Ethercat HAL driver
10 years 2 months ago #78878 by narogon
Replied by narogon on topic Ethercat HAL driver
sirop wrote: Besides all that:
0055-fsm_slave_config_scan-to-fsm_slave.patch
The motivating case was a network of about 100 slave devices; while scanning
is fast (under a second, after prior SII patches), the configuration process
to bring the slaves from PREOP to OP took about 80 seconds (and you could
see the lights coming on each slave in sequence). After the patch it takes
about 20 seconds.
lists.etherlab.org/pipermail/etherlab-dev/2016/000553.html
How could I use the lcec component after install the patches???
The patches do lots of code changes and sittner lcec_component can't be installed...
Many thanks for your help sirop
BR
10 years 2 months ago #78879 by sirop
Replied by sirop on topic Ethercat HAL driver
narogon wrote: How could I use the lcec component after install the patches???
Before applying any patches: did you do the simple test as propose above forum.linuxcnc.org/forum/24-hal-componen.../78878?quote=1#78863 ?
10 years 2 months ago #78886 by narogon
Yes I did the test and the same results.
I've tested a different pc with a r8139too and it works. So I assume there is some kind of problem with this network card.
10 years 2 months ago - 10 years 2 months ago #78898 by narogon
I've just tried another r8169 and it doesn't work... Also I've tested using generic driver
Last edit: 10 years 2 months ago by narogon.
10 years 2 months ago #78900 by sirop
I've just tried another r8169 and it doesn't work... Also I've tested using generic driver[/quote]
Do you have also e1000e network card?
Generic driver won't make anything more reliable or faster.
10 years 2 months ago #78905 by narogon
Generic driver won't make anything more reliable or faster.[/quote]
Im going to buy one r8139 and other e1000e. Ana recommendation? Have every Intel card e1000e?
Time to create page: 5.998 seconds
