  • Jensner
  • Jensner
20 Nov 2025 20:54 - 21 Nov 2025 06:24
Aufschaukeln mit JMC iHSS60-36-30-21-38 in Verbindung mit Linear Encodern
Category: Deutsch
Hello,
today I did the steps from tommy`s link.
At the end i played around with the P and FF1.
After arount 50 different tests, slowly the hard errors dissapeared and at the end i found the best working configuration with P=15 and FF1 =1
So I configured this parameter on all 3 Axes and it works.
Only one last problem is the speed for "Go To Home"
Is ther a info where i can find the different settings for all moves?
Jogging Speed is OK and i can change ist via the GUI.
Homing Speed is also OK, but "Go Home" is far to fast.
Best regards
Jens
Here is my config (with working Linear-Encoders​ & Closed Loop Stepper)
File Name: FraeseNEU_...1-20.ini
File Size:10 KB
File Name: FraeseNEU_...1-20.hal
File Size:14 KB
20 Nov 2025 20:37
Replied by tommylight on topic Maho 500 W4 Retrofit
Assuming it has analog servo drives and those work, you would need an analog Mesa card, preferably Mesa 7i97T as it has analog outputs and encoder inputs all on one card, and a few I/O for limits and relays.
It is an ethernet board, and there is no practical difference between PCI/PCI-E/ETH cards except ETH cards can be mounted wherever is suitable on the machine as the LAN cable can be quite long, while DB25 cables are limited to about 1.5m (there are 3m and 5m ones but will have to be very good quality to work).
The Maho should (or should not?) have some EXE boards that translate the signal from motor feedback to encoder pulses that Mesa can use. This is what i've learned fro reading here on the forum, i do not have a Maho.
20 Nov 2025 20:28
Replied by tommylight on topic Servo Driver Plasma Retrofit
Category: Plasmac
You guys rock.
Not much lately, to old ! :)
You are welcomed, always.
And as a general rule, edit machine files only with simple text editors, anything else will add special characters to the files making a mess.
20 Nov 2025 20:25
20 Nov 2025 20:20
Replied by tommylight on topic Funzioni pausa e resume con pulsanti esterni.
Category: HAL
Parallel port in mode OUT (normal mode):
OUTPUTS
1, 2, 3, 4, 5, 6, 7, 8, 9, 14, 16, 17
INPUTS
10, 11, 12, 13, 15
  • ihavenofish
  • ihavenofish
20 Nov 2025 20:19
lemontart - a call for help with s curve, ui's, and all the cool toys
So, just to side track a little....
Where would you stick the control? Assume the machine is open, cause its a wood machine.
Would you put an arm on the machine frame, our would you put it on the stand? I feel like cause the stand is optional/variable, mounting it to the machine is better. off to the right side (viewed from the front) vertical 15" capacitive touch. with a little printed housing for a clusters of physical buttons and e stop.
Thoughts?
  • abs32
  • abs32
20 Nov 2025 19:57
v2.9 and not the perpendicularity of X and Y
ln -s /usr/lib/linuxcnc/modules/maxkins.so /usr/lib/linuxcnc/modules/matrixkins.so
# ll /usr/lib/linuxcnc/modules/ma*
-rw-r--r-- 1 root root 15240 окт 23 01:43 /usr/lib/linuxcnc/modules/maj3.so
-rw-r--r-- 1 root root 15680 окт 23 01:43 /usr/lib/linuxcnc/modules/match8.so
-rw-r--r-- 1 root root 14800 окт 23 01:43 /usr/lib/linuxcnc/modules/matrix_kb.so
lrwxrwxrwx 1 root root 36 ноя 20 22:52 /usr/lib/linuxcnc/modules/matrixkins.so -> /usr/lib/linuxcnc/modules/maxkins.so
-rw-r--r-- 1 root root 15512 окт 23 01:43 /usr/lib/linuxcnc/modules/max31855.so
-rw-r--r-- 1 root root 14704 окт 23 01:43 /usr/lib/linuxcnc/modules/maxkins.so
Start = abort,
Debug file information:
Note: Using POSIX realtime
4.hal:16: /usr/bin/rtapi_app exited without becoming ready
4.hal:16: insmod for matrixkins failed, returned -1
1358
Stopping realtime threads
Unloading hal components
maxkins: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
<commandline>:0: unloadrt failed
ЧЯДНТ? What I Do Wrong?
  • viacolvento
  • viacolvento
20 Nov 2025 19:57
Replied by viacolvento on topic Funzioni pausa e resume con pulsanti esterni.
Category: HAL
Grazie per la risposta,
Si, si tratta della funziona Hal. Ho letto come impostarla, ma sono in difficoltà nell'imdividuare i piedini della parallela. Pensavo di usare il p. 12 come ingressa di M8, il piedino 3 come segnale di PAUSE, e il piedino 13 come segnale di RESUME. Sono segnali TTL in uscita da un integrato cd 4017.
Un saluto
  • abs32
  • abs32
20 Nov 2025 19:47 - 22 Nov 2025 10:06
SOLVED  -
 matrixkins
is a standard technique for correcting the curvature of the portal in the LinuxCNC 2.10 kernel (and above). The issue of mutual correction of XYZ coordinates is resolved by specifying correction coefficients. However, this component is provided for single-engine machines, i.e. XYZ schemes. To use this software correction, changes must be made to the ini machine configuration files. Hal file does not require correction. MAN does not give these examples, см. github.com/LinuxCNC/linuxcnc/blob/master...ents/matrixkins.comp. However, in the ini file
instead of -
KINEMATICS = trivkins coordinates=XYZ
set -
KINEMATICS=matrixkins
then explicitly specify non-zero correction factors, for example -
halcmd setp matrixkins.C_yx -0.00252427184466
You will find the coefficient values and the transformation matrix in MAN.
