  • andrax
  • andrax's Avatar
08 Dec 2025 10:58
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Here is my cthercAT.xml.
When loading, I get an error saying that the pin lcec.0.A6.control-word already exists.
>EtherCAT pdos< gives me completely different addresses for the A6 400W.
0x6060 is not mapped:
It is possible that my XML has an error.
But how am I supposed to write an 8 (csp mode) to 0x6060 if it does not currently exist on the A
File Name: ethercat.xml
File Size:8 KB
6 400W?
Here is the excerpt from my post again:
A6 750W
=== Master 0, Slave 0 ===
SM0: PhysAddr 0x1000, DefaultSize  256, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1400, DefaultSize  256, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1800, DefaultSize   12, ControlRegister 0x64, Enable 1
  RxPDO 0x1600 ""
    PDO entry 0x6040:00, 16 bit, ""
    PDO entry 0x6060:00,  8 bit, ""
    PDO entry 0x607a:00, 32 bit, ""
    PDO entry 0x60ff:00, 32 bit, ""
    PDO entry 0x607c:00, 32 bit, ""
    PDO entry 0x6098:00,  8 bit, ""
    PDO entry 0x6099:01, 32 bit, ""
    PDO entry 0x6099:02, 32 bit, ""
    PDO entry 0x609a:00, 32 bit, ""
SM3: PhysAddr 0x1c00, DefaultSize   28, ControlRegister 0x20, Enable 1
  TxPDO 0x1a00 ""
    PDO entry 0x6041:00, 16 bit, ""
    PDO entry 0x6061:00,  8 bit, ""
    PDO entry 0x6064:00, 32 bit, ""
    PDO entry 0x606c:00, 32 bit, ""
    PDO entry 0x6077:00, 16 bit, ""
A6 400W
=== Master 0, Slave 1 ===
  RxPDO 0x1701 ""
    PDO entry 0x60b8:00, 16 bit, ""
    PDO entry 0x60fe:01, 32 bit, ""
  TxPDO 0x1b01 ""
    PDO entry 0x603f:00, 16 bit, ""
    PDO entry 0x60f4:00, 32 bit, ""
    PDO entry 0x60b9:00, 16 bit, ""
    PDO entry 0x60ba:00, 32 bit, ""
    PDO entry 0x60bc:00, 32 bit, ""
    PDO entry 0x60fd:00, 32 bit, ""
  • voltaicsca
  • voltaicsca
08 Dec 2025 10:12
Replied by voltaicsca on topic Hybrid Manual/Stepper Control
Thanks for the replies! I have considered putting independent x/y MPGs somewhere on the machine, but it doesn't quite scratch the itch I'm trying to scratch.
My background is a manual machinist, and I wanted to add some CNC capability to my arsenal, even if that came at the cost of being able to do manual machining the way I used to. That said, there's no substitute from the feedback you get from turning the cranks, when you just need to make a quick slot, face a part, etc.
It seems like LinuxCNC (appropriately) is really intended almost exclusively for the CNC use case.
  • Hakan
  • Hakan
08 Dec 2025 07:58
Replied by Hakan on topic StepperOnline A6 Servo
Category: EtherCAT
Every slave must have its own configuration in the config xml file.
See example here. github.com/dbraun1981/hal-cia402/blob/ma...le/ethercat-conf.xml
You must enter the config for the new drive.
  • abs32
  • abs32
08 Dec 2025 07:49
Probe tripped during non-probe move deadlock
 without my M64/M65-flipflop solution,
Please publish your solution in full, including function declarations such as loadrt + everything, everything, everything. So that I can repeat it.
  • vibram
  • vibram
08 Dec 2025 07:47
Replied by vibram on topic MPG and analog command config issue
Category: Basic Configuration
yes, everything is working well thanks :)
  • jc2ktr
  • jc2ktr
08 Dec 2025 06:49
Replied by jc2ktr on topic Config 2 ethercat ports?
Category: EtherCAT
You get after start another lcec.1. instances with your pins.
I can provide a config later this day.
Greets sven
  • meister
  • meister
08 Dec 2025 05:57
can you please add your .json config.
Have you set the scale for the quad encoder correctly?
