  • GDTH
  • GDTH's Avatar
27 Sep 2025 18:34
Carousel with counts move x amount of pockets
i have copied the carousel component and removed the align_pin if statement from state 8. I think this is ment for dc motors. So far it seems to work fine.
  • kb58
  • kb58
27 Sep 2025 17:44 - 27 Sep 2025 17:52
(Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Category: Driver Boards
FWIW, here are the files in question as of now, with the requested lines commented out or removed. I must still be missing something - or the manual leaves out critical information...
  • kb58
  • kb58
27 Sep 2025 17:38 - 27 Sep 2025 17:39
Understood. I tried the above - no change, status light still blinking, still in "PREOP".
Regarding a factory reset, I'm not sure how to apply it. See attached screenshot:
  • Hakan
  • Hakan
27 Sep 2025 17:07
I specifically was after the digital IO like here
#net sig300 lcec.0.0.digital-inputs => baxedmstatus.0.ect60inputs
net sig301 baxedmstatus.0.wirenok => qtvcp_embed.wirenok_led baxedmfeedcontrolV02.0.wireNOK
net sig302 baxedmstatus.0.wirefeedon => qtvcp_embed.wirefeed_led qtvcp_embed.led_wire
#net sig303 baxedmstatus.0.ect60-0-outputs => lcec.0.0.set60FE-1
#net sig304 baxedmstatus.0.ect60-1-outputs => lcec.0.1.set60FE-1
Put a # in front of the net lines. "and stuff" is vague for anything else that might cause problem for linuxcnc to start.
The logic of your machine is not correct then, but that's not important now. Get it to start only.
  • kb58
  • kb58
27 Sep 2025 16:48 - 27 Sep 2025 16:49
I will try that, yes. What is meant by "nets and stuff?"
I will also try the factory reset but am unsure how well that will work. What I mean is, let's say that I issue the factory reset command upon entry to the code. Then, the following code will immediately configure the driver into a "not factory reset" condition. Is the thinking that something was changed that has not been corrected and that a factory reset is the only way to fix it?
  • Hakan
  • Hakan
27 Sep 2025 16:48 - 27 Sep 2025 16:52
Replied by Hakan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
I meant "lcec_configgen".
I don't think there is a guide for TwinCAT here, have not seen one.
Maybe my old stumbling tries with Twincat still works.
Youtube video Twincat start
Download TwinCAT XAE shell from beckhoff (free).
It might need other downloads as well, but once installed it seems to work.
So I think we have tried everything now.
TwinCAT should be supported by the manufacturer, so you should be able to ask the manufacturer how to get it running.
Once you have got was is needed to get the drive from PreOP+E it should be possible to replicate in lcec.
  • Hakan
  • Hakan
27 Sep 2025 16:37
Can you comment out nets and things in the hal file to also remove the digital in and out?
rodw also mentioned doing a factory reset of the drive by writing to a sdo. Can you do that too?
  • Ul
  • Ul
27 Sep 2025 15:55
  • ulda
  • ulda
27 Sep 2025 14:53 - 27 Sep 2025 14:56
proudly presenting a Maho MH700 retrofit ..
Category: CNC Machines
Hi
The machine is sold, but I have the config data.you can download it to the attachment.
/ulda
  • Aciera
  • Aciera's Avatar
27 Sep 2025 14:31
Replied by Aciera on topic Spindle speed settings
Category: Gmoccapy
I think you might have to look at the [SPINDLE_0] section in the ini.
  • kworm
  • kworm
27 Sep 2025 14:17
Replied by kworm on topic Beckhoff AX5YZZ internal probing
Category: EtherCAT
If you already have it working in TC3 then my stuff won't help.  I don't know if you are using Beckhoff drives but here is some documentation that might help.  I think you will have to parametize everything and then enable with something like S-0-0405 before initiating with the control word.
Pages 104-105:
download.beckhoff.com/download/Document/...scription_hw2_en.pdf
Many IDNs dealing with probing...just search for "prob":
download.beckhoff.com/download/Document/...N_Description_en.pdf
Hope this helps.
  • GDTH
  • GDTH's Avatar
27 Sep 2025 13:52
okay, i will sure to be using in that in the end. however when i am using M120 or just put the pocket number manualy it just gets stuck in state 8 where it is waiting for align_pin to be something else then 0. As nothing moves , this will never happen. also i constantly getting the error "the toolchanger has hailed its alignment check". I have used the carousel comp many times. howeve this is the first time with only a stepgen. with that in mind and that i barely find anyone use it the same i am question if this actualy works with stepgen (Counts).
  • jcbryant
  • jcbryant
27 Sep 2025 13:40
Going from Devian 10 to 12 has created problems
Thank you very much for explaining this. I do hate not understanding things. And I now understand how it can be that simply writing to a file effect irq's, and why changes made don't persist after a reboot (something else that was troubling me). Clearly this is an instance of a pseudo file system (something I'd never heard of until this morning).
This whole experience has extended my limited knowledge of Linux. And, incredibly enough, I now seem to have a functioning system. The diagnostic tests look good and, although I've hardly stressed it very much, Linux CNC appears to be perfectly functional save for the fact that the Axis window won't maximize. I'll start a separate thread on this as it's a pretty specific issue. Hopefully a solution will turn up, and f none does I've also found some workarounds.
Many thanks to both of you for responding. Were it not for you two I would never have got things working.
  • phew
  • phew
27 Sep 2025 13:26
LCNC 2.9.5 - How to jog with a wireless xbox bt controller
Category: Basic Configuration
Yeah, finding things on the forum is currently a bit tedeous for me. At least from Central Europe it sometimes takes like 15-20 seconds to load a single thread. Since my last visit this seems to have improved a lot (today it's actually quite fast), maybe it was just a temporary routing issue. The wiki loads way faster though, probably due to its pages being static.
Yeah I completly understand, I mean jogging with the controller is more of a nice-to-have than a must-have.
github.com/LinuxCNC/linuxcnc/issues/3573
  • anli
  • anli's Avatar
27 Sep 2025 11:34 - 27 Sep 2025 11:38
Spindle speed settings was created by anli
Category: Gmoccapy
I try to setup my spindle in gmoccapy. The spindle uses wj200_vfd, I can start it and run it via gmoccapy, however I don't manage to set up the correct parameters for the speed selection. The spindle has min speed 0 and max speed 24000 rpm. This is my setup:
In machine.hal:
[DISPLAY]
DISPLAY = gmoccapy
CYCLE_TIME = 150
DEFAULT_SPINDLE_SPEED = 2000
MIN_SPINDLE_OVERRIDE = 0
MAX_SPINDLE_OVERRIDE = 2.4
DEFAULT_SPINDLE_0_SPEED = 2000
MIN_SPINDLE_0_SPEED = 0
MAX_SPINDLE_0_SPEED = 24000
MIN_SPINDLE_0_OVERRIDE = 0
MAX_SPINDLE_0_OVERRIDE = 2.4
and in machine.pref:
scale_spindle_override = 2.4
spindle_bar_min = 0.0
spindle_bar_max = 24000.0
spindle_start_rpm = 10000.0​​​​​​​
but I can't manage to get it up to 24000rpm. What am I doing wrong here?
Displaying 11941 - 11955 out of 14148 results.
Time to create page: 0.600 seconds