The halcmd setp matrixkins.C_yx correction command -0.00252427184466 can be executed in the terminal (not while the machine is moving!), i.e. the parameter can be changed on the fly.
In case you have a multi-engine XXYZ configuration, etc., you need to change the source code of the matrixkins component (github.com/LinuxCNC/linuxcnc/blob/master...ents/matrixkins.comp), similar to www.forum.linuxcnc.org/38-general-linuxc...xyyz?start=20#338894
+ sudo halcompile --install matrixkins.comp
  • abs32
  • abs32
20 Nov 2025 19:22 - 20 Nov 2025 19:29
Replied by abs32 on topic Issue with G38.5
Issue with G38.5
For real-time kernel5.4.254 or 5.4.290, there is only version 2.9.4. Apparently, this patch isn’t there?
As planned, I installed 2.9.4 with both 254 and 290 cores. The test result is bad - excellent jitter (less than 1000), but the same sensor response error (when performing G38.5, the sensor moves, the response stops, stops and flies out error The sensor was activated during working movement - but in the g-code program there are no commands of the form G1-G3 at all!).
In addition, a completely new mistake for me is misalignment of axes (joints)! First, Joint0 (this is the first X motor), then Joint3 (the first Y motor) - XXYYZ circuit.
  • papagno-source
  • papagno-source
20 Nov 2025 19:01
CNC AXIS IN PARKING MODE was created by papagno-source
Good morning everyone.
I need to replace an old Siemens CNC.
I'd like to try Linux CNC, but the machine is a boring machine with a Z-axis that can be controlled manually or via CNC.
Let me explain. The Z-axis performs normal axis reference and moves in jog+ and jog- directions, with the position controlled by an optical scale.
However, the operator can press a mechanical selector, which allows the axis to be moved with a mechanical handwheel and, when desired, re-engage the axis in the CNC.
Clearly, the current CNC disables the axis drive when the mechanical handwheel is selected.
The axis on the current CNC goes into park mode, meaning the commanded position follows the feedback position, and when the mechanical handwheel is disengaged, the CNC does not enter a following error.
With Linux CNC, I could disable the drive and move the axis with the mechanical handwheel, but as soon as I disable the handwheel and enable the drive again, the CNC displays the following error because the commanded position doesn't follow the feedback position.
Is there a way to mimic the behavior of the Siemens CNC?
Thanks for support
  • Hakan
  • Hakan
20 Nov 2025 18:10 - 20 Nov 2025 18:13
Ethercat installation from repositories - how to step by step
Category: EtherCAT
"zstd: error 70 : Write error : cannot write block : No space left on device"
Boot device too small most likely.
A fresh install is never wrong.
You should be able to use a swedish I mean german version.
You seem to have missed a step where it says it will dismount the cd-rom and restart or something like that. A guess.
Install all in one large partition, or at least 100 Mb in the boot partition if you are required to have one.
This seem to be the proper sequence to remove raspi-firmware, you'll need to do that after a new install.
   sudo rm /etc/initramfs/post-update.d/z50-raspi-firmware
sudo rm /etc/kernel/postinst.d/z50-raspi-firmware
sudo apt purge --autoremove raspi-firmware
sudo apt update
  • kn612
  • kn612
20 Nov 2025 18:09
Replied by kn612 on topic Servo Driver Plasma Retrofit
Category: Plasmac
You guys rock. Thank you so much for pointing that out. I was editing hal with libre office instead of text editor. Added the line about offset mode and now the servos are quiet and don't move or jump when enabled.
  • kor
  • kor
20 Nov 2025 17:51
Category: EtherCAT
sudo apt remove raspi-firmware
[sudo] Passwort für bf20:
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
Paket »raspi-firmware« ist nicht installiert, wird also auch nicht entfernt.
Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
  linux-headers-6.1.0-30-amd64 linux-headers-6.1.0-30-common
Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
3 nicht vollständig installiert oder entfernt.
Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
initramfs-tools (0.142+deb12u3) wird eingerichtet ...
update-initramfs: deferring update (trigger activated)
linux-image-6.1.0-41-rt-amd64 (6.1.158-1) wird eingerichtet ...
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-41-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-41-rt-amd64.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.1.0-41-rt-amd64
E: mkinitramfs failure zstd -q -9 -T0 70
update-initramfs: failed for /boot/initrd.img-6.1.0-41-rt-amd64 with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: Fehler beim Bearbeiten des Paketes linux-image-6.1.0-41-rt-amd64 (--configure):
 »installiertes post-installation-Skript des Paketes linux-image-6.1.0-41-rt-amd64«-Unterprozess gab den Fehlerwert
 1 zurück
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von linux-image-rt-amd64:
 linux-image-rt-amd64 hängt ab von linux-image-6.1.0-41-rt-amd64 (= 6.1.158-1); aber:
  Paket linux-image-6.1.0-41-rt-amd64 ist noch nicht konfiguriert.
dpkg: Fehler beim Bearbeiten des Paketes linux-image-rt-amd64 (--configure):
 Abhängigkeitsprobleme - verbleibt unkonfiguriert
Trigger für initramfs-tools (0.142+deb12u3) werden verarbeitet ...
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
dpkg: Fehler beim Bearbeiten des Paketes initramfs-tools (--configure):
 »installiertes post-installation-Skript des Paketes initramfs-tools«-Unterprozess gab den Fehlerwert 1 zurück
Fehler traten auf beim Bearbeiten von:
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
I think it is probably better to do a fresh install by now. switching to english and see whether it will work right away. What do you guys think?
Displaying 10951 - 10965 out of 11534 results.
Time to create page: 2.209 seconds
