Good morning everyone.
I'm continuing the discussion on the Forum, on this PC; I don't have Discord.
I ran the last tests requested by Grandixximo with two versions.
Both versions, with reference clock -1 and 1, don't work well; the axes emit noise.
With the value -1, they are very present when you move browser windows; with 1, they are less noticeable but are still there.
With halscope, I monitored the profile error of joint 0 and joint 1, and when the noise occurs, you see a spike in tracking error on both axes at the same time.
I also tried changing all the EtherCAT cables with no results.
Obviously, for those who have been following the discussion, I had to reinstall the HD with Debian 10, which works fine.
I tried optimizing the GroB command, but it doesn't work.
I tried varying synclock from 0 to 300,000 and 500,000, but it doesn't work.
Now I can't stop the customer who has been very helpful.
We could try again on the next machine, in about 3 months.
The problem with the initial delay of the LCEC pins has been resolved, but the synchronization problem is still present.
I've noticed that sometimes everything seems to be fine. You open maybe four browser windows, frecad, and so on, and everything is fine. Then you reboot, and after opening the first browser window, it starts to vibrate, and it stays that way until you reboot several times.
The problem is there, and it's significant. It means we'll be stuck with Debian 10.
I imagine some drives are more tolerant than others, but we can't use a system that only works well with some drives and not with others.
Probably, if the synchronization problems between the kernel and EtherCAT aren't resolved, in my opinion, the solution would be a hardware EtherCAT master.
I want to thank Grandixximo, RoDW, and others for their efforts.
If you'd like, once I've prepared the next machine, we can meet and work directly on the machine. I'd be willing to do anything to resolve the issue.
I remain available for any clarification.
