Beckhoff ethercat 64 with bit linuxcnc, How to install.
5 years 5 months ago #209772 by db1981
ok..
do a try with this, but i might remember that the apt sources are not available anymore..
5 years 4 months ago #211100 by endian
hello folks,
I am searching how to succesfully install ethercat on lcnc. I found more "tutorials" how to do and I do not know which is the easist way for begining... I found next links...
  1. sourceforge.net/projects/skynet-software/files/
  2. github.com/grotius-cnc/install_script
  3. forum.linuxcnc.org/27-driver-boards/3559...all?start=110#184991
  4. also forum.linuxcnc.org/27-driver-boards/3559...tall?start=30#135811
I currently run with 7i76e at integrated network card... but I have EK1100+EL1008+EL2008 connected to Realtek8139 in PCI port of this guy www.furbify.sk/pocitac-hp-compaq-8100-elite-sff-1605417 ...
thanks for any help!!
Regards Slav
5 years 4 months ago #211106 by tommylight
Ahoj Slav,
Pretty sure there is an ISO with ethercat installed in one of these links made by Grotius, so try to find it.
There should be several versions so find the latest.
forum.linuxcnc.org/38-general-linuxcnc-q...ntrol-in-c-c?start=0
forum.linuxcnc.org/38-general-linuxcnc-q...inuxcnc-link?start=0
The following user(s) said Thank You: endian
5 years 4 months ago #212868 by wang
Hello, I encountered such a problem when I executed : sudo ./get_source.sh
I get this :
qxh@qxh-w:~/2/linuxcnc-dev/ec-debianize$ sudo ./get_source.sh
Cloning HG commit 33b922...
adding changesets
adding manifests
adding file changes
added 2112 changesets with 8177 changes to 1502 files
updating to branch default
1116 files updated, 0 files merged, 0 files removed, 0 files unresolved
Cloning patchset commit 8ea394...
adding changesets
adding manifests
adding file changes
added 13 changesets with 528 changes to 310 files
145 files updated, 0 files merged, 0 files removed, 0 files unresolved
Apply patchset...
hg: unknown command 'qpush'
'qpush' is provided by the following extension:
mq manage a stack of patches
use "hg help extensions" for information on enabling extensions
Can you help me solve it? Thank you
5 years 4 months ago - 5 years 4 months ago #212875 by Nico2017
Hi @Wang,
please see post: forum.linuxcnc.org/27-driver-boards/3559...tall?start=50#157205 , on the earlier page of this thread (p6 by default).
I hope this helps.
Nico2017 wrote: Hi,
I think this is because the first step which use mercurial (hg) did not completely succeed. Restart from the install EtherCAT step 0
Make sure you got:
sudo apt-get install quilt
before. But this is more likely due to the mercurial hg options. At the first step doing:
cd ec-debianize ./get_source.sh
Read carefully the output. There might be an error indicated even if it is not clearly flagging it. This might implies hg extensions which use the qpush command which requires the mq extension. To add an extension in mercurial, follow the suggested help displayed on the terminal, creating a ~/.hgrc , ie on your home directory. Then edit this file as a text file:
[extensions] mq =
Retry step ./get_source.sh till you got a complete success of this step. I have noticed that this might work or not depending how you did the git cloning with or without root privilege. Same thing with the creation of the .hgrc file. You might have also to
as this is copying some files in specific locations.
Let me know how it this help, at least send the output of the ./get_source.
Once this step is successful you can carry on the installation
Thank you,
Nicolas
Last edit: 5 years 4 months ago by Nico2017. Reason: More precise with link
5 years 4 months ago #212888 by wang
I read your post and I also encountered this problem. I would like to ask how you linked to the real-time kernel
I think you said to delete the non-real-time kernel mandatory link, but how to delete the non-real-time kernel and not update a new kernel? Because sudo apt-get remove linux-image-*** he will install a new high version kernel. And do you need to reinstall ec-debianizer
_16246131018073.png[/attachment]attachment]
Time to create page: 0.165 seconds
