Ethercat random jitter fix
6 months 1 week ago #345798 by papagno-source
Good morning everyone. I would like to do more. I can make an image of my HD and put the image somewhere, made with Clonezilla or other software. Luca, I will contact you, so you can give me a link to support the image. While you have Debian 13, so you can try it on your system. In the meantime, today I will try your patch and try to scale the I/O peripheral, the last one on the bus, and if it still doesn't work, I will change PC.
6 months 1 week ago #345805 by rodw
Replied by rodw on topic Ethercat random jitter fix
I don't think that would help much without your slave  hardware. Its not just a simple config problem. The remote access is probably the best way.
6 months 1 week ago #345809 by grandixximo
YangYang found something to do OP real quick, maybe will have update tomorrow.
The following user(s) said Thank You: NWE
6 months 1 week ago - 6 months 1 week ago #345816 by papagno-source
Greetings everyone.
So I tested Grandixximo's latest fix.
Slave 0, i.e., the VIPA's I/O, wasn't synchronizing, while the drives were. That is, the VIPA card's Run LED wasn't staying on, but blinking.
So I decided to change the slave sequence. The drives were on 0-1-2, and I/O was on 3, last.
Now slave 3, i.e., I/O, is running correctly.
I started testing. I have the impression that the drive quotas are read faster at startup, sometimes almost as fast as Debian 10. I tried refClockSyncCycles=1 and refClockSyncCycles=-1. In the refClockSyncCycles=1 mode, the axes emit noise more frequently.
The refClockSyncCycles=-1 mode seems to work better, but sometimes I hear a little noise, especially if I move the browser windows.
In refClockSyncCycles=-1 mode, the pll-err pin oscillates from about 800 to -1000, but if I move the windows, it sometimes reaches -10000, and I seem to understand that as the value increases, the noise increases. The pll-out pin stays at values ​​from 2 to -2.
In refClockSyncCycles=1 mode, the pll-err pin always remains zero. The pll-out pin always remains zero.
In both modes, the ethercat command upload -p 0 -t uint16 0x1C32 0x01 returns 0x0002 2, on all axes, including the slave.
I tried changing the sync0Shift value to 500000 without any change.
At this point I'm thinking of changing the PC, I don't want the problem now to be the jitter of Debian Trixie, which is greater, at least double compared to Debian 10.
I'd like to point out that with this latest fix from Grandixximo, the pull-err value is hovering around zero, like Debian 10. While in previous versions the pull-err value was around 99200.
Furthermore, with the latest fix, the plug-out pin has a fluctuating value close to zero, while with previous versions it was always zero.
Last edit: 6 months 1 week ago by papagno-source.
6 months 1 week ago - 6 months 1 week ago #345823 by grandixximo
@papagno-source check these as well please
0x1C32:02 (cycle time), 0x1C32:03 (shift time), and 0x1C32:05 (min cycle time), 0x1C33:01 (input side)
Would still love to get direct access to the hardware so that I can check myself...
Edit:
YangYang found a 1.5.2 that is much quicker to OP
github.com/synapticon/Etherlab_EtherCAT_Master
Will try to port to 1.6.9 stable, otherwise make compatible linuxcnc-ethercat package for this 1.5.2
The OP times should not relate to the grinding.
Last edit: 6 months 1 week ago by grandixximo.
6 months 1 week ago - 6 months 1 week ago #345828 by rodw
It makes no sense to roll back to a version built for  kernel 2.6 (Trixie's is 6.12) that's not been touched for 7 years...
Last edit: 6 months 1 week ago by rodw.
Time to create page: 0.145 seconds
