  • emresensoy
  • emresensoy
25 Nov 2025 02:59
Replied by emresensoy on topic LinuxCNC Hardware Survey
Category: Driver Boards
We have ESI files and many examples,
But, of course a driver is better than ever
  • EW_CNC
  • EW_CNC's Avatar
25 Nov 2025 02:46
Ohmic Probe + Material Height Feature Request
Category: Plasmac
I have added the Material Thickness parameter option for Ohmic Probe with Material Height.
The updated files are in the attached qtvcp folder. It needs to be placed into your working machine config directory.
Also the attached custom_postgui.hal must also be in your machine config folder.
The qtplasmac-imperial_material.cfg file has the material thickness added, it has the settings for a Hypertherm Powermax 85.
Snowgoer, I'm not sure if the custom_postgui file is the proper place to do the hal pin linking. If you have time to review the changes and add it to the source code, I would appreciate it. Otherwise I can try to figure out git and do a pull request.
File Name: qtvcp.tar.gz
File Size:780 KB
File Name: custom_postgui.hal
File Size:0 KB
File Name: qtplasmac-...rial.txt
File Size:24 KB
  • Lcvette
  • Lcvette's Avatar
25 Nov 2025 02:31 - 25 Nov 2025 02:32
Replied by Lcvette on topic Rack ATC
Rack ATC
Category: QtPyVCP
For probe basic non of that is required, the existing rack atc is fully setup for configuring the atc in the gui once the correct ini settings and var file parameter numbers have been added. It uses random tool change and tracks pockets the same as random carousel. Looks for the first open pocket for storing the tool and finds the tool by its tool number and the parameter number its stored in. We made it super easy to setup with only a few user entries in the ui itself to determine where the rack is on the machine and the direction of ascending pocket order . Then the first pocket coordinate and the pocket spacing is entered and the drop off and pickup heights and clearance distance and its ready to rock and roll!
  • johnbump
  • johnbump
25 Nov 2025 02:30
calling subroutine from G54, G55, G56, but it acts weird
Category: O Codes (subroutines) and NGCGUI
I wasn't good with my phrasing. I touch off G54, and explicitly set G10 L20 P1 X0 Y0 Z0 to force G54 (I may not need to do this? because it's what automatically happens when I touch off if I have the popup set to G54?), but don't ever use that except for touchoff/part location. (I *think* this is how I should be doing this?) Then I subsequently set up G10 P2, G10 P3, and so forth, and only machine at the work offsets referenced by those.
  • Lcvette
  • Lcvette's Avatar
25 Nov 2025 02:24
Rack ATC
Category: QtPyVCP
Is this for probe basic? If so the docs here have the information on how the rack atc should be setup in configs:
kcjengr.github.io/probe_basic/
  • PCW
  • PCW's Avatar
24 Nov 2025 22:23
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
On the Fujitsu also make sure that if it has the AMT feature
(common in corporate desktops), that it is disabled.
Also disable EEE and any PCIE power saving  in grub.
  • AgentWD40
  • AgentWD40's Avatar
24 Nov 2025 21:02
Replied by AgentWD40 on topic Configuring dual Y Axis drivers
When you get to about the stepper motor section of pncconf check out "tandem" axis... like this:
Also, depending on your machine you may or may not need to invert the direction of one of the motors. There's a few ways to do that but this is one way:
  • melayate
  • melayate
24 Nov 2025 20:03 - 24 Nov 2025 21:00
QtDragon M6 Remap Tool Measurement - Inconsistent/Wrong Offsets with VersaProbe
Category: Qtvcp
attached are my config files. I have been trying for over a week to get the remap to work, I don't know what am I doing wrong. thank you!
  • Aciera
  • Aciera's Avatar
24 Nov 2025 19:55
  • gardenweazel
  • gardenweazel's Avatar
24 Nov 2025 19:52
Replied by gardenweazel on topic qt_auto_probe_tool.ngc Oddity(Again)
Category: Qtvcp
Thanks for your feedback. I'm not so worried about the first issue above as much as the second issue that I describe above.
The second problem has persisted for a long time and many have tried their luck at resolving it. I continue to see problems being discussed
that may be probable causes for this subroutine.
Honestly, I think that the documentation around what I have described is perhaps incorrect or simply doesn't provide enough information
for the operator to make the subroutine work as expected. A good example of this is line number 31, the instructions indicate the following:
  31;  4 - Workpiece Measure: Use the button under the Probe Screens for "Probe Z height
  32 ;        of material:" this will set and display on the Probe Settings screen the
  33 ;        "Block Ht" = #<_hal[qtversaprobe.blockheight]> value in ABS coordinates.
What is missing is is there should be a "Jog to a coordinate" in order to measure the work piece height which will determine the "Block Ht" .
I am curious if there are any other steps involved that are not documented?
  • melayate
  • melayate
24 Nov 2025 18:47
Replied by tommylight on topic Rack ATC
Rack ATC
Category: QtPyVCP
Included with LinuxCNC, go to "sample configurations">sim>axis>remap>ract-toolchange>racktoolchange
It will copy the sample config to your config directory, so you can have a look at what it uses, and copy/paste the relevant stuff to your working machine config for testing on the actual machine.
Do make a backup or two before editing your machine files.
24 Nov 2025 18:42
Replied by tommylight on topic LinuxCNC homing twice in Axis SImulation
Category: AXIS
I do recall getting the same thing sometimes, but i never really bothered with why it happens, it is a sim and i use it only to check the gcode sometimes, not for anything important.
If you want to test on a real machine but with no machine attached, use the parallel port configs, so will work even with no parallel port, but it is a real machine so nothing is simulated. You will have to use immediate homing for it though.
  • papagno-source
  • papagno-source
24 Nov 2025 18:27
Replied by papagno-source on topic CNC AXIS IN PARKING MODE
Thanks everyone for the support.
Yes, I know, so where can I change the value in the source code?
  • PCW
  • PCW's Avatar
24 Nov 2025 17:36 - 24 Nov 2025 21:49
Replied by PCW on topic Configuring dual Y Axis drivers
The ideal way would be to have 2 sets of step/dir signals and 2 Y home switches so
any gantry racking can be corrected every time the machine is homed.
Whether one step/dir output can drive 2 motor drive inputs depends on the current
requirements of those inputs, but in general I would suggest the separate drive/separate
home switch system.
Displaying 10696 - 10710 out of 11518 results.
Time to create page: 0.458 seconds
