  • grandixximo
  • grandixximo's Avatar
07 Sep 2026 03:17
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
You did not give linuxcnc-ethercat version
github.com/linuxcnc-ethercat/ethercat/releases
github.com/linuxcnc-ethercat/linuxcnc-ethercat/releases
I made arm64 debs as well...
syncToRefClock="false" without a refClockSyncCycles means free mode, don't use with axis.
syncToRefClock is going away because it is confusing, use refClockSyncCycles=-1 if you want to test having the pi sync to the clock on the drives, in your case it does not seem to work, should be same as syncToRefClock="true" but test with latest version.
refClockSyncCycles="1" if your latency is decent is a good choice.
  • Aciera
  • Aciera's Avatar
07 Sep 2026 02:27
Replied by Aciera on topic 5 axis tool offset
5 axis tool offset
Category: CAD CAM
5 axis is certainly a bit off the beaten track. You might want to try on the linuxcnc discord server or on a forum that caters more to 5axis machining and CAM applications. I'm afraid I don't have any links for you though.
  • jjdege
  • jjdege's Avatar
07 Sep 2026 02:01
Replied by jjdege on topic EtherCAT Master Beckhoff slave not found
Category: Basic Configuration
Here   you have a good example of the xml file for Beckhoff devices
Hi
  • spumco
  • spumco
06 Sep 2026 21:36
Replied by spumco on topic Looking for consultant
 If you know somebody who might be a fit or would be interested yourself, I would love to hear from you.
Contact details?
  • spumco
  • spumco
06 Sep 2026 21:34
Replied by spumco on topic Paid Consulting Opportunity
Category: QtPyVCP
Not me, despite really needing the money, i never charge for any help here or when initiated from here, and i am of no use for Probe Basic, yet.
For other things related to LinuxCNC, i am here often and daily, so feel free to shoot questions here.
You're Mr. Helpful, Tommy - no sarcasm at all.
I suspect the OP has an issue with the Probe Basic ATC control scheme not meshing with their hardware.  Same thing I ran in to when I was setting up my mill - I don't have a 'dumb' on/off motor with geneva drive, so the ATC subroutines aren't gonna work.
I'm betting that as a business they would rather spend money to get things sorted than go back-and-forth over the forum for days/weeks.  Regardless of how awesome the forum members are, sometimes you just want to buy your way out of a jam.
06 Sep 2026 19:31
Replied by tommylight on topic Encoder question
Encoder question
...but it just runs as soon as i enable it.
Does it run slowly or at full speed?
If the drive and motor are a set, do not try to tune them before making sure that is the issue, for this:
-disconnect the analog drive input from Mesa
-connect those two wires together
-power on the drive
-enable the drive
>>>does the motor turn slowly ?
-If yes = move on the drive is fine
-If no = first thing to check is Tacho wiring and brushes, then check motor brushes (if any).
>also check the commutator state for both, if there are signs of sparking on tacho = change tacho and check the drive output to tacho for whatever signal it should output. Rarely an issue, very rarely.
-Use compressed air to blow the brush holes and do not breathe near it
-And VERY important, return the brushes in the same hole you got them from, in the same direction and orientation.
  • Tinker
  • Tinker
06 Sep 2026 19:11
Replied by Tinker on topic Encoder question
Encoder question
I think i might have a drive issue, the encoder counts are working but it just runs as soon as i enable it. The drive for the 4th is from another machine and i thing i need to break my oscilliscope out and actually tune it per their directions. Im going to get that squared away and then start messing with the software side of it.
Thank you again for all your help!!!!
06 Sep 2026 19:06
Replied by tommylight on topic PureCutCNC
PureCutCNC
Category: CAD CAM
Looks OK, but i have not used it.
I did use PyCAM several years back, it was terribly slow to generate code but easy to use.
I wonder how fast is this at generating code...
06 Sep 2026 19:00
MeasurefromSTL - Online measurement tool - Open source
Category: Show Your Stuff
Thank you, i can see some uses for it, personally.
06 Sep 2026 18:54
IgH 1.6.9 MEASURE_TIMING 1 kHz on Debian 13 RT, N100, I226-V + ec_igc (isolcpus
Category: EtherCAT
Can we merge these two topics, seems way easier for users to find as the only variable is the CPU.
Or am i missing something?
Thank you, either way.
06 Sep 2026 18:52
Replied by tommylight on topic GrooveCam
GrooveCam
A short video tutorial would be really nice.
Thank you.
06 Sep 2026 18:50
Replied by tommylight on topic emco compact 55 mill. Just starting
Category: Milling Machines
Parallel port, make the machine work, see if you can be content with what it can do, then decide if you want to upgrade.
Emco usually use parallel port, so the upgrade from parallel would be Mesa 7i92T and an IDC26 to DB25 cable, plug and play etc, etc.
This is personal, so take this as you see fit, but i do not use RPI and probably never will, as 1. they are way to much fuss for everything, and 2. they are way more expensive than a good used laptop with touchscreen so when you add the screen and the other stuff needed it usually comes to twice more expensive than that laptop.
And that laptop will beat the living sh#t out of RPI for everything.
See Lenovo X1 Yoga, or Y370 or Y380, but beware that despite several of mine and other members here, yours might end up not usable, it is a risk, but for me definitely worth taking as i can find those from 120 to 220 Euro a piece in perfect condition.
06 Sep 2026 16:41
Encoder question
forum.linuxcnc.org/10-advanced-configura...to-example-mesa-7i77
Skip to the part about wiring and tuning.
06 Sep 2026 16:37
Ethernet connection to Mesa 7i76e disconnecting on its own after one minute
Category: Plasmac
All I had to do was switch this setting from automatic to manual in the network settings and boom works now!
If you used this:
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
It clearly states to change that to manual.
06 Sep 2026 16:32
Replied by tommylight on topic Mesa Suppliers
Mesa Suppliers
Category: Driver Boards
www.welectron.com
Should be added to first post, they are in Germany and been keeping a steady stock of Mesa boards, i did order from them several times and everything was fine. My sister lives in Germany so the shipping goes to her, usually in 2-4 days, and then i have to wait about a week or two to get them here.
Also the link to duzi.cz and cncmonster should be removed, duzi has security certificate issues and the shop is 404, cncmonster seems to have moved to other things.
Displaying 1216 - 1230 out of 11356 results.
Time to create page: 0.411 seconds
