Ethercat HAL driver
10 years 3 months ago #77758 by zerix
Replied by zerix on topic Ethercat HAL driver
sirop wrote:
zerix wrote: I found problem. ethernet-port haven't contact. i put paper in port and now i can see device. But now I am having other problem. when I write
ethercat upload -t int8 0x6061 0
it is showing me
Failed to upload SDO: input/output error
In my case:
$ ethercat upload -p1 -t int8 0x6061 0 0x08 8
So your line without position argument would work if the master sees only 1 slave on the network.
I have two servo. and one servo works normal. but second servo doesn't can work with ethercat. Green LED blinks, but orange LED doesn't blink or switch on. Can you also help me with command
ethercat reg_read
? i dont understand what i should write. when i wrote
ethercat reg_read -t int8 0x040e 1
it shows me
Failed to read register: Input/output error
when i wrote
ethercat reg_read -t int16 0x040e 1
it shows me last error again.
10 years 3 months ago #77761 by sirop
Replied by sirop on topic Ethercat HAL driver
zerix wrote: I have two servo. and one servo works normal. but second servo doesn't can work with ethercat. Green LED blinks, but orange LED doesn't blink or switch on. Can you also help me with command
ethercat reg_read
it shows me
when i wrote
1. Please always use a position argument to avoid confusion as one cannot know if you have only 1 or more slaves on the
EtherCAT network.
2. You mentioned some hardware problems like loose contacts on the NIC ports.
So first do
ethercat slaves
just to know if the master can really see all slaves.
3.
ethercat reg_read [OPTIONS] <ADDRESS> [SIZE]
so your command should be either
ethercat reg_read -p$SLAVEPOSITION -t int8 0x040e 1
or
ethercat reg_read -p$SLAVEPOSITION -t int16 0x040e 2
But what is 0x40e register about? Never seen it...
As for LED indicators of the slave's states - rather consult the manual.
10 years 3 months ago #77967 by kehaar
Replied by kehaar on topic Ethercat HAL driver
Thank you for your reply!
Currently, apart from EL6601(Ethernet switch port from Beckhoff), I still have several EtherCAT devices to control simultaneously. Previously, I have written a HAL driver for EL3008, an 8 channel analog input I/Os from Beckhoff. However, I do not have any clue and experience in writing one for the EL6601, do you have any advice in writing an EtherCAT HAL driver for EL6601 under the LinuxCNC environment?
Thank you for your time !
10 years 3 months ago #77968 by sirop
kehaar wrote: Thank you for your reply!
First of all, it is worth looking at this docs patch:
sourceforge.net/p/etherlabmaster/code/ci...d87dcbc43fd04cffbea/
I cannot tell you more as I never used EoE functions of IgH EtherCAT-Master .
Besides this EL6601 manual makes a difference between Real-time data exchange and Non-real-time data exchange.
Non-real-time data exchange is the actual EoE.
So I would begin with standalone app just to learn how to "speak" with this slave either in real time or acyclic in terms of EL66601 manual.
The following user(s) said Thank You: kehaar
10 years 3 months ago #78208 by REEEN
Replied by REEEN on topic Ethercat HAL driver
Hello everyone,
simple question, does the linuxnc driver for ethercat also work with rt preempt ?
Or does it only work with rtai and xenomai ?
10 years 3 months ago #78217 by sirop
REEEN wrote: Hello everyone,
If the question is about using userspace threads instead of kernel threads with linuxcnc-ethercat,
then the answer is yes. I use userspace threads with xenomai. So rt-preempt should also go.
However, you might need to install the EtherCAT master manually, as github.com/sittner/ec-debianize/blob/mas...an/configure#L79-L95 does not mention rt-preempt.
The following user(s) said Thank You: Nico2017
Time to create page: 0.820 seconds