  • endian
  • endian's Avatar
08 Dec 2025 05:39
Replied by endian on topic Config 2 ethercat ports?
Category: EtherCAT
and then how will you specify the .hal file for separate masters?
there will be more lcec. instances?
do anybody have working config?
  • jc2ktr
  • jc2ktr
08 Dec 2025 04:49 - 08 Dec 2025 05:06
Category: EtherCAT
Yes, you add a second master in your /etc/ethercat.conf
There is already a line:
# The MASTER<X>_DEVICE variables also determine, how many masters will be
# created: A non-empty variable MASTER0_DEVICE will create one master, adding a
# non-empty variable MASTER1_DEVICE will create a second master, and so on.
MASTER0_DEVICE="eno0"
MASTER1_DEVICE="eno1 or mac adress"
Then you can add a second master in your ethercat-conf.xml
<master idx="1" appTimePeriod="1000000" refClockSyncCycles="5">
And that's it.
I had testet it with 2 Nic's not long ago
It's working fine.
Greetings Sven
  • heaven
  • heaven
08 Dec 2025 04:41
Config 2 ethercat ports? was created by heaven
Category: EtherCAT
My PC has two Ethernet ports. I want to use port 1 to connect to devices A, B, and C, and port 2 to connect to devices D, E, and F because they are in separate locations. Is it possible to configure two EtherCAT ports?
  • hanz24
  • hanz24
08 Dec 2025 04:06 - 08 Dec 2025 04:07
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
Sorry for the late response. If our problem is same, this is what I changed in the sii file from my Inovance driver. I changed that part to ‘04’ and then wrote it back to the driver after making the change.
  • Fastfred
  • Fastfred
08 Dec 2025 01:14
Replied by Fastfred on topic Clearpath HLFB amp.joint.delay
Category: HAL
I did try reversing the input, Does my custom.hal file look correct? I get a joint 0 amplifier fault instantly its the only joint i am trying to figure out at the moment i haven't tried to add the other joints yet. Is there other ways of doing this that might be easier to add in my case ?
  • andypugh
  • andypugh's Avatar
08 Dec 2025 00:09
Replied by andypugh on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
To get a specific kernel you probably need to get the source from kernel.org
www.kernel.org/pub/linux/kernel/v5.x/
Follow a similar process to the attachment but I assume you won't need to patch the real time kernel
If I go that way I will, absolutely, need to patch the kernel.
But this whole thread seems to say that there was a 5.4.279-rtai kernel that a number of people successfully tested. But which is now nowhere that I have looked.
I have installed 5.4.290-rtai on a machine here, and it seems to work for me, and I have created a LinuxCNC / Trixie / RTAI package based on it, but I don't want to bake that into an ISO if it's known to be an unreliable kernel.
  • jcdammeyer
  • jcdammeyer's Avatar
07 Dec 2025 23:32
Replied by jcdammeyer on topic wait_complete()
wait_complete()
I'm using a slightly older version of the probe screen so the gcode() method is in base.py. I haven't upgraded. I suppose I should.
I'm running axis 2.8.1.
I like the idea of the INI file value [TOOLSENSOR]RAPID_SPEED being used for the movement to/from the start search position. I could then even use F50 for example after tool is up above the work piece. Then when it reaches the other end it goes back to self.ps_rapid_speed from the probe screen parameter which I have set at 10.
However somehow although it works on Thonny the
if "G1 " in l:
l += " F#<_ini[TOOLSENSOR]RAPID_SPEED>"
is not working. And setting the box on the probe screen to 50 for rapid has the risk of breaking the probe. Actually anything above about 20 has that risk.
  • electrosteam
  • electrosteam
07 Dec 2025 23:20
Replied by electrosteam on topic GCode Review
GCode Review
Category: CAD CAM
I run Ubuntu 24.04 on my workshop station.
So no problem doing as Tommy suggested, and I will follow that up.
Did some more digging, found out FreeCad will open a GCode file and display the paths.
And, when a path is selected, the readout shows the (nearly) equivalent file line number and x,y,z coordinates.
Already solved the problem that initiated the OP, thanks to all.
John.
Displaying 10171 - 10185 out of 11520 results.
Time to create page: 2.077 seconds
