  • Z3n
  • Z3n
27 Nov 2025 15:42
Replied by Z3n on topic Converting a Brother TC215 to LinuxCNC
Category: Milling Machines
You can direct connect to via the AC Servos via a special cable through USB and their software: www.dmm-tech.com/resource-center
The 7I92 does connect via eithernet. I believe the reason for purchasing the dual board setup was to make sure there were enough axis controllers available for eventual expansion via rotary tables and things like that, as well as the appropriate spindle control for the mill.
  • Z3n
  • Z3n
27 Nov 2025 15:40 - 27 Nov 2025 15:44
Replied by Z3n on topic Red Init & Done Lights on 7i92M
Category: Driver Boards
It is a 7I92M as per the screen printing on the board and the sticker on the back.
I did check the 5v power and it appears to be getting a very solid 5v, but I will power it independently to double check in case there is some form of low voltage immediately at power on.
Appreciate the help, I'll start the RMA process with Mesa.
Edit: Oh, and I'm assuming I should be able to configure the 7I76 / 7I77D appropriately to be powered via direct 5v and look at the lights to confirm those boards function as well? The manual is a little sparse on what the different LED patterns indicate.
  • jmp97
  • jmp97
27 Nov 2025 15:39
Replied by jmp97 on topic Mesa 7I96s - 5 AXIS
Mesa 7I96s - 5 AXIS
Category: Installing LinuxCNC
Not, it's the same
  • PCW
  • PCW's Avatar
27 Nov 2025 15:24
Replied by PCW on topic Mesa 7I96s - 5 AXIS
Mesa 7I96s - 5 AXIS
Is the card IP address different in the 5 Axis configuration?
  • PCW
  • PCW's Avatar
27 Nov 2025 15:20
Replied by PCW on topic Red Init & Done Lights on 7i92M
First, is the a 7I92M or 7I92TM? these need different firmware and recovery is
done differently.
On a 7I92M, what is expected to happen at power up is that both red LEDs will
turn on briefly and then go out. If the /INIT light never goes out (even for a fraction of a second)
at power up, its likely an issue with the 5V power so first check the 5V power.
Also on a 7I92M, if the /INIT light blinks of briefly at power up and then re-illuminates,
this  suggests corrupted firmware or some other card issue which probably requires
returning the card to Mesa for analysis/repair/replacement.
  • meandreas72
  • meandreas72
27 Nov 2025 13:41
Button with toggle was created by meandreas72
Button with toggle
Category: HAL
Hallo,
ich brauche mal einen Tip bezüglich der custom postgui hall.
Ich möchte die Maschinenspindel extern über einen Taster ein bzw. wieder aus schalten. Im Moment mache ich das mit zwei Tastern. Einen für EIN und einen für AUS. Dabei wird ein MDI Befehl auf der Axis Oberfläche angestoßen. Ich weiß das es mit der Funktion Toggle möglich ist, nur einen Taster zum EIN und AUS schalten zu benötigen. Funktioniert das auch bei MDI Befehlen?
Gruß Andreas
  • RotarySMP
  • RotarySMP's Avatar
27 Nov 2025 13:23
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Category: Turning
Pick your excuse :
1/ That requires more effort than my inherent laziness allows :)
Everything is already in there.
2/ I don't see a deal like that. The best deal offered here for a 5KW servo and driver from AliExpress is at least €1000, so will cost more like €1500 delivered, with tax and customs.
3/ I only have 16A feed at 400V. The required supply varies, but those 5KW servo drivers seem to require supplies which can peak above 20A.
But it is basically what Schaublin did on the follow on 125-CCN model. Since my collet closer limits the spindle to 3000rpm, a 1:2 reduction to the spindle would work, as those servos seem to be 6000rpm.
  • Masiwood123
  • Masiwood123's Avatar
27 Nov 2025 11:59
Replied by Masiwood123 on topic Physical buttons to 7i96s+7i77
Category: HAL
thank you very much, I really appreciate it
  • timo
  • timo
27 Nov 2025 11:35
Replied by timo on topic Probleme beim Bohrfräsen
Category: Fusion 360
Die Beschreibung ist etwas vage, vielleicht kommt deshalb kein brauchbarer Hinweis.
Hat sich die Sache mittlerweile erledigt?
  • MTTI
  • MTTI's Avatar
27 Nov 2025 11:34 - 27 Nov 2025 11:42
QtPlasmaC – Magic Comments not creating materials from G-code
Category: Plasmac
Hi everyone,I’m trying to use the Magic Comments in QtPlasmaC to automatically create/select materials from my G-code.
Example:
(o=2, nu=2, na=5mm Mild Steel 40A, ph=3.1, pd=0.1, ch=0.75, fr=3000, kw=1.0)
​​​​​​​Result:
- QtPlasmaC shows an error like “invalid parameter in magic comment”
- The material is not created automatically
Material management in the GUI works normally
My goal is to automatically load correct cut settings (pierce height, cut height, feed rate, etc.) from the G-code generated in my CAM software.
Questions:
- Any specific setting to enable this feature in the INI / QtPlasmaC preferences?
- Could someone share a working example G-code header with material Magic Comments?​​​​​​​
Thanks a lot in advance for your help!
  • COFHAL
  • COFHAL
27 Nov 2025 11:01
Replied by COFHAL on topic Physical buttons to 7i96s+7i77
Category: HAL
Later I'll send you an example; I have two potentiometers connected to a 7i73 to control those parameters, and with a component that saves their position when the LCN is executed.
  • Aciera
  • Aciera's Avatar
27 Nov 2025 10:08
Replied by Aciera on topic Incremental Axes U, V, W support?
The gcode interpreter will only accept axes you have configured in your ini file. The live plot in the gui will add translation in U,V,W to position of X,Y,Z respectively.
Note that you will need to add 'U,V,W' to the GEOMETRY entry of the [DISPLAY] section in your ini file.
See 'configs/sim/axis/axis_9axis.ini' for an example configuration.
  • jmp97
  • jmp97
27 Nov 2025 09:45
Mesa 7I96s - 5 AXIS
I have checked the wiring of the drivers and the controller board. Everything seems to be fine.
With the 5 drivers turned on and the 3-axis configuration, it works fine. When I open the 5-axis configuration I have created, it gives an error.
Could it be due to a parameter in the HAL or INI?
  • Z3n
  • Z3n
27 Nov 2025 08:44
Replied by Z3n on topic Funny message when reply to a topic
Category: Forum Questions
No problem, thanks for your work on moderation - I know it's constant and often thankless. Appreciate you keeping the forums free of spammers and more use to us all as a result!
  • et
  • et
27 Nov 2025 07:52
Hi, thank you for the beta version. Just a small question, the 3.1.4.beta is 193.7 KB while the 3.1.3 is 350 KB. Is the beta full version? why is it so much smaller? Thanks
Displaying 10621 - 10635 out of 11519 results.
Time to create page: 4.258 seconds
