  • mooser
  • mooser
10 Dec 2025 22:45
2.9.4 Get the Open File dialog to include .NC files by default
Category: AXIS
Never occurred to me that it would be case sensitive.... My Mastercam is set to spits everything out in unppercase including the extension.
Many thanks for making me look at it again.
  • mooser
  • mooser
10 Dec 2025 22:30
Replied by mooser on topic 7i84u probably toasted
Category: Driver Boards
That's what I normally use but ones that are small enough for 28g wire are a little scarce around here.
I've got 100 26g on order but I don't like trying to double them over to make it large enough to crimp securely, seem to put a lot of faith in that spot where it comes out of the insulation :)
For now I'm seriously looking at trying this, actually seems to have a really good grip.. in theory it should have at least a decent electrical contact...
  • Hakan
  • Hakan
10 Dec 2025 21:34
Replied by Hakan on topic StepperOnline A6 Servo
Category: EtherCAT
Well done, andrax.
There are two homing methods
1. Linuxcnc normal homing. Google "linuxcnc homing" and you will find an article incl illustrative figures describing this.
2. Ethercat homing. Many people have used it, I have not so can't advise on that.
I propose you start with 1. You can always do 2. later on.
I actually think you are doing 1. and want to use one of the digital inputs as X homing switch.
The signal you have made looks ok. Just check that din-4 is a general purpose switch, not tied to ethercat homing.
Use the halshow utility to follow/watch pins to make sure they react the way you want.
  • matasbuk
  • matasbuk
10 Dec 2025 21:30 - 11 Dec 2025 18:45
Replied by matasbuk on topic C axis with a VFD?
C axis with a VFD?
Thank you for the reply. Will try to get something to work.
Thinking about using Delta C2000 VFD.
  • Hakan
  • Hakan
10 Dec 2025 21:04
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
I am away from the code for at least one more day. I'll give you some clues for now and give a more precise answer when I am back.
You *must* set up spi. The other pins are set up as needed. Use free-run mode and you don't need them.
Spi is setup using stm32duino standard spi functions.
Somewhere in lib/soes c or h file (also check subdirectories to lib/soes) there is a call to
spi_begin(). Find that . Check there for pins, speed, and Chip Select. And set them to match your dev board.
Use slow speed to start with. Increase as it starts to work. I have on max now (80 MHz?), was on some kHz when troubleshooting.
Actually #if 0 all ethercat code and use the normal arduino setup(), loop() for encoder testing.
If you use serial port output it must be explicitly opened or something, check code.
You should be able to come a long way and then I'm back.
  • PCW
  • PCW's Avatar
10 Dec 2025 20:41
MESA 7i76EU - Pinzuordnung (z.B. Endschalter)
Category: Deutsch
Just as a general thought, no GUI configurator can fully support the 7I76EU
(or any other hardware) , though I think MesaCT does support the output options.
In all but the simplest cases, some hand editing of hal/ini files is likely to be needed
and considerable hal customization will be needed for functions like tool changers,
spindle orientation, jogging options etc etc.
  • scotta
  • scotta's Avatar
10 Dec 2025 19:50
Replied by scotta on topic Remora sk1.4 with ethernet?
The SKR1.4 is not actively supported and the ethernet demo was an early concept testing. Please check this link for ethernet supported boards.
remora-docs.readthedocs.io/en/latest/har...hernet/ethernet.html
Cakeslob also has his F4 repo
github.com/cakeslob/Remora-STM32F4xx-W5500
  • tuxcnc
  • tuxcnc
10 Dec 2025 18:02
Replied by tuxcnc on topic 7i92 cnc motion controller from aliexpress?
Any one using this card?
I bought similar but not the same. Most important is that, there is custom bitfile preloaded at factory. If your's card works, do not try load any other bitfile.
I have some files received from seller (in attachment), the mesa-rtcp config is works for me, but not all resources are configured.
