARNING 0: 125 datagrams TIMED OUT! [ 194.037849] EtherCAT WARNING 0: 125 datagrams TIMED OUT!
10 years 2 months ago #78575 by sirop
Replied by sirop on topic Ethercat HAL driver
That's the point to research.
Time to create page: 2.496 seconds
