Ethercat HAL driver
10 years 2 months ago #78685 by REEEN
Replied by REEEN on topic Ethercat HAL driver
Thank you really much Sirop, I will try this out :)
Iam really happy that there are people willing to help so much.
10 years 2 months ago #78702 by REEEN
Hi again,
Sirop, I just tried out what you told me I only enabled generic in configure script.
I got the same error again.
This is how the configure-stamp in rules script looks like:
configure: configure-stamp
configure-stamp: unpack-stamp patch-stamp
dh_testdir
./bootstrap
./configure --prefix=/usr --sysconfdir=/etc --localstatedir=/var --with-linux-dir=/lib/modules/3.18.13-rt10mah+/build --enable-generic
touch $@
He is somehow trying to enable the others anyway.
Do you find out why ?
is configure -r okay or should it be configure -a ?
If you need any further information just tell me.
Thank you !
10 years 2 months ago #78708 by sirop
Replied by sirop on topic Ethercat HAL driver
configure -r should be ok, but I do not know what to tell you now
but advise to build the master following etherlab.org/download/ethercat/ethercat-1.5.2.pdf , Chapter 9.
10 years 2 months ago - 10 years 2 months ago #78741 by REEEN
Thank you Sirop,
I did the following to install etherlab:
# hg clone hg.code.sf.net/p/etherlabmaster/code ethercat-hg
# cd ethercat-hg/
# hg update stable-1.5
# ./bootstrap
# ./configure --disable-8139too --enable-generic
# make
# make modules
# sudo make install
# sudo make modules_install
# sudo /sbin/depmod
# sudo ln -s /usr/local/etherlab/bin/ethercat /usr/local/bin/
--disable-8139too this was the key !
But Iam not sure what to do now ?
Can you help me ?
Last edit: 10 years 2 months ago by REEEN.
10 years 2 months ago - 10 years 2 months ago #78745 by sirop
1. Make a simple test with a slave you have just to know that the master works.
2. Proceed with github.com/sittner/linuxcnc-ethercat .
Last edit: 10 years 2 months ago by sirop. Reason: typo
10 years 2 months ago - 10 years 2 months ago #78746 by REEEN
Didn't I miss anything ?
how can I run the master ?
Time to create page: 3.297 seconds