File Name: Ali7i92.tgz
File Size:1,011 KB
  • andrax
  • andrax's Avatar
10 Dec 2025 17:40
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Hello,
I have now got all axes running.
I would now like to set up homing.
When I start homing, the axes start moving.
However, the home switches are ignored and the axes continue to move.
I have linked the home switches in the HAL as follows:
net X-home-sw        <= lcec.1.6.din-4        => joint.0.home-sw-in
Is this correct, or does the home switch have to be set to HomeSwitch(DI3) from the A6 servo drive?
  • vibram
  • vibram
10 Dec 2025 15:29 - 10 Dec 2025 16:03
Category: EtherCAT
Hello,
With the help of @Hakan, I will try to make a SinCos encoder input ethercat compatible board.
I'm a beginner so please don't give credit to my post, this is a learning project.
chip used: STM32F407VE and LAN9252
Here is the git project:
github.com/paulsvc/Firmware
Done:
Step 1: Quadrature Encoder input
Ongoing:
Step 2: Ethernet layer
@Hakan, I struggle to setup the ethernet part. I use the following pins:
SPI2_MISO: PC2
SPI2_MOSI: PC3
SPI_IRQ: PA8
SPI2_SCK: PB10
SPI_NSS: PB8
SYNC0:PC6
SYNC1: PB15
I went through the EASERCAT7000 project but I'm not sure when do you setup these previous pins
Thank you in advance for your help
  • andypugh
  • andypugh's Avatar
10 Dec 2025 15:02
Replied by andypugh on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
Is there a way to manually apply the Monokrom filter plasma_gcode_preprocessor to a G-code file outside of Monokrom, just to see what the output looks like?
Does Monokrom have an option to save the current G-code file? (I can see that it might well not have, as you can't typically change the file in the GUI, so there is no point).
You might be able to view the file-as-run in the GUI though, and see something odd around (I stress "around" as the reported line number can be off by several lines)
Unary operators are things like SIN[] COS[] etc so I would be looking for unexpected square brackets.
  • andypugh
  • andypugh's Avatar
10 Dec 2025 13:34
Replied by andypugh on topic 7i84u probably toasted
While waiting I've got to find a better solution to using these fine wires from the sensors and pendant into the terminal blocks.
Maybe bootlace ferrules? Effective at stopping stray strands bridging between channels.
(And some of the crimpers are fun - there is a little video of a 6-segment one here, though the 4-segment ones work better in cage clamps, I feel.
www.amazon.co.uk/s?k=ferrule+crimper&crid=284PIPYNNE1CT )
  • rodw
  • rodw's Avatar
10 Dec 2025 11:54
freelancer needed to create a routine for ATC tool change (rackchange)
how do i upgrade linuxcnc only, without losing the configs and leaving bookworm? apt upgrade only adds office and some other things..
Your configs are in your ~/linuxcnc folder so keep it. If you used the linuxcnc ISO
sudo apt upgrade might do it.
I just published a video on how to upgrade to 2.9.7 on Trixie because it has 2.9.4 available in the Debian repos.
The apt pinning method I describe could be used on Bookworm as well. In fact uninstalling linuxcnc and removing the linuxcnc.list file in the APT folders would let you follow my Trixie method on Bookworm just keep the sources files pointing to bookworm
  • Masiwood123
  • Masiwood123's Avatar
10 Dec 2025 11:33
  • RaspII
  • RaspII
10 Dec 2025 07:42
Category: Deutsch
Thanks a lot for this information. Currently I will stay with the sourcing Outputs. I just started with LinuxCNC and don't plan to modify the Hal-File by hand at the moment (Pncconf is currently my approach).
If I'm more experienced with LinuxCNC I will do this modification or maybe a new LinuxCNC version is available which fully supports the 7i76EU.
Displaying 10081 - 10095 out of 11520 results.
Time to create page: 2.245 seconds
